If Windows was installed with Secure Boot no it will not boot now. one wqould either rerun Windows or use the one fix out there to make Windows boot again. The latter is not reccommended.
@ptr1337 info on Windows and secure boot is wrong. On top of that Secure Boot and TPM should be off in your bios. Some board have CSM and you want it off as well.
As of July 31st, I just can’t boot on the live ISO and I don’t know why. CSM, SecureBoot and TMP are all disabled. I used BalenaEtcher to flash the USB drive and verified the integrity of the ISO.
I disabled TPM, SecureBoot, CSM and used ventoy. I checked the integrity of the iso. I got to grub, chose an option, the lights on my keyboard and mouse flickered and then lights off and then nothing happenned, waited for ten minutes in case the nvidia driver took more time to load and black screen and the two devices didn’t lights on again.
I have an i7-10700k, 32gb of RAM and a RTX 3060.
I tried with nomodeset, but to no avail. Really bizarre, never had such a problem with any of the live I used so far : Mint, Nobara, etc.
It’s been a long time since I used command in Linux, so can you remind me how to do that? I know that I have to hit the e key to edit the command line, but what do I have to add? Furthermore, how can I provide you logs?
