Hi! I’ve came back from holidays today, a small week.
I log into my working desktop, and check a few things.
I do a usual “sudo pacman -Syu” as I’m used to when logging in, and a lot of packages update. CachyOS prompts me to reboot, which I do.
I see the systemd terminal log then… nothing. Black screen. Ctrl+Alt+F3 doesnt give me the usual tty… just nothing.
Not my first arch breaking; so I use my live usb to boot and arch-chroot and pacman -Syu to see if any issues are to be seen.
I have a packagekit gdbus error; okay i remove it. pacman finishes. I reinstall sddm in case with a “pacman -S sddm” and it finished successfully, prompting me that theres a duplicate file already.
Everything seems in order.
Still not booting into SDDM.
Wayland KDE Plasma on a recent OS. NVMe drive with 5800x3D and Nvidia drivers for a 3090.
I had a similar problem. In my case it seemed to be an issue with the newest nvidia driver release (570.124). I was able to boot using integrated graphics. Downgrading to 570.86 resolved the problem.
journalctl -b showed a series of “flip event” errors that end in a failure to provide atomic modeset (error code -22)
additionally; kwin segfaults according to journalctl
and I have constant “fatal library error” whenever using pacman for the slightest thing
sudo pacman -S kwin
warning: kwin-6.3.2.1-2 is up to date – reinstalling
resolving dependencies…
Package (1) Old Version New Version Net Change
cachyos-v3/kwin 6.3.2.1-2 6.3.2.1-2 0.00 MiB
Total Installed Size: 32.89 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [-----------------------------------------------------------------------------] 100%
(1/1) checking package integrity [-----------------------------------------------------------------------------] 100%
(1/1) loading package files [-----------------------------------------------------------------------------] 100%
(1/1) checking for file conflicts [-----------------------------------------------------------------------------] 100%
:: Processing package changes…
(1/1) reinstalling kwin [-----------------------------------------------------------------------------] 100%
:: Running post-transaction hooks…
(1/5) Reloading user manager configuration…
Skipped: Running in chroot.
(2/5) Arming ConditionNeedsUpdate…
(3/5) Updating icon theme caches…
(4/5) Checking which packages need to be rebuilt
fatal library error, lookup self
(5/5) Updating the desktop file MIME type cache…
Unfortunately; I do not have a multi monitor setup. Its a single 3440x1440 screen. I did not remove “cachyos-kde-settings”.
I cannot enter any tty when booting my machine, the alt+F Keys simply do not work and, despite my screen showing its turned on (light up in the dark), the output remains fully black. Which does not enable me to open a tty and enter said command.
In arch-chroot, this is the output of the command.
[root@CachyOS /]# startplasma-wayland
startplasmacompositor: Could not start D-Bus. Can you call qdbus?
hey i had the same problem which occured a week ago that i “fixed” just yesterday, made a post here. my theory is that there was a mesa update that is conflicting with SDDM at the moment, which was NOT updated. this isnt exclusive to arch, it happened on other distro’s for me and others as well! disabling SDDM service (via chroot) and using other DM (e.g. ly) worked for me!
This works but i’m stuck in 1024x768 and without a way to change it in KDE’s options…
❯ sudo lspci -v -s 3d:00.0
[sudo] password for zelie:
3d:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device 87b3
Flags: fast devsel, IRQ 255, IOMMU group 16
Memory at ee000000 (32-bit, non-prefetchable) [size=16M]
Memory at 7000000000 (64-bit, prefetchable) [size=32G]
Memory at 7800000000 (64-bit, prefetchable) [size=32M]
I/O ports at f000 [size=128]
Expansion ROM at ef000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, IntMsgNum 0
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [bb0] Physical Resizable BAR
Capabilities: [c1c] Physical Layer 16.0 GT/s <?>
Capabilities: [d00] Lane Margining at the Receiver
Capabilities: [e00] Data Link Feature <?>
Kernel modules: nouveau
the GPU is in use but doesn’t seem to be.
I reran “sudo pacman -Syu” and the other command sudo pacman -U https://archive.cachyos.org/archive/cachyos-v3/{{,lib32-}{nvidia-utils,opencl-nvidia},nvidia-open-dkms}-570.86.16-2-x86_64_v3.pkg.tar.zst
I, however, decided to just install Arch using ALCI and using the KDE configs provided by CachyOS.
Thanks for the wonderful DE; and I will stop bother you all.
Have a good day.
