Hi guys. First these are my specs: Dell Precisiontower 5810 with Original Motherboard and Powersupply. CPU: Intel Xeon E5-1650 v3 12 @ 3z. GPU: AMD Radeon RX 5600 XT. Monitor is a Philips 272E1GJ. I use latest cachyOS and have my system up to date. My Kernel is Linux 7.0.5-1-cachyos-rt-bore. The issue also arose on regular bore kernel and goes as follows:
At random times the video signal cuts out permanently. As in the only way to get it back is forcing the PC off (technically If I memorized the movements to turn it off via GUI or terminal blindly that would work, as the systems continues to run). There seems not to be an issue with the physical connection, I tried all the DP ports and the HDMI port and also tested a different monitor (LG Flatron) and adjusting the cables didn’t work either excluding a loose connection. I have no settings for automatic standby or anything like it on and the issue sometimes even happend before entering grub. Other than that it usually happened during the first 10 minutes mostly earlier. I have also had sessions running issueless for more than 4-6h. So yeah I’m really at a loss here and couldn’t find anything similar onlines. How can I approach further troubleshooting?
If you feel comfortable with it, you can run sudo cachyos-bugreport.sh and share the link it provides, for people to have more information in order to help you.
I am not familiar with the Dell Precisiontower 5810, but did you upgrade the GPU at some point? I would be a little worried that the integrated PSU is not enough to handle potential upgrades.
can you try to get logs from the previous failed boot?
run something like this after the restart sudo journalctl -b -1 -k | grep -E -i “amdgpu|drm|timeout|ring”
Thanks! I will do it when I find some time (tomorrow prolly) I did upgrade the gpu but checked the power demand and the available output via the PCIe and 8 Pin connector from the powersupply. When I get to the bug report I can run and provide the numbers.
So I checked the numbers again and my GPU is delivered with up to 300W from the PCIe slot and cable from the PSU, my GPU uses around half of that, the setup in total goes around 400W and my PSU deliveres up to 685W. So i think thats fine right?
I assume -3 refers to which log it is and this was the last one that failed or at least it definitely shows errors. I hope it helps.
sudo journalctl -b -3 -k | grep -E -i “amdgpu|drm|timeout|ring”
Mai 16 15:47:38 cachyos kernel: CPU0: Thermal monitoring enabled (TM1)
Mai 16 15:47:38 cachyos kernel: smp: Bringing up secondary CPUs …
Mai 16 15:47:38 cachyos kernel: ACPI: PM: Registering ACPI NVS region [mem 0xca012000-0xcac83fff] (13049856 bytes)
Mai 16 15:47:38 cachyos kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Mai 16 15:47:38 cachyos kernel: Initialise system trusted keyrings
Mai 16 15:47:38 cachyos kernel: integrity: Platform Keyring initialized
Mai 16 15:47:38 cachyos kernel: integrity: Machine keyring initialized
Mai 16 15:47:38 cachyos kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Mai 16 15:47:38 cachyos kernel: ACPI: bus type drm_connector registered
Mai 16 15:47:38 cachyos kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mai 16 15:47:38 cachyos kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mai 16 15:47:38 cachyos kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mai 16 15:47:38 cachyos kernel: simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
Mai 16 15:47:38 cachyos kernel: [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Mai 16 15:47:38 cachyos kernel: fbcon: Deferring console take-over
Mai 16 15:47:38 cachyos kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Mai 16 15:47:38 cachyos kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Mai 16 15:47:38 cachyos kernel: resctrl: L3 monitoring detected
Mai 16 15:47:38 cachyos kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mai 16 15:47:38 cachyos kernel: usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mai 16 15:47:38 cachyos kernel: usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mai 16 15:47:38 cachyos kernel: usb 2-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mai 16 15:47:38 cachyos kernel: usb 2-13: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mai 16 15:47:39 cachyos kernel: usb 2-14: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Mai 16 15:47:42 cachyos kernel: amdgpu: Virtual CRAT table created for CPU
Mai 16 15:47:42 cachyos kernel: amdgpu: Topology: Add CPU node
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: enabling device (0106 → 0107)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: initializing kernel modesetting (NAVI10 0x1002:0x731F 0x1043:0x059F 0xCA).
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: register mmio base: 0xF7B00000
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: register mmio size: 524288
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 0 <common_v1_0_0> (nv_common)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 1 <gmc_v10_0_0> (gmc_v10_0)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 2 <ih_v5_0_0> (navi10_ih)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 3 <psp_v11_0_0> (psp)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 4 <smu_v11_0_0> (smu)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 5 <dce_v1_0_0> (dm)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 6 <gfx_v10_0_0> (gfx_v10_0)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 7 <sdma_v5_0_0> (sdma_v5_0)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 8 <vcn_v2_0_0> (vcn_v2_0)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: detected ip block number 9 <jpeg_v2_0_0> (jpeg_v2_0)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: Fetched VBIOS from VFCT
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [drm] ATOM BIOS: 115-D189P00-100
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: vgaarb: deactivate vga console
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: VRAM: 6128M 0x0000008000000000 - 0x000000817EFFFFFF (6128M used)
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [drm] Detected VRAM RAM=6128M, BAR=256M
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [drm] RAM width 192bits GDDR6
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: 6128M of VRAM memory ready
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: 32107M of GTT memory ready.
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [drm] GART: num cpu pages 131072, num gpu pages 131072
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [drm] PCIE GART of 512M enabled (table at 0x0000008000800000).
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [VCN instance 0] Found VCN firmware Version ENC: 1.24 DEC: 8 VEP: 0 Revision: 9
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: reserve 0x900000 from 0x817d000000 for PSP TMR
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: RAS: optional ras ta ucode is not available
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: RAP: optional rap ta ucode is not available
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: SECUREDISPLAY: optional securedisplay ta ucode is not available
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: use vbios provided pptable
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: smc_dpm_info table revision(format.content): 4.5
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: SMU is initialized successfully!
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [drm] Display Core v3.2.369 initialized on DCN 2.0
Mai 16 15:47:42 cachyos kernel: amdgpu 0000:04:00.0: [drm] DP-HDMI FRL PCON supported
Mai 16 15:47:43 cachyos kernel: amdgpu 0000:04:00.0: kiq ring mec 2 pipe 1 q 0
Mai 16 15:47:43 cachyos kernel: amdgpu 0000:04:00.0: Fence fallback timer expired on ring sdma0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: Fence fallback timer expired on ring sdma0
Mai 16 15:47:44 cachyos kernel: amdgpu: Virtual CRAT table created for GPU
Mai 16 15:47:44 cachyos kernel: amdgpu: Topology: Add GPU node [0x1002:0x731f]
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: SE 2, SH per SE 2, CU per SH 10, active_cu_number 36
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring kiq_0.2.1.0 uses VM inv eng 11 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring sdma0 uses VM inv eng 12 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring sdma1 uses VM inv eng 13 on hub 0
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring vcn_dec uses VM inv eng 0 on hub 8
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring vcn_enc0 uses VM inv eng 1 on hub 8
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring vcn_enc1 uses VM inv eng 4 on hub 8
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: ring jpeg_dec uses VM inv eng 5 on hub 8
Mai 16 15:47:44 cachyos kernel: amdgpu: HMM registered 6128MB device memory
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: Using BACO for runtime pm
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: [drm] Registered 6 planes with drm panic
Mai 16 15:47:44 cachyos kernel: [drm] Initialized amdgpu 3.64.0 for 0000:04:00.0 on minor 1
Mai 16 15:47:44 cachyos kernel: fbcon: amdgpudrmfb (fb0) is primary device
Mai 16 15:47:44 cachyos kernel: amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
Mai 16 15:47:45 DellPT5810 systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
Mai 16 15:47:45 DellPT5810 systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
Mai 16 15:47:46 DellPT5810 kernel: [drm] pre_validate_dsc:1667 MST_DSC dsc precompute is not needed
Mai 16 15:47:47 DellPT5810 kernel: snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
Mai 16 15:49:51 DellPT5810 kernel: snd_hda_intel 0000:04:00.1: CORB reset timeout#2, CORBRP = 65535
Mai 16 15:49:52 DellPT5810 kernel: amdgpu 0000:04:00.0: device lost from bus!
Mai 16 15:49:52 DellPT5810 kernel: amdgpu 0000:04:00.0: SMU: bus error for message: SetWorkloadMask(36) response:0xFFFFFFFF
Mai 16 15:49:52 DellPT5810 kernel: amdgpu 0000:04:00.0: Failed to set workload mask 0x00000003
Mai 16 15:49:52 DellPT5810 kernel: amdgpu 0000:04:00.0: (-121) failed to disable fullscreen 3D power profile mode
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: Dumping IP State
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: Dumping IP State Completed
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm] AMDGPU device coredump file has been created
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: ring gfx_0.0.0 timeout, signaled seq=10914, emitted seq=10916
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: Process plasmashell pid 1546 thread plasmashel:cs0 pid 1565
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: Starting gfx_0.0.0 ring reset
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: Ring gfx_0.0.0 reset failed
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU reset begin!. Source: 1
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: device lost from bus!
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU reset end with ret = -19
Mai 16 15:49:55 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU Recovery Failed: -19
Mai 16 15:50:10 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm] *ERROR* [CRTC:88:crtc-0] flip_done timed out
Mai 16 15:51:39 DellPT5810 kernel: amdgpu 0000:04:00.0: device lost from bus!
Mai 16 15:51:39 DellPT5810 kernel: amdgpu 0000:04:00.0: SMU: bus error for message: GetEnabledSmuFeaturesHigh(13) response:0xFFFFFFFF
Mai 16 15:51:39 DellPT5810 kernel: amdgpu 0000:04:00.0: Failed to retrieve enabled ppfeatures!
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: Dumping IP State
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: Dumping IP State Completed
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm] AMDGPU device coredump file has been created
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm] Check your /sys/class/drm/card1/device/devcoredump/data
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: ring sdma1 timeout, signaled seq=1133, emitted seq=1135
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: Starting sdma1 ring reset
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring kiq_0.2.1.0 test failed (-110)
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring sdma1 test failed (-110)
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: Ring sdma1 reset failed
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU reset begin!. Source: 1
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: device lost from bus!
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU reset end with ret = -19
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU Recovery Failed: -19
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: ring sdma0 timeout, signaled seq=2390, emitted seq=2392
Mai 16 15:51:41 DellPT5810 kernel: amdgpu 0000:04:00.0: Starting sdma0 ring reset
Mai 16 15:51:42 DellPT5810 kernel: amdgpu 0000:04:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring sdma0 test failed (-110)
Mai 16 15:51:42 DellPT5810 kernel: amdgpu 0000:04:00.0: Ring sdma0 reset failed
Mai 16 15:51:42 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU reset begin!. Source: 1
Mai 16 15:51:42 DellPT5810 kernel: amdgpu 0000:04:00.0: device lost from bus!
Mai 16 15:51:42 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU reset end with ret = -19
Mai 16 15:51:42 DellPT5810 kernel: amdgpu 0000:04:00.0: GPU Recovery Failed: -19
Thank you for the clarity, did not make a reassembly but did oncemore plugged out an plugged in the PSU > GPU cable and the last two sessions did not have any trouble. If the problem comes back I will get a new cable and worst case update the thread. Thanks everyone for helping ^^
