Problem after CachyUpdate
You need libalpm.so.16 but the mirrors are not providing it.
ldd /usr/bin/pacsort | grep libalpm
check what you have
when libalpm.so.15 then run
sudo cachyos-rate-mirrors
sudo pacman -Syyu pacman-contrib
check again with ldd /usr/bin/pacsort | grep libalpm
if it’s still on .15 your mirrors are not providing you with a .16 version
manual install
your architecture v2,v3,v4 ?
replace with what you are using now next to the letter v in URL
v4 example
https://cdn77.cachyos.org/repo/x86_64_v4/cachyos-extra-v4/pacman-contrib-1.13.1-1.2-x86_64_v4.pkg.tar.zst
v3 https://cdn77.cachyos.org/repo/x86_64_v3/cachyos-extra-v3/pacman-contrib-1.13.1-1.2-x86_64_v3.pkg.tar.zst
cd /tmp
curl -LO https://cdn77.cachyos.org/repo/x86_64_v3/cachyos-extra-v3/pacman-contrib-1.13.1-1.2-x86_64_v3.pkg.tar.zst
sudo pacman -U ./pacman-contrib-1.13.1-1.2-x86_64_v3.pkg.tar.zst
after install check what ver you have now
should be libalpm.so.16
i did the manual install, worked perfectly, thank you
I had a similar problem with the recent update. Went to update due to discord being needy and kept getting “Cannot fetch updates”. Thank you all so much! after running rate-mirrors cachyos then sudo pacman -Syu the problem was resolved and the updater is working again.
Hello @Theogren and welcome to the forum. Nice to hear that you got your problem fixed. Normally we refrain from “necro-ing” solved threads, but as you are new here, you wouldn’t know that, so all is fine.
Yes, cachyos-rate-mirrors followed by a full system upgrade by sudo pacman -Syu fixes a lot of problems for us :grin: Sometimes, you may have to wait a day or two, so you might want to check out ways of restoring your system should an update really mess with things.
CachyOS is definitely a good choice, just be prepared that you need to be willing to delve into things to understand how your OS works, what it is and what it is not. Have fun and don’t hesitate to ask.
Honest question. What are the rules on “necroing" here? Four days hardly feels old on most forums I am a regular on. Heck this thread just popped up in my digest.
No rules as far as I know :slight_smile: maybe I was a bit rash.
