I tried to activated hibernate by following this blog entry. Every step works flawless and the hibernate option appears in menu of kde. It seems like the system writes the ram to the ssd if i try to hibernate. But after starting the system the bootloader doesn’t “use” the hibernate partition. I tried systemd and also grub. Grub shows a message that he founds something on the hibernate partition but still I get a “fresh” desktop. What can I do to fix this?
I tried again to hibernate and this what “journalctl -b” shows:
Summary
Jun 18 18:17:46 viper-cachyos kernel: Linux version 6.15.2-3-cachyos (linux-cachyos@cachyos) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Tue, 17 Jun 2025 >
Jun 18 18:17:46 viper-cachyos kernel: Command line: BOOT_IMAGE=/vmlinuz-linux-cachyos root=UUID=f12bb03c-9eca-4113-8d17-732fd56eb659 rw rootflags=subvol=@ loglevel=3 quiet
Jun 18 18:17:46 viper-cachyos kernel: BIOS-provided physical RAM map:
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009d81fff] usable
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x0000000009d82000-0x0000000009ffffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x000000000a20e000-0x000000000affffff] usable
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x000000000b020000-0x00000000bb31afff] usable
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000bb31b000-0x00000000bb69afff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000bb69b000-0x00000000bb6fefff] ACPI data
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000bb6ff000-0x00000000bcdfdfff] ACPI NVS
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000bcdfe000-0x00000000bddfefff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000bddff000-0x00000000beffffff] usable
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000bf000000-0x00000000bfffffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fd600000-0x00000000fd7fffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x0000000100000000-0x000000083f37ffff] usable
Jun 18 18:17:46 viper-cachyos kernel: BIOS-e820: [mem 0x000000083f380000-0x000000083fffffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: NX (Execute Disable) protection: active
Jun 18 18:17:46 viper-cachyos kernel: APIC: Static calls initialized
Jun 18 18:17:46 viper-cachyos kernel: efi: EFI v2.7 by American Megatrends
Jun 18 18:17:46 viper-cachyos kernel: efi: ACPI=0xbcde7000 ACPI 2.0=0xbcde7014 TPMFinalLog=0xbcdb1000 SMBIOS=0xbdbcf000 MEMATTR=0xb8d22018 INITRD=0xb8d25098 RNG=0xbb6d1018 TPMEventLog=0xbb6c8>
Jun 18 18:17:46 viper-cachyos kernel: random: crng init done
Jun 18 18:17:46 viper-cachyos kernel: efi: Remove mem297: MMIO range=[0xf0000000-0xf7ffffff] (128MB) from e820 map
Jun 18 18:17:46 viper-cachyos kernel: e820: remove [mem 0xf0000000-0xf7ffffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: efi: Remove mem298: MMIO range=[0xfd200000-0xfd2fffff] (1MB) from e820 map
Jun 18 18:17:46 viper-cachyos kernel: e820: remove [mem 0xfd200000-0xfd2fffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: efi: Remove mem299: MMIO range=[0xfd600000-0xfd7fffff] (2MB) from e820 map
Jun 18 18:17:46 viper-cachyos kernel: e820: remove [mem 0xfd600000-0xfd7fffff] reserved
Jun 18 18:17:46 viper-cachyos kernel: efi: Not removing mem300: MMIO range=[0xfea00000-0xfea0ffff] (64KB) from e820 map
Jun 18 18:17:46 viper-cachyos kernel: efi: Remove mem301: MMIO range=[0xfeb80000-0xfec01fff] (0MB) from e820 map
lines 1-46
Does anybody see something that seems wrong?
Maybe I found something…?:
Jun 18 18:17:46 viper-cachyos kernel: Kernel command line: BOOT_IMAGE=/vmlinuz-linux-cachyos root=UUID=f12bb03c-9eca-4113-8d17-732fd56eb659 rw rootflags=subvol=@ loglevel=3 quiet
Jun 18 18:17:46 viper-cachyos kernel: Unknown kernel command line parameters “BOOT_IMAGE=/vmlinuz-linux-cachyos”, will be passed to user space.
Did you check the entire log? I personally have a problem with NVIDIA: maj 12 14:08:27 cachyos kernel: nvidia 0000:01:00.0: PM: pci_pm_freeze(): nv_pmops_freeze [nvidia] returns -5.
