Wired Switch pro controller buttons mapped horribly wrong
Greetings, I recently switched to CachyOS from windows and I’m trying to use my wired switch pro controller. It’s a PDP Gaming Faceoff Deluxe+ Wired Switch Pro Controller and it plugs in and gets detected fine but the issue is the mappings are horribly wrong in settings controller to the point I can’t even remap them in Steam to fix. For example X is mapped on the left bumper, back and start are mapped to the joystick buttons and the physical A & right bumper don’t seem to have any mapping. Lastly and most confusingly is that the right bumper button is mapped to both the triggers being pulled, or at least is the most consistent way of getting it to work, and dpads move the axis but doesn’t show up in the button list (5 and 6 will change numbers but D-pad… button won’t change). My desktop environment is KDE Plasma, and the controller worked fine previously on windows in without needing anything else. Additionally another controller (mayflash fightstick) works fine in xinput mode (only tested mode).
Edit: is there potentially a driver I could be missing? I only downloaded the Meta package since most the applications the second bundle comes with are things I wouldn’t use. Or is there a way to forcibly remap it to fix the misinterpretation of inputs?
I have the exact same problem, have you found any solutions ?
I found this topic on Fedora forums which is similar but there’s way too much tinkering, I’m afraid of breaking something
Not gonna lie more or less forgot about trying to fix it and didn’t see this reply at all until now. Give it another shot, maybe a port issue since I plugged it in just now and its working fine without me having done really anything at all. since then I just resorted to using an xbox or switch pro controller. But I gotta give my thanks for reminding me about it to try it again since its more convenient and I just like the controller better.
