I just recently downloaded cachyos on a new ssd. When I set windows only, as a boot manager, it boots up fast, normally and fine. Even with a valve index plugged in, it boots fast, and the index acts normal (it doesn’t show up as an extra display). (the windows boot is on a different ssd). When i change it to use limine as my main boot option (i disable all other settings in bios), it takes a minute and a half to just get to the limine selection menu. And when i use bore it gets stuck in infinite spinning hell. If i choose lts i can login normally, but the index shows up as a normal display.
If i boot from power off, (wait a minute and a half), and then chose windows as my boot, when i go into windows, the index shows up as a third monitor then as well (it does not do this if i choose windows as the main and only boot option in bios).
Normal boot time is 15 seconds MAX from power off to desktop login, so the speed difference is massive.
So my question is, how can i fix the boot so that the valve index doesn’t abysmally slow down boot and make bore hang, and also make the valve index not show up as a third monitor.
Bios:
version: 3112
fast boot: on
csm: off
boot option: (only limine, else is disabled)
kernel:
6.17.7-2 bore
6.12.56-3 lts
specs:
mobo: x670e-e
gpu: 5070
other info:
the OS partitions are on their own respective ssd’s i am not dual booting from the same ssd
my “main“ monitor is hdmi in slot 1
my secondary monitor is dp in slot 1
index is in dp slot 3
