Hi! I have a problem that I can’t solve. Dolphin can’t load video previews (images can). As in the picture below I tried to uninstall the packages and reinstall only “ffmpegthumbs” but nothing. How can I solve it? Help! Thanks!
I believe you need kdegraphics-thumbnailers
and ffmpegthumbnailer
. Can you check if both of those are installed?
i had the same problem. In Endevouros the video previews worked fine in Dolphin.
So i took look what is there installed and there is only
kdegraphics-thumbnailers and ffmpegthumbs installed.
I deinstalled ffmpegthumbnailer, rebooted the system and it works just fine!
As soon ffmpegthumbnailer and ffmpegthumbs are both installed video preview stops working.
