VLC could not decode the format "a52 " (A52 Audio (aka AC3))
I installed CachyOS a couple of days ago.
I’m trying to play back an mkv file I made a couple of years ago using MakeMKV.
I get a “Codec not supported” error, specifically “VLC could not decode the format "a52 " (A52 Audio (aka AC3))”
I have installed vlc-plugins-all but that has not fixed the issue.
Any advice is appreciated.
Try installing a52dec package.
vlc-plugin-a52dec installed?
Yes, latest version 3.0.21-32.1 is already installed.
Additionally, if I open VLC, click on the Tools menu and select “Plugins and extensions” then click on the “Plugins” tab and search for “a52” I can see a plugin called MPEG-I/II/4 / A52 / DTC / MLP audio with the demux Capability and a Score of 155.
is it required that it be played with vlc?
did you try playing it with ffmpeg (through ffplay) or mpv?
mvp won’t open at all, it gives me this error:
mpv: error while loading shared libraries: libSvtAv1Enc.so.4: cannot open shared object file: No such file or directory
Which I think is because of the special version of handbrake I am using to do AV1 encodes.
If I run sudo pacman -S svt-av1 mpv it wants to remove some of that:
:: svt-av1-4.0.1-2 and svt-av1-psy-1:v2.1.0.r0.g5471bd78-3 are in conflict. Remove svt-av1-psy?
The version of this in the repos is very out of date.
Only providing libSvtAv1Enc.so.2 (while svt-av1 provides libSvtAv1Enc.so.4 that most other software is expecting).
I am not sure of what state the AUR version is currently .. but these out of date svt-av1* packages are the source of your problem.
Yes.
And then how do things work?
