Hi, for the past few months, i don’t remember exactly when, but whenever i try to boot from suspend, it takes around 3-5 minutes, as just a black screen, before the sddm actually shows. In this time, i can’t input anything, go into a text terminal or use capslock etc. The only grub parameter I have is i8042.nopnp=1. My system is an ideapad 3 15abr8, with a ryzen 5 7530u, 8 gb ram, and integrated graphics. This issue persists in the cachyos linux and lts kernel. This issue only started mattering recently, where the new updates broke my hibernation completely, so i fully deleted my swap. My sleeping is s2idle, and s3 is not supported. here are the error logs shown, when i run journalctl -k -b 0 | grep -i "PM: " -A 20.
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0x09c00000-0x09db0fff]
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0x09f00000-0x09f0cfff]
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0xc2af4000-0xc2be7fff]
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0xc34b9000-0xc34b9fff]
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0xc6a7e000-0xccdfdfff]
May 05 20:17:22 cachyos kernel: PM: hibernation: Registered nosave memory: [mem 0xce000000-0xffffffff]
May 05 20:17:22 cachyos kernel: [gap 0xd0000000-0xf7ffffff] available for PCI devices
May 05 20:17:22 cachyos kernel: Booting paravirtualized kernel on bare hardware
May 05 20:17:22 cachyos kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
May 05 20:17:22 cachyos kernel: Zone ranges:
May 05 20:17:22 cachyos kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
May 05 20:17:22 cachyos kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
May 05 20:17:22 cachyos kernel: Normal [mem 0x0000000100000000-0x00000001ee2fffff]
May 05 20:17:22 cachyos kernel: Device empty
May 05 20:17:22 cachyos kernel: Movable zone start for each node
May 05 20:17:22 cachyos kernel: Early memory node ranges
May 05 20:17:22 cachyos kernel: node 0: [mem 0x0000000000001000-0x000000000009efff]
May 05 20:17:22 cachyos kernel: node 0: [mem 0x0000000000100000-0x0000000009bfffff]
May 05 20:17:22 cachyos kernel: node 0: [mem 0x0000000009db1000-0x0000000009efffff]
May 05 20:17:22 cachyos kernel: node 0: [mem 0x0000000009f0d000-0x00000000c6a7dfff]
May 05 20:17:22 cachyos kernel: node 0: [mem 0x00000000ccdfe000-0x00000000cdffffff]
May 05 20:17:22 cachyos kernel: node 0: [mem 0x0000000100000000-0x00000001ee2fffff]
May 05 20:17:22 cachyos kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000001ee2fffff]
May 05 20:17:22 cachyos kernel: On node 0, zone DMA: 1 pages in unavailable ranges
May 05 20:17:22 cachyos kernel: On node 0, zone DMA: 97 pages in unavailable ranges
May 05 20:17:22 cachyos kernel: On node 0, zone DMA32: 433 pages in unavailable ranges
May 05 20:17:22 cachyos kernel: ACPI: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f0cfff] (53248 bytes)
May 05 20:17:22 cachyos kernel: ACPI: PM: Registering ACPI NVS region [mem 0xcac7e000-0xccd7dfff] (34603008 bytes)
May 05 20:17:22 cachyos kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
May 05 20:17:22 cachyos kernel: posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
May 05 20:17:22 cachyos kernel: futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 KiB, linear).
May 05 20:17:22 cachyos kernel: PM: RTC time: 00:17:21, date: 2026-05-06
May 05 20:17:22 cachyos kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
May 05 20:17:22 cachyos kernel: DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
May 05 20:17:22 cachyos kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
May 05 20:17:22 cachyos kernel: DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
May 05 20:17:22 cachyos kernel: audit: initializing netlink subsys (disabled)
May 05 20:17:22 cachyos kernel: audit: type=2000 audit(1778026641.150:1): state=initialized audit_enabled=0 res=1
May 05 20:17:22 cachyos kernel: thermal_sys: Registered thermal governor 'fair_share'
May 05 20:17:22 cachyos kernel: thermal_sys: Registered thermal governor 'bang_bang'
May 05 20:17:22 cachyos kernel: thermal_sys: Registered thermal governor 'step_wise'
May 05 20:17:22 cachyos kernel: thermal_sys: Registered thermal governor 'user_space'
May 05 20:17:22 cachyos kernel: thermal_sys: Registered thermal governor 'power_allocator'
May 05 20:17:22 cachyos kernel: cpuidle: using governor ladder
May 05 20:17:22 cachyos kernel: cpuidle: using governor menu
May 05 20:17:22 cachyos kernel: efi: Freeing EFI boot services memory: 81840K
May 05 20:17:22 cachyos kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
May 05 20:17:22 cachyos kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
May 05 20:17:22 cachyos kernel: PCI: ECAM [mem 0xf8000000-0xfbffffff] (base 0xf8000000) for domain 0000 [bus 00-3f]
May 05 20:17:22 cachyos kernel: PCI: Using configuration type 1 for base access
May 05 20:17:22 cachyos kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
May 05 20:17:22 cachyos kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
May 05 20:17:22 cachyos kernel: ACPI: PM: (supports S0 S4 S5)
May 05 20:17:22 cachyos kernel: ACPI: Using IOAPIC for interrupt routing
May 05 20:17:22 cachyos kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
May 05 20:17:22 cachyos kernel: PCI: Ignoring E820 reservations for host bridge windows
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GPP4.WLAN.WRST: New power resource
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GPP6.P0NV: New power resource
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GP17.XHC0.P0U0: New power resource
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GP17.XHC0.P3U0: New power resource
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GP17.XHC1.P0U1: New power resource
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GP17.XHC1.P3U1: New power resource
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GP17.XHC1.RHUB.PRT4.BTPR: New power resource
May 05 20:17:22 cachyos kernel: ACPI: \_SB_.PCI0.GP18.P0SA: New power resource
May 05 20:17:22 cachyos kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
May 05 20:17:22 cachyos kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
May 05 20:17:22 cachyos kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug AER LTR DPC]
May 05 20:17:22 cachyos kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
May 05 20:17:22 cachyos kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
May 05 20:17:22 cachyos kernel: acpi PNP0A08:00: [Firmware Info]: ECAM [mem 0xf8000000-0xfbffffff] for domain 0000 [bus 00-3f] only partially covers this bridge
May 05 20:17:22 cachyos kernel: PCI host bridge to bus 0000:00
May 05 20:17:22 cachyos kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000effff window]
May 05 20:17:22 cachyos kernel: pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
May 05 20:17:22 cachyos kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
May 05 20:17:22 cachyos kernel: NET: Registered PF_INET protocol family
May 05 20:17:22 cachyos kernel: IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
May 05 20:17:22 cachyos kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
May 05 20:17:22 cachyos kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
May 05 20:17:22 cachyos kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
May 05 20:17:22 cachyos kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
May 05 20:17:22 cachyos kernel: TCP: Hash tables configured (established 65536 bind 65536)
May 05 20:17:22 cachyos kernel: MPTCP token hash table entries: 8192 (order: 6, 196608 bytes, linear)
May 05 20:17:22 cachyos kernel: UDP hash table entries: 4096 (order: 6, 262144 bytes, linear)
May 05 20:17:22 cachyos kernel: UDP-Lite hash table entries: 4096 (order: 6, 262144 bytes, linear)
May 05 20:17:22 cachyos kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
May 05 20:17:22 cachyos kernel: NET: Registered PF_XDP protocol family
May 05 20:17:22 cachyos kernel: pci 0000:00:02.1: PCI bridge to [bus 01]
May 05 20:17:22 cachyos kernel: pci 0000:00:02.1: bridge window [mem 0xfd500000-0xfd5fffff]
May 05 20:17:22 cachyos kernel: pci 0000:00:02.2: PCI bridge to [bus 02]
May 05 20:17:22 cachyos kernel: pci 0000:00:02.2: bridge window [mem 0x270200000-0x2703fffff 64bit pref]
May 05 20:17:22 cachyos kernel: pci 0000:00:02.4: PCI bridge to [bus 03]
May 05 20:17:22 cachyos kernel: pci 0000:00:02.4: bridge window [mem 0xfd400000-0xfd4fffff]
May 05 20:17:22 cachyos kernel: pci 0000:00:08.1: PCI bridge to [bus 04]
May 05 20:17:22 cachyos kernel: pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
May 05 20:17:22 cachyos kernel: PM: Magic number: 10:160:253
May 05 20:17:22 cachyos kernel: pcie_pme 0000:00:02.2:pcie001: hash matches
May 05 20:17:22 cachyos kernel: RAS: Correctable Errors collector initialized.
May 05 20:17:22 cachyos kernel: Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
May 05 20:17:22 cachyos kernel: clk: Disabling unused clocks
May 05 20:17:22 cachyos kernel: PM: genpd: Disabling unused power domains
May 05 20:17:22 cachyos kernel: Freeing unused decrypted memory: 2028K
May 05 20:17:22 cachyos kernel: Freeing unused kernel image (initmem) memory: 4720K
May 05 20:17:22 cachyos kernel: Write protecting the kernel read-only data: 38912k
May 05 20:17:22 cachyos kernel: Freeing unused kernel image (text/rodata gap) memory: 236K
May 05 20:17:22 cachyos kernel: Freeing unused kernel image (rodata/data gap) memory: 8K
May 05 20:17:22 cachyos kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
May 05 20:17:22 cachyos kernel: rodata_test: all tests were successful
May 05 20:17:22 cachyos kernel: Run /init as init process
May 05 20:17:22 cachyos kernel: with arguments:
May 05 20:17:22 cachyos kernel: /init
May 05 20:17:22 cachyos kernel: with environment:
May 05 20:17:22 cachyos kernel: HOME=/
May 05 20:17:22 cachyos kernel: TERM=linux
May 05 20:17:22 cachyos systemd[1]: Successfully made /usr/ read-only.
May 05 20:17:22 cachyos kernel: usb 3-3: new full-speed USB device number 2 using xhci_hcd
May 05 20:17:22 cachyos kernel: usb 1-3: new high-speed USB device number 2 using xhci_hcd
May 05 20:17:22 cachyos kernel: usb 1-3: New USB device found, idVendor=13d3, idProduct=54b1, bcdDevice=22.08
May 05 20:17:22 cachyos kernel: usb 1-3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
May 05 20:17:22 cachyos kernel: usb 1-3: Product: Integrated Camera
May 05 20:17:22 cachyos kernel: usb 1-3: Manufacturer: Azurewave
May 05 20:17:30 cachyLenovo kernel: PM: Image not found (code -16)
May 05 20:17:31 cachyLenovo kernel: mc: Linux media interface: v0.10
May 05 20:17:31 cachyLenovo kernel: videodev: Linux video capture interface: v2.00
May 05 20:17:31 cachyLenovo kernel: Bluetooth: Core ver 2.22
May 05 20:17:31 cachyLenovo kernel: NET: Registered PF_BLUETOOTH protocol family
May 05 20:17:31 cachyLenovo kernel: Bluetooth: HCI device and connection manager initialized
May 05 20:17:31 cachyLenovo kernel: Bluetooth: HCI socket layer initialized
May 05 20:17:31 cachyLenovo kernel: Bluetooth: L2CAP socket layer initialized
May 05 20:17:31 cachyLenovo kernel: Bluetooth: SCO socket layer initialized
May 05 20:17:31 cachyLenovo kernel: uvcvideo 1-3:1.0: Found UVC 1.00 device Integrated Camera (13d3:54b1)
May 05 20:17:31 cachyLenovo kernel: usbcore: registered new interface driver btusb
May 05 20:17:31 cachyLenovo kernel: Bluetooth: hci0: HW/SW Version: 0x008a008a, Build Time: 20251223091725
May 05 20:17:31 cachyLenovo kernel: usbcore: registered new interface driver uvcvideo
May 05 20:17:31 cachyLenovo kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
May 05 20:17:31 cachyLenovo kernel: Bluetooth: BNEP filters: protocol multicast
May 05 20:17:31 cachyLenovo kernel: Bluetooth: BNEP socket layer initialized
May 05 20:17:31 cachyLenovo kernel: PM: Image not found (code -16)
May 05 20:17:31 cachyLenovo kernel: tlp: vm.laptop_mode is deprecated. Ignoring setting.
May 05 20:17:33 cachyLenovo kernel: Bluetooth: hci0: Device setup in 2595300 usecs
May 05 20:17:33 cachyLenovo kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
May 05 20:17:33 cachyLenovo kernel: Bluetooth: hci0: AOSP extensions version v1.00
May 05 20:17:33 cachyLenovo kernel: Bluetooth: hci0: AOSP quality report is supported
May 05 20:17:33 cachyLenovo kernel: Bluetooth: MGMT ver 1.23
May 05 20:17:33 cachyLenovo kernel: NET: Registered PF_ALG protocol family
May 05 20:17:34 cachyLenovo kernel: wlan0: authenticate with 70:4f:57:da:ef:3a (local address=00:41:0e:ab:50:75)
May 05 20:17:34 cachyLenovo kernel: wlan0: send auth to 70:4f:57:da:ef:3a (try 1/3)
May 05 20:17:34 cachyLenovo kernel: wlan0: send auth to 70:4f:57:da:ef:3a (try 2/3)
May 05 20:17:34 cachyLenovo kernel: wlan0: authenticated
May 05 20:17:34 cachyLenovo kernel: wlan0: associate with 70:4f:57:da:ef:3a (try 1/3)
May 05 20:17:34 cachyLenovo kernel: wlan0: associate with 70:4f:57:da:ef:3a (try 2/3)
May 05 20:17:34 cachyLenovo kernel: wlan0: RX AssocResp from 70:4f:57:da:ef:3a (capab=0x1411 status=0 aid=2)
May 05 20:17:34 cachyLenovo kernel: wlan0: associated
May 05 20:17:35 cachyLenovo kernel: Bluetooth: RFCOMM TTY layer initialized
May 05 20:17:35 cachyLenovo kernel: Bluetooth: RFCOMM socket layer initialized
May 05 20:17:35 cachyLenovo kernel: Bluetooth: RFCOMM ver 1.11
May 05 20:17:35 cachyLenovo kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 70:4f:57:da:ef:3a
May 05 20:17:36 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=10.0.0.65 DST=224.0.0.252 LEN=57 TOS=0x00 PREC=0x00 TTL=255 ID=53593 PROTO=UDP SPT=5355 DPT=5355 LEN=37
May 05 20:18:22 cachyLenovo kernel: PM: Image not found (code -16)
May 05 20:18:23 cachyLenovo kernel: hibernate-prep. (5775): drop_caches: 3
May 05 20:18:23 cachyLenovo kernel: PM: suspend entry (s2idle)
May 05 20:18:23 cachyLenovo kernel: Filesystems sync: 0.011 seconds
May 05 20:18:24 cachyLenovo kernel: Freezing user space processes
May 05 20:18:24 cachyLenovo kernel: Freezing user space processes completed (elapsed 0.001 seconds)
May 05 20:18:24 cachyLenovo kernel: OOM killer disabled.
May 05 20:18:24 cachyLenovo kernel: Freezing remaining freezable tasks
May 05 20:18:24 cachyLenovo kernel: Freezing remaining freezable tasks completed (elapsed 0.000 seconds)
May 05 20:18:24 cachyLenovo kernel: printk: Suspending console(s) (use no_console_suspend to debug)
May 05 20:18:24 cachyLenovo kernel: atkbd serio0: Disabling IRQ1 wakeup source to avoid platform firmware bug
May 05 20:18:24 cachyLenovo kernel: queueing ieee80211 work while going to suspend
May 05 20:18:24 cachyLenovo kernel: ACPI: EC: interrupt blocked
May 05 20:18:24 cachyLenovo kernel: hrtimer: interrupt took 10190784 ns
May 05 20:18:24 cachyLenovo kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SNTM], AE_NOT_FOUND (20251212/psargs-332)
May 05 20:18:24 cachyLenovo kernel: ACPI Error: Aborting method \_SB.PEP._DSM due to previous error (AE_NOT_FOUND) (20251212/psparse-531)
May 05 20:18:24 cachyLenovo kernel: ACPI: EC: interrupt unblocked
May 05 20:18:24 cachyLenovo kernel: amdgpu 0000:04:00.0: [drm] PCIE GART of 1024M enabled.
May 05 20:18:24 cachyLenovo kernel: amdgpu 0000:04:00.0: [drm] PTB located at 0x000000F43FC00000
May 05 20:18:24 cachyLenovo kernel: amdgpu 0000:04:00.0: SMU is resuming...
May 05 20:18:24 cachyLenovo kernel: amdgpu 0000:04:00.0: dpm has been disabled
May 05 20:18:24 cachyLenovo kernel: amdgpu 0000:04:00.0: SMU is resumed successfully!
May 05 20:18:24 cachyLenovo kernel: amdgpu 0000:04:00.0: ring gfx uses VM inv eng 0 on hub 0
May 05 20:18:24 cachyLenovo kernel: PM: suspend exit
May 05 20:18:24 cachyLenovo kernel: tlp: vm.laptop_mode is deprecated. Ignoring setting.
May 05 20:18:25 cachyLenovo kernel: atkbd serio1: keyboard reset failed on isa0060/serio1
May 05 20:19:56 cachyLenovo kernel: wlan0: authenticate with 70:4f:57:da:ef:3a (local address=00:41:0e:ab:50:75)
May 05 20:19:56 cachyLenovo kernel: wlan0: send auth to 70:4f:57:da:ef:3a (try 1/3)
May 05 20:19:56 cachyLenovo kernel: wlan0: authenticated
May 05 20:19:56 cachyLenovo kernel: wlan0: associate with 70:4f:57:da:ef:3a (try 1/3)
May 05 20:19:57 cachyLenovo kernel: wlan0: associate with 70:4f:57:da:ef:3a (try 2/3)
May 05 20:19:57 cachyLenovo kernel: wlan0: RX AssocResp from 70:4f:57:da:ef:3a (capab=0x1411 status=0 aid=2)
May 05 20:19:57 cachyLenovo kernel: wlan0: associated
May 05 20:19:57 cachyLenovo kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 70:4f:57:da:ef:3a
May 05 20:19:58 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=fe80:0000:0000:0000:4712:747c:b8f7:43bc DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=78 TC=0 HOPLIMIT=255 FLOWLBL=203191 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:19:59 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=fe80:0000:0000:0000:4712:747c:b8f7:43bc DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=78 TC=0 HOPLIMIT=255 FLOWLBL=203191 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:19:59 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=10.0.0.65 DST=224.0.0.252 LEN=58 TOS=0x00 PREC=0x00 TTL=255 ID=44538 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:19:59 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=10.0.0.65 DST=224.0.0.252 LEN=58 TOS=0x00 PREC=0x00 TTL=255 ID=44684 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:20:00 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=10.0.0.65 DST=224.0.0.252 LEN=58 TOS=0x00 PREC=0x00 TTL=255 ID=44985 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:23:03 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC=00:41:0e:ab:50:75:68:6c:e6:e8:87:93:08:00 SRC=10.0.0.48 DST=224.0.0.252 LEN=50 TOS=0x00 PREC=0x00 TTL=1 ID=18250 PROTO=UDP SPT=56811 DPT=5355 LEN=30
May 05 20:23:03 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC=33:33:00:01:00:03:68:6c:e6:e8:87:93:86:dd SRC=fe80:0000:0000:0000:3ae8:91ca:4ecd:3d8a DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=70 TC=0 HOPLIMIT=1 FLOWLBL=957709 PROTO=UDP SPT=56811 DPT=5355 LEN=30
May 05 20:23:04 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC=00:41:0e:ab:50:75:68:6c:e6:e8:87:93:08:00 SRC=10.0.0.48 DST=224.0.0.252 LEN=50 TOS=0x00 PREC=0x00 TTL=1 ID=18251 PROTO=UDP SPT=56811 DPT=5355 LEN=30
May 05 20:23:04 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC=33:33:00:01:00:03:68:6c:e6:e8:87:93:86:dd SRC=fe80:0000:0000:0000:3ae8:91ca:4ecd:3d8a DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=70 TC=0 HOPLIMIT=1 FLOWLBL=957709 PROTO=UDP SPT=56811 DPT=5355 LEN=30
May 05 20:32:54 cachyLenovo kernel: PM: Image not found (code -16)
May 05 20:32:54 cachyLenovo kernel: hibernate-prep. (9619): drop_caches: 3
May 05 20:32:54 cachyLenovo kernel: PM: suspend entry (s2idle)
May 05 20:32:54 cachyLenovo kernel: PM: suspend exit
May 05 20:32:54 cachyLenovo kernel: Filesystems sync: 0.017 seconds
May 05 20:32:55 cachyLenovo kernel: Filesystems sync: 0.009 seconds
May 05 20:32:56 cachyLenovo kernel: Freezing user space processes
May 05 20:32:56 cachyLenovo kernel: Freezing user space processes completed (elapsed 0.001 seconds)
May 05 20:32:56 cachyLenovo kernel: OOM killer disabled.
May 05 20:32:56 cachyLenovo kernel: Freezing remaining freezable tasks
May 05 20:32:56 cachyLenovo kernel: Freezing remaining freezable tasks completed (elapsed 0.000 seconds)
May 05 20:32:56 cachyLenovo kernel: printk: Suspending console(s) (use no_console_suspend to debug)
May 05 20:32:56 cachyLenovo kernel: queueing ieee80211 work while going to suspend
May 05 20:32:56 cachyLenovo kernel: amdgpu 0000:04:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
May 05 20:32:56 cachyLenovo kernel: ACPI: EC: interrupt blocked
May 05 20:32:56 cachyLenovo kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.LPCB.EC0.SNTM], AE_NOT_FOUND (20251212/psargs-332)
May 05 20:32:56 cachyLenovo kernel: ACPI Error: Aborting method \_SB.PEP._DSM due to previous error (AE_NOT_FOUND) (20251212/psparse-531)
May 05 20:32:56 cachyLenovo kernel: ACPI: EC: interrupt unblocked
May 05 20:32:56 cachyLenovo kernel: amdgpu 0000:04:00.0: [drm] PCIE GART of 1024M enabled.
May 05 20:32:56 cachyLenovo kernel: amdgpu 0000:04:00.0: [drm] PTB located at 0x000000F43FC00000
May 05 20:32:56 cachyLenovo kernel: amdgpu 0000:04:00.0: SMU is resuming...
May 05 20:32:56 cachyLenovo kernel: amdgpu 0000:04:00.0: dpm has been disabled
May 05 20:32:56 cachyLenovo kernel: amdgpu 0000:04:00.0: SMU is resumed successfully!
May 05 20:32:56 cachyLenovo kernel: nvme nvme0: 12/0/0 default/read/poll queues
May 05 20:32:56 cachyLenovo kernel: PM: suspend exit
May 05 20:32:56 cachyLenovo kernel: tlp: vm.laptop_mode is deprecated. Ignoring setting.
May 05 20:32:57 cachyLenovo kernel: atkbd serio1: keyboard reset failed on isa0060/serio1
May 05 20:34:29 cachyLenovo kernel: wlan0: authenticate with 70:4f:57:da:ef:3a (local address=00:41:0e:ab:50:75)
May 05 20:34:29 cachyLenovo kernel: wlan0: send auth to 70:4f:57:da:ef:3a (try 1/3)
May 05 20:34:29 cachyLenovo kernel: wlan0: authenticated
May 05 20:34:29 cachyLenovo kernel: wlan0: associate with 70:4f:57:da:ef:3a (try 1/3)
May 05 20:34:29 cachyLenovo kernel: wlan0: associate with 70:4f:57:da:ef:3a (try 2/3)
May 05 20:34:29 cachyLenovo kernel: wlan0: RX AssocResp from 70:4f:57:da:ef:3a (capab=0x1411 status=0 aid=2)
May 05 20:34:29 cachyLenovo kernel: wlan0: associated
May 05 20:34:29 cachyLenovo kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 70:4f:57:da:ef:3a
May 05 20:34:31 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=fe80:0000:0000:0000:4712:747c:b8f7:43bc DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=78 TC=0 HOPLIMIT=255 FLOWLBL=203191 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:34:31 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=10.0.0.65 DST=224.0.0.252 LEN=58 TOS=0x00 PREC=0x00 TTL=255 ID=63575 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:34:31 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=10.0.0.65 DST=224.0.0.252 LEN=58 TOS=0x00 PREC=0x00 TTL=255 ID=63663 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:34:32 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=10.0.0.65 DST=224.0.0.252 LEN=58 TOS=0x00 PREC=0x00 TTL=255 ID=63850 PROTO=UDP SPT=5355 DPT=5355 LEN=38
May 05 20:34:38 cachyLenovo kernel: input: keyd virtual keyboard as /devices/virtual/input/input26
May 05 20:34:38 cachyLenovo kernel: input: keyd virtual pointer as /devices/virtual/input/input27
May 05 20:35:02 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC=33:33:00:01:00:03:68:6c:e6:e8:87:93:86:dd SRC=fe80:0000:0000:0000:3ae8:91ca:4ecd:3d8a DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=70 TC=0 HOPLIMIT=1 FLOWLBL=794413 PROTO=UDP SPT=56618 DPT=5355 LEN=30
May 05 20:35:02 cachyLenovo kernel: [UFW BLOCK] IN=wlan0 OUT= MAC=00:41:0e:ab:50:75:68:6c:e6:e8:87:93:08:00 SRC=10.0.0.48 DST=224.0.0.252 LEN=50 TOS=0x00 PREC=0x00 TTL=1 ID=18256 PROTO=UDP SPT=56618 DPT=5355 LEN=30
