After CachyUpdate and restart when I try to check the updates again i get:
==> Looking for updates…
==> ERROR: Cannot fetch updates==> No update available
==> No orphan package found
pacsort: error while loading shared libraries: libalpm.so.15: cannot open shared object file: No such file or directorypacsort: error while loading shared libraries: libalpm.so.15: cannot open shared object file: No such file or directory==> No old or uninstalled cached package found
had the same problem. seems to be fixed after running octopi and updating the pacman-contrib package, which was noted as not up to date. (sorry, rather new to arch-based linux, so i don’t know the command line version to do this)
updating system this way works but when running Cachy OS update - the pacsort error persists.
New to Cachy OS. I’m not entirely sure about the differences between the 2 . I assumed that the Cachy OS update runs “sudo pacman -Syu” script. Is that right?
We might be getting the error for different reasons. I usually check mirrors if an update runs into problems, and it seem to work for me. Will the error return at some point, ??
From octopi, install pacman-contrib versions 1.13.1-2.1 from the cachyos repository.
The cachyos-extra-v3 repository is not yet updated, and the pacman -Syu command will indicate this.
Confirmed. Update pacman-contrib through Octopi (from cachyos repository). After that I run cachyupdate, updated pacman through cachyupdate and error is gone.
