**I’m not most linux savvy, so got claude to diagnose my journalctl’s. Here is its summary. (issue is still persistent)
System:**
Distro: CachyOS (Arch-based)
Kernel: 7.1.1-2-cachyos
Desktop: KDE Plasma 6.7.1 (Wayland)
WiFi Card: MediaTek MT7922 (driver: mt7921e)
Motherboard: ASUS ROG STRIX X670E-A GAMING WIFI
NetworkManager version: (check yours with
nmcli --version)
Description:
WiFi connection drops and reconnects approximately every 10 minutes with no user interaction. Issue started approximately one week ago with no deliberate system changes. Ethernet began dropping first, WiFi followed shortly after.
What’s happening:
NetworkManager initiates a roaming handoff between two BSSIDs on the same network (two bands of the same router). The mt7921e driver fails to complete authentication with the target AP, cycling through all 3 attempts before timing out. This triggers a full disconnect/reconnect cycle. On reconnect, NetworkManager negotiates FT-PSK and FT-SAE (Fast Transition) key management, which the router and/or driver appear to handle unreliably, causing the cycle to repeat indefinitely.
Relevant journalctl output:
device (wlan0): link timed out.
device (wlan0): state change: activated -> failed (reason 'ssid-not-found', managed-type: 'full')
device (wlan0): Activation: failed for connection 'BeepBoop'
device (wlan0): Activation: (wifi) access point has security, but secrets are required.
Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
dmesg pattern:
wlan0: disconnect from AP [BSSID-1] for new auth to [BSSID-2]
wlan0: authentication with [BSSID-2] timed out
wlan0: deauthenticated from [BSSID-1] while associating (Reason: 2=PREV_AUTH_NOT_VALID)
What was tried:
Disabled MAC address randomization via
/etc/NetworkManager/conf.d/no-mac-randomization.conf— changed failure reason fromsupplicant-timeouttossid-not-foundbut drops continue -
Locking BSSID to single AP via
nmcli connection modifyresolves the drops as a workaround
Suspected cause:
A recent update to NetworkManager, wpa_supplicant, or linux-firmware appears to have enabled or exposed Fast Transition (802.11r) roaming negotiation on the mt7921e driver. The driver and/or router cannot complete FT handoffs reliably, causing the loop. Issue did not exist prior to approximately June 18, 2026.
Attempted Workaround:
Lock connection to a single BSSID:
bash
nmcli connection modify [SSID] 802-11-wireless.bssid [preferred-AP-MAC]
nmcli connection up [SSID]
