Won’t start after crash
I am still a Linux beginner and am facing the following problem. Last night, I put my computer into standby mode as usual. This morning, I noticed that the computer had rebooted instead of waking up from standby. However, it didn’t boot up fully but instead went into the emergency console.
I first tried loading the LTS version, but without success. Then I tried loading the last snapshot, but that was also unsuccessful. I checked the journalctl log and found two issues: for one, zram wasn’t generated, and for another, it seems not all kernel files were loaded. Can anyone help me?
Here is the full bug report: fe99c32
I fixed the problem. Reinstalling the kernel helped.
- Create a current CachyOS bootable USB drive and boot the live system from it.
- Change the language to German and set the keyboard layout to German (otherwise, the keys won’t work in the console).
- Open the console and enter
sudo cachy-chroot. - Select the boot partition; set subvolume = y, additional partitions = no, and mountpoint = /boot.
- Update everything and reinstall the kernel:
sudo pacman -Syu,sudo pacman -Syu linux-cachyos linux-cachyos-headers. - Exit and reboot.
