Hi, I’ve been trying to configure my system to “Hibernate” (suspend to disk). I followed this guide (with some changes as I’m systemd-based) and the hibernate button is now available in KDE, the system suspends with no issues.
When I start up again after the suspend, the system boots normally instead of resuming. In dmesg, I can see that the swapfile is loaded successfully but there are some errors from nvidia that cause it to boot from scratch.
[ 4.601338] PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
[ 4.601346] PM: hibernation: Marking nosave pages: [mem 0x0009e000-0x0009efff]
[ 4.601350] PM: hibernation: Marking nosave pages: [mem 0x000a0000-0x000fffff]
[ 4.601356] PM: hibernation: Marking nosave pages: [mem 0x85984000-0x85984fff]
[ 4.601360] PM: hibernation: Marking nosave pages: [mem 0x9099a000-0x909dffff]
[ 4.601365] PM: hibernation: Marking nosave pages: [mem 0x93bfa000-0x93bfafff]
[ 4.601368] PM: hibernation: Marking nosave pages: [mem 0x95db5000-0x99ffefff]
[ 4.601956] PM: hibernation: Marking nosave pages: [mem 0x9a000000-0xffffffff]
[ 4.602798] PM: hibernation: Basic memory bitmaps created
[ 4.651518] PM: Using 3 thread(s) for lzo decompression
[ 4.651520] PM: Loading and decompressing image data (872611 pages)...
[ 4.719112] PM: Image loading progress: 0%
[ 5.284108] PM: Image loading progress: 10%
[ 5.415718] PM: Image loading progress: 20%
[ 5.545200] PM: Image loading progress: 30%
[ 5.667252] PM: Image loading progress: 40%
[ 5.787451] PM: Image loading progress: 50%
[ 5.898473] PM: Image loading progress: 60%
[ 6.002815] PM: Image loading progress: 70%
[ 6.163241] PM: Image loading progress: 80%
[ 6.251344] PM: Image loading progress: 90%
[ 6.328626] PM: Image loading progress: 100%
[ 6.328634] PM: Image loading done
[ 6.328640] PM: hibernation: Read 3490444 kbytes in 1.67 seconds (2090.08 MB/s)
[ 6.328977] PM: Image successfully loaded
[ 6.328980] printk: Suspending console(s) (use no_console_suspend to debug)
[ 6.371239] NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
[ 6.371250] nvidia 0000:01:00.0: PM: pci_pm_freeze(): nv_pmops_freeze [nvidia] returns -5
[ 6.371695] nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_freeze.llvm.11904911950140034564 returns -5
[ 6.371710] nvidia 0000:01:00.0: PM: failed to quiesce async: error -5
[ 6.438999] PM: hibernation: Failed to load image, recovering.
[ 6.521441] PM: hibernation: Basic memory bitmaps freed
[ 6.521853] OOM killer enabled.
[ 6.521853] Restarting tasks: Starting
[ 6.522104] Restarting tasks: Done
[ 6.522112] efivarfs: resyncing variable state
[ 6.538395] efivarfs: finished resyncing variable state
[ 6.538403] PM: hibernation: resume failed (-5)
My understanding of the issue is that the system memory was saved to disk successfully, but the video memory was not, forcing a regular boot. This happens consistently so far.
I’ve enabled the nvidia-resume, nvidia-hibernate, and nvidia-suspend systemd services, and set NVreg_PreserveVideoMemoryAllocations=1 in /etc/modprobe.d/nvidia-power-management.conf.
/proc/driver/nvidia/params contains the expected lines PreserveVideoMemoryAllocations: 1 and TemporaryFilePath: "/var/tmp".
Others online (and the Arch docs) mentioned Early KMS, causing the failure because the nvidia driver can’t load from its saved files before the disk is mounted. As far as I can tell this isn’t enabled on my system, my mkinitcpio hooks are base systemd autodetect keyboard sd-vconsole modconf block sd-encrypt btrfs filesystems resume fsck and the MODULES list is empty.
I also found this issue on GitHub which leads me to believe this is an issue with the open source Nvidia drivers - but it also seems that the proprietary ones are no longer available for CachyOS?
Any help or pointers is appreciated, thanks!
