I found this tutorial: How to install Microsoft Office 2007/ 2010/ 2016/ 2021/ 365 or any version on Linux | WxGuy have anyone of you managed to install MS Office using winapps?
You can just follow the guide - its based on archlinux/cachyos.
Basically it does install a docker container with windows, which can be then used as graphical application (personally never tested it, but should maybe work)
