Hi, Iβm new on CachyOs and Linux. few weeks ago I learned that there is a tool called topgrade and it upgrades system much better su by using it I think I changed my mirrorlist and used/upgraded the system like that for a whileβ¦
Then one day I have noticed that I am not on the correct repo and reverted to CachyOs v3 mirrors for my cpu.. then the problems started to arise I donβt have cached old package versions and also I do not have a snapshot state before using topgradeβ¦ What do you guys think is the best approach would be here? I donβt want a messy system that I always ignore some packages..
here is the topgrade command part that I messed up probably (merged mirrors or overwritten them)
ββ 00:31:05 - Configuration update βββββββββββββββββββββββββββββββββββββββββββββ
==> pacnew file found for /etc/pacman.d/mirrorlist
:: (V)iew, (M)erge, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/m/s/r/o/q]
and hereβs the current situation. I tried removing spectacle and reinstalling it but it cannot reinstall it so I reverted back with snapshots
β― sudo pacman -Syyu
[sudo] password for ozu:
:: Synchronising package databases...
cachyos-v3 122.2 KiB 745 KiB/s 00:00 [################################] 100%
cachyos-core-v3 114.9 KiB 684 KiB/s 00:00 [################################] 100%
cachyos-extra-v3 4.3 MiB 6.24 MiB/s 00:01 [################################] 100%
warning: bash: local (5.3.15-1) is newer than cachyos-v3 (5.3.9-2)
warning: ripgrep: local (15.1.0-3) is newer than cachyos-v3 (15.1.0-2)
warning: zstd: local (1.5.7-3) is newer than cachyos-v3 (1.5.7-2)
resolving dependencies...
warning: cannot resolve "qtkeychain-qt6", a dependency of "plasma-nm"
warning: cannot resolve "tessdata", a dependency of "tesseract"
warning: cannot resolve "tesseract-data-osd", a dependency of "tesseract"
warning: cannot resolve "tesseract", a dependency of "spectacle"
:: The following packages cannot be upgraded due to unresolvable dependencies:
plasma-nm spectacle
:: Do you want to skip the above packages for this upgrade? [y/N] y
there is nothing to do
~ 9s
Here iss my mirrorlist now. But I think now it is correct but I messed it up before and upgraded system with that config. Now mirrors are correct but packages are not probably some of them are from v4 repos and they can not update now.. I had no idea about pacnew files I will research it now thank you!
cachyos-v3 is up to date
cachyos-core-v3 is up to date
plasma-nm spectacle
I have those warnings that the current package is newer and I can not upgrade those 2 packages
It is lacking all of the Arch repositories - it was originally guessed this was because of the missing mirrors but it seems the repos are simply not enabled in the pacman configuration file.
Did you βhandleβ more pacnews than just the mirrorlist?
Or recently otherwise touch or configure /etc/pacman.conf?
I might have handled more than one pacnews. I am not sure. and I updated pacman.conf with the current one assuming this is correct. How can I revert the original mirror list ? I can always go back to first snapshot but I want to avoid that since I will lose many things, not just files but also apps and configs of themβ¦
As explained in one of the linked threads on pacnews .. it is rather rare that any pacnew file should either be blindly discarded or blindly used to overwrite the current file. In almost all cases the file should be manually inspected and compared and manually merged as needed.
That is using the v response to pacdiff -s.
( Or DIFFPROG=meld pacdiff -s or using some other comparison tool as needed. )
Then manually applying needed changes before deleting the pacnew.
As suspected .. the Arch repos are missing and we need those.
The bottom of the file should look more like this;
# cachyos repos
[cachyos-v3]
Include = /etc/pacman.d/cachyos-v3-mirrorlist
[cachyos-core-v3]
[cachyos-extra-v3]
[cachyos]
#[core-testing]
# arch repos
[core]
#[extra-testing]
[extra]
# If you want to run 32 bit applications on your x86_64 system,
#[multilib-testing]
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
..following the existing example of no sigs.
My file actually uses SigLevel = PackageRequired on each, ex;
[extra]
but yours does not so I did not include any such lines.
When you have made the requisite changes then please run a full sync/refresh/upgrade again and share the output;
I also added SigLevel = PackageRequired to each of them just to add more security. After that it upgraded all the packages correctly thank you! here is the output;
:: Synchronising package databasesβ¦
cachyos-v3 122.2 KiB 837 KiB/s 00:00 [################################] 100%
cachyos-core-v3 114.9 KiB 751 KiB/s 00:00 [################################] 100%
cachyos-extra-v3 4.3 MiB 6.37 MiB/s 00:01 [################################] 100%
cachyos 513.8 KiB 1954 KiB/s 00:00 [################################] 100%
core is up to date
extra is up to date
multilib is up to date
:: Starting full system upgradeβ¦
warning: mkinitcpio: local (41-4) is newer than cachyos (41-2)
warning: oh-my-zsh-git: local (r7801.5181447da-1) is newer than cachyos (r7425.7ed475cb5-1)
warning: proton-cachyos-slr: local (1:11.0.20260602-3) is newer than cachyos (1:11.0.20260601-1)
warning: rate-mirrors: local (0.29.0-1) is newer than cachyos (0.28.3-2)
warning: zen-browser-bin: local (1.21.3b-1) is newer than cachyos (1.21.1b-1)
warning: zsh-theme-powerlevel10k: local (1:1.20.17-1) is newer than cachyos (1:1.20.15-1)
I assume these warning will fade away by time/upgrades
It seems like some of those may have been upgraded from the AUR or some other source, possibly during the previous misconfiguration, but we should be able to at least get rid of those warning by including an extra u. Heck lets add the extra y too just because they were reconfigured;
sudo pacman -Syyuu
(The extra u allows apparent downgrades so should sync with the repos even if it looks like it would be a lesser version.)
(The extra y forces refresh of the databases - you will notice during this run all of the repos loading on the right even when previously only the ones needing changes did.)
Thank you I donβt know how I did this mess-up but you helped me understand what was wrong and how to deal with it ! Now there are no warnings and every package is up to date within correct repos !
