WiFi keeps disconnecting and reconnecting. Taskbar becomes unresponsive
Internet keeps disconnecting on random occasions and when i try to manually turn WiFi off, entire taskbar becomes unresponsive. It takes way too long to shut down the pc and the only option left to turn it off is to force restart. Sometimes the entire pc freezes for a good 15 seconds to respond.
Things I have tried:
  1. set powersave to 2
  2. pcie_aspm = 0
  3. disabling bluetooth
OS: CachyOS x86_64
Host: ASUS TUF Gaming F15 FX506LI_FX566LI (1.0)
Kernel: Linux 7.0.1-1-cachyos
Shell: zsh 5.9
WM: Hyprland 0.54.3 (Wayland)
CPU: Intel(R) Coreā„¢ i5-10300H (8) @ 4.50 GHz
GPU 1: NVIDIA GeForce GTX 1650 Ti Mobile [Discrete]
GPU 2: Intel UHD Graphics @ 1.05 GHz [Integrated]
Memory: 2.43 GiB / 7.59 GiB (32%)
Swap: 0 B / 7.59 GiB (0%)
Disk (/): 11.33 GiB / 474.94 GiB (2%) - btrfs
Network controller [0280]: MEDIATEK Corp. MT7921 802.11ax PCIe Wireless Network
Kernel driver in use: mt7921e
Kernel modules: mt7921e
