Vram usage on Cachy
Hello hello :slight_smile:
A lil’post because I noticed something a little odd. I’ve been using Cachy for a couple weeks now and it’s been an absolute delight :smiley: I barely ever pop Windows on anymore.
But there IS one thing I noticed: on Nvtop I keep an eye on my vram usage, and most times, I’m well above 10-11 Gb when a game is running. I already installed the Cachy gaming packages, as a note ^^
The oddity is that whenever I run the same games, same settings, same areas on Windows? My Vram rarely goes above 8 Gb of usage (at most). Sometimes 9 when in a huge city in a very vast game with a ton of ultra-level textures.
I’m not sure if it comes from the games (tho I tried with multiple), if the paging is more aggressive on Windows 10, if it depends on how the driver is handled, if it’s a question of Proton being more demanding on vram for understandable reasons, …
The question thus is: are there ways, that aren’t included in the base Cachy packages, that’d help optimize vram usage/clearing/paging/something else?
Hallo,
Are you actually using too much, as in running out?
Or it just appears to use more of it in the same scenarios?
This might be something akin to www.linuxatemyram.com
I have run out once! It was a VERY specific case though-- I had Conan Exiles in the background (running on Ultra) with 3 tons of stuff being crafted. Since this takes a while, I typically pop a WoW delve meanwhile. On Windows it works fine, ~10 Gb of vram taken.
On Cachy though… Firefox started crashing repeatedly until I restarted the entire computer :')
The error message mentioned vram, but said error message disappeared after .5 seconds so I could not even copy/paste it.
Now, granted: running two games at the same time is a VEEEERY specific use case. It’s pushing the system a little bit hard, so I acknowledge it’s NOT an emergency issue that should be fixed or disqualifies the distro :slight_smile:
Though regarding the link you sent… ironically: Cachy uses a LOT less system memory/normal ram than Windows does. By such a long shot :slight_smile:
Again: I know this is a very specific case, not at all standard. I just wondered if there was something I could do as a user, or if it’s a “deal with it” case (which is perfectly fine).
The FF example sounds a bit like it could have been regular memory being maxed out.
Maybe combined with certain SWAP/OOM configuration?
Back to the VRAM;
There are potentially some places to look like PStates and/or your power settings .. such as if using power-profiles-daemon and if that is set to anything like “performance”.
Maybe some other things too depending on the gpu.
( We could get system info from sudo cachyos-bugreport.sh )
One extra odd one (for nvidia) might be;
The FF crash happened weeks ago-- ever since, I’ve just started lowering graphics to low on any game that isn’t in the foreground, no issues since. It’s why I’m really insisting this is not a big deal, just a curiosity on my part :slight_smile: I noticed a weird discrepancy and I wonder if it can be addressed or not.
I’m currently on the windows boot (My Cyberpunk 2077 has 300+ mods, it’s the only game I play in Winslop xD). I’ll check all this once I’m back on Cachy! Thanks a ton :smiley:
300 mods and running wow…
If I am not mistaken, what cannot fit into VRAM goes to system RAM as GTT or SMEM. Lack of VRAM doesn’t cause crashes it causes stutter and low FPS. Low system RAM causes crashes. Maybe turn off ZRAM and add a swap partition? Sounds like you don’t have enough system RAM.
If you must have ZRAM, make sure systemd-oomd is enabled. It is required for ZRAM to work correctly. Otherwise your computer will simply hang in the event of a memory leak or when under high memory pressure. You can enable this via CachyOS Hello’s “Apps/Tweaks” tab.
Yeah it’s only 300, seems kind of light IMO :rofl:
Is it actually the game using all that, or is that the total VRAM used?
KDE is a bit frivolous with VRAM usage. plasmashell in particular has a tendency to leak VRAM slowly, and can end up using hundreds of MB after a few days of uptime. Browsers also tend to use it by default.
Running nvidia-smi will give you a breakdown of VRAM usage by process. Although, not all VRAM usage is assigned to a process there. Often, you’ll see the total exceed the sum of listed processes.
It’s not uncommon to see 2+ GB of VRAM usage in KDE, without any games running, which would account for the difference you’re seeing if you’re comparing just the game on Windows with total system VRAM usage on Linux.
On laptops, much of this is often offloaded to the integrated GPU (and therefore RAM instead of VRAM). But, on a typical desktop PC, all of it ends up in VRAM.
Some things you could do to mitigate this:
  • Turn off GPU acceleration in browser settings. It’s not needed for most things.
    • Don’t forget Steam’s builtin browser. It’s in Steam → Settings → Interface.
  • Run systemctl --user restart plasma-plasmashell to restart plasmashell when it gets too leaky.
    • It’s useful to have that on a global shortcut in general, to recover if the desktop or task panel becomes unresponsive
Alright! After a couple days of fiddling around, I made it back!
Here’s the system info o/
I also indeed do have the power profile setting (KDE Plasma) set to “Performance”. Steam is requesting it apparently.
Since a few answers mentioned my use case is a little over the top-- I agree. This is why I didn’t put it in “assistance” :stuck_out_tongue: I’m only curious as to why the Vram usage is so different between the two OS’es and if it can be bettered ^^
Done on removing hardware accel’ from Steam and Firefox, will test and see! Thanks :slight_smile:
The amount of vram used I mentioned was the total, not the individual games.
A pair of interesting updates!
First, I checked with nvidia-smi. The result is… something is odd? It states 826 Mb used, except if I add everything I get barely over 400…
And something else is strange. The same moment nvidia-smi states 800-ish is taken?
Nvtop states 1.2 Gb is used…
I don’t know if nvtop and nvidia-smi count Vram usage differently, and/or which one is more accurate?
