Need help to rescue data
Hi.
based at this behavior System freezes i lost some files i need.
What i did:
I moved some files, simple .txt files from a data logger, from a sd card to my pc.
moving was finished and i opend some of the files
my system freezes because of the behavior described at the link above.
Avter shooting down, only posible by hardware reset, and reboot the files i moved before are not in the folder i put it thrue.
I think the files are there because i opend a few of it before but they are not registered.
Do someone know a way to find this files?
I can solve this prob. by using testdisk
