Hey, just installed CachyOS for the first time a day ago - all my previous linux experience is mainly Ubuntu/Debian/Unraid. Never used Arch before.
My main drive is a LUKS2 NVME.
Secondary is a standard SSD, also LUKS2 - both are btrfs.
I’m somewhat used to using fstab for non-encrypted drives but it’s different with an encrypted drive. The primary drive was set up for me so I don’t know what the process was to have the second drive match.
Also, I want to have both encrypted drives securely decrypt if possible - what is the recommended approach for that?
Is this a good route (Lumo AI)?
That error is exactly what we expected. The kernel sees
/dev/sdc1ascrypto_LUKS(an encrypted container), not a filesystem. You can’t mount the container directly; you must unlock it first to reveal the Btrfs filesystem inside, then mount that.Since you want automatic unlocking and mounting on boot, we need two steps:
/etc/crypttab: Tells the system to unlock the drive automatically at boot (using a keyfile or your boot password).
/etc/fstab: Tells the system to mount the unlocked drive.Prerequisite: Create a Keyfile (For True Automation)
To unlock without typing a password at boot, you need a keyfile stored on your encrypted boot drive.
Run this to create the keyfile and add it to your LUKS drive:
sudo mkdir -p /etc/cryptsetup-keys && sudo dd if=/dev/urandom of=/etc/cryptsetup-keys/wdblue.key bs=512 count=1 && sudo chmod 0400 /etc/cryptsetup-keys/wdblue.key && sudo cryptsetup luksAddKey /dev/sdc1 /etc/cryptsetup-keys/wdblue.key(You will be prompted for your current LUKS password to authorize adding the key.)
Step 1: Configure Auto-Unlock (
/etc/crypttab)This tells the system: “At boot, unlock
/dev/sdc1using the keyfile and call itwdblue.”Run this one-liner:
grep -q "wdblue" /etc/crypttab || echo "wdblue /dev/sdc1 /etc/cryptsetup-keys/wdblue.key luks,discard" | sudo tee -a /etc/crypttab
wdblue: The name of the unlocked device (it will appear as/dev/mapper/wdblue).
luks,discard:discardenables TRIM support for your SSD (crucial for performance/lifespan).Step 2: Configure Auto-Mount (
/etc/fstab)This tells the system: “Mount the unlocked device (
/dev/mapper/wdblue) to/mnt/wdblue.”Run this one-liner:
grep -q "/mnt/wdblue" /etc/fstab || echo "/dev/mapper/wdblue /mnt/wdblue btrfs compress=zstd,noatime,x-systemd.automount 0 2" | sudo tee -a /etc/fstabStep 3: Update Boot Image (Critical)
Since the keyfile is on the boot drive, the system needs to know about it before the main OS loads.
Run this:
sudo mkinitcpio -PStep 4: Reload Systemd & Test
Reload systemd to pick up the new fstab/crypttab changes without rebooting immediately:
sudo systemctl daemon-reloadThen test the unlock and mount manually:
sudo cryptsetup open /dev/sdc1 wdblue --key-file /etc/cryptsetup-keys/wdblue.key && sudo mount -a(If you get “Device already exists”, just run
sudo mount -a).Verification
Run
lsblk -f. You should see:
/dev/sdc1(Type:crypto_LUKS)
wdblue(Under/dev/mapper/, Type:btrfs, Mounted at/mnt/wdblue)Now, on the next reboot, the drive will unlock and mount automatically without you typing a password!
