I’ve and this issue on Cachy OS. My issuse is that my computer won’t wake from sleep. My solution was to reboot but had to reboot twict because on the first reboot, I lost wifi. I didn’t have this problem with Ubuntu.
my system is:
Ok, I can’t figure this out and its looks like I’m going down a crazy rabbit hole just to prevent my system from crashing from sleep. I don’t want to have to reset my system twice to use off sleep. Thank you for the help but I’m switching back to ubuntu. the fact out of the box the os has has this glitch of stalling out my system from sleep is crazy. I didn’t alter anything. I followed the basic install nothing crazy, btrfs was recommend. Now system can’t wake up? crazy Thank you for the help.
arch and there forks have mostly some rough edges^^
anyway please test if mkinitcpio is installed, if not the guid from the arch wiki will not work
how to test: pacman -Q mkinitcpio
