My Shunshine server returns following error while detecting entrypoints for KMS screencast. Anybody can help me?
[2024-11-17 21:10:43.058]: Info: Sunshine version: 0.0.0.dirty
[2024-11-17 21:10:43.058]: Info: Package Publisher: Third Party Publisher
[2024-11-17 21:10:43.058]: Info: Publisher Website:
[2024-11-17 21:10:43.058]: Info: Get support: https://app.lizardbyte.dev/support
[2024-11-17 21:10:43.078]: Info: Found display [wayland-0]
[2024-11-17 21:10:43.078]: Info: Found interface: zxdg_output_manager_v1(31) version 3
[2024-11-17 21:10:43.078]: Info: Found interface: wl_output(72) version 4
[2024-11-17 21:10:43.078]: Warning: Missing Wayland wire for wlr-export-dmabuf
[2024-11-17 21:10:43.078]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:43.081]: Info: Found display [wayland-0]
[2024-11-17 21:10:43.081]: Info: Found interface: zxdg_output_manager_v1(31) version 3
[2024-11-17 21:10:43.081]: Info: Found interface: wl_output(72) version 4
[2024-11-17 21:10:43.081]: Info: Resolution: 1920x1080
[2024-11-17 21:10:43.081]: Info: Offset: 0x0
[2024-11-17 21:10:43.081]: Info: Logical size: 1920x1080
[2024-11-17 21:10:43.081]: Info: Name: DP-1
[2024-11-17 21:10:43.081]: Info: Found monitor: @@@ /0x00000001
[2024-11-17 21:10:43.081]: Info: -------- Start of KMS monitor list --------
[2024-11-17 21:10:43.081]: Info: Monitor 0 is DP-1: @@@ /0x00000001
[2024-11-17 21:10:43.081]: Info: --------- End of KMS monitor list ---------
[2024-11-17 21:10:43.084]: Warning: Gamepad ds5 is disabled due to Permission denied
[2024-11-17 21:10:43.084]: Info: // Testing for available encoders, this may generate errors. You can safely ignore those errors. //
[2024-11-17 21:10:43.084]: Info: Trying encoder [nvenc]
[2024-11-17 21:10:43.084]: Info: Screencasting with KMS
[2024-11-17 21:10:43.084]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:43.089]: Error: Couldn't find monitor [0]
[2024-11-17 21:10:43.092]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:43.092]: Error: Couldn't find monitor [0]
[2024-11-17 21:10:43.132]: Info: System tray created
[2024-11-17 21:10:43.292]: Info: Screencasting with KMS
[2024-11-17 21:10:43.292]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:43.295]: Error: Couldn't find monitor [0]
[2024-11-17 21:10:43.295]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:43.495]: Info: Encoder [nvenc] failed
[2024-11-17 21:10:43.495]: Info: Trying encoder [vaapi]
[2024-11-17 21:10:43.495]: Info: Screencasting with KMS
[2024-11-17 21:10:43.495]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:43.495]: Info: Found monitor for DRM screencasting
[2024-11-17 21:10:43.496]: Info: Found connector ID [116]
[2024-11-17 21:10:43.496]: Info: Found cursor plane [90]
[2024-11-17 21:10:43.508]: Info: Creating encoder [h264_vaapi]
[2024-11-17 21:10:43.509]: Info: Color coding: SDR (Rec. 601)
[2024-11-17 21:10:43.509]: Info: Color depth: 8-bit
[2024-11-17 21:10:43.509]: Info: Color range: JPEG
[2024-11-17 21:10:43.524]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:43.528]: Info: Using normal encoding mode
[2024-11-17 21:10:43.528]: Info: Using default rate control
[2024-11-17 21:10:43.528]: Warning: [h264_vaapi @ 0x5b0f29314e00] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
[2024-11-17 21:10:43.563]: Info: Creating encoder [hevc_vaapi]
[2024-11-17 21:10:43.563]: Info: Color coding: SDR (Rec. 601)
[2024-11-17 21:10:43.563]: Info: Color depth: 8-bit
[2024-11-17 21:10:43.563]: Info: Color range: JPEG
[2024-11-17 21:10:43.578]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:43.581]: Info: Using normal encoding mode
[2024-11-17 21:10:43.581]: Info: Using default rate control
[2024-11-17 21:10:43.581]: Warning: [hevc_vaapi @ 0x5b0f2940a4c0] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
[2024-11-17 21:10:43.611]: Info: Creating encoder [av1_vaapi]
[2024-11-17 21:10:43.612]: Info: Color coding: SDR (Rec. 601)
[2024-11-17 21:10:43.612]: Info: Color depth: 8-bit
[2024-11-17 21:10:43.612]: Info: Color range: JPEG
[2024-11-17 21:10:43.624]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:43.627]: Error: [av1_vaapi @ 0x5b0f29f9b000] No usable encoding entrypoint found for profile VAProfileAV1Profile0 (32).
[2024-11-17 21:10:43.627]: Error: Could not open codec [av1_vaapi]: Function not implemented
[2024-11-17 21:10:43.630]: Info: Screencasting with KMS
[2024-11-17 21:10:43.630]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:43.630]: Info: Found monitor for DRM screencasting
[2024-11-17 21:10:43.630]: Info: Found connector ID [116]
[2024-11-17 21:10:43.631]: Info: Found cursor plane [90]
[2024-11-17 21:10:43.639]: Info: Creating encoder [hevc_vaapi]
[2024-11-17 21:10:43.639]: Info: Color coding: SDR (Rec. 709)
[2024-11-17 21:10:43.639]: Info: Color depth: 10-bit
[2024-11-17 21:10:43.639]: Info: Color range: JPEG
[2024-11-17 21:10:43.653]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:43.656]: Info: Using normal encoding mode
[2024-11-17 21:10:43.656]: Info: Using default rate control
[2024-11-17 21:10:43.656]: Warning: [hevc_vaapi @ 0x5b0f293da0c0] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
[2024-11-17 21:10:43.697]: Info:
[2024-11-17 21:10:43.698]: Info: // Ignore any errors mentioned above, they are not relevant. //
[2024-11-17 21:10:43.698]: Info: Found H.264 encoder: h264_vaapi [vaapi]
[2024-11-17 21:10:43.698]: Info: Found HEVC encoder: hevc_vaapi [vaapi]
[2024-11-17 21:10:43.702]: Info: Configuration UI available at [https://localhost:47990]
[2024-11-17 21:10:43.703]: Info: Adding avahi service Hageri
[2024-11-17 21:10:44.548]: Info: Avahi service Hageri successfully established.
[2024-11-17 21:10:47.100]: Info: // Testing for available encoders, this may generate errors. You can safely ignore those errors. //
[2024-11-17 21:10:47.100]: Info: Trying encoder [nvenc]
[2024-11-17 21:10:47.100]: Info: Screencasting with KMS
[2024-11-17 21:10:47.100]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.103]: Error: Couldn't find monitor [0]
[2024-11-17 21:10:47.103]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.303]: Info: Screencasting with KMS
[2024-11-17 21:10:47.304]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.306]: Error: Couldn't find monitor [0]
[2024-11-17 21:10:47.307]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.307]: Error: Couldn't find monitor [0]
[2024-11-17 21:10:47.507]: Info: Encoder [nvenc] failed
[2024-11-17 21:10:47.507]: Info: Trying encoder [vaapi]
[2024-11-17 21:10:47.507]: Info: Screencasting with KMS
[2024-11-17 21:10:47.507]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.508]: Info: Found monitor for DRM screencasting
[2024-11-17 21:10:47.508]: Info: Found connector ID [116]
[2024-11-17 21:10:47.508]: Info: Found cursor plane [90]
[2024-11-17 21:10:47.517]: Info: Creating encoder [h264_vaapi]
[2024-11-17 21:10:47.517]: Info: Color coding: SDR (Rec. 601)
[2024-11-17 21:10:47.517]: Info: Color depth: 8-bit
[2024-11-17 21:10:47.517]: Info: Color range: JPEG
[2024-11-17 21:10:47.531]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:47.534]: Info: Using normal encoding mode
[2024-11-17 21:10:47.534]: Info: Using default rate control
[2024-11-17 21:10:47.534]: Warning: [h264_vaapi @ 0x778d60039100] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
[2024-11-17 21:10:47.571]: Info: Creating encoder [hevc_vaapi]
[2024-11-17 21:10:47.571]: Info: Color coding: SDR (Rec. 601)
[2024-11-17 21:10:47.571]: Info: Color depth: 8-bit
[2024-11-17 21:10:47.571]: Info: Color range: JPEG
[2024-11-17 21:10:47.587]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:47.589]: Info: Using normal encoding mode
[2024-11-17 21:10:47.589]: Info: Using default rate control
[2024-11-17 21:10:47.589]: Warning: [hevc_vaapi @ 0x778d60035c80] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
[2024-11-17 21:10:47.622]: Info: Creating encoder [av1_vaapi]
[2024-11-17 21:10:47.622]: Info: Color coding: SDR (Rec. 601)
[2024-11-17 21:10:47.622]: Info: Color depth: 8-bit
[2024-11-17 21:10:47.622]: Info: Color range: JPEG
[2024-11-17 21:10:47.634]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:47.637]: Error: [av1_vaapi @ 0x778d60037c40] No usable encoding entrypoint found for profile VAProfileAV1Profile0 (32).
[2024-11-17 21:10:47.637]: Error: Could not open codec [av1_vaapi]: Function not implemented
[2024-11-17 21:10:47.640]: Info: Screencasting with KMS
[2024-11-17 21:10:47.640]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.640]: Info: Found monitor for DRM screencasting
[2024-11-17 21:10:47.640]: Info: Found connector ID [116]
[2024-11-17 21:10:47.641]: Info: Found cursor plane [90]
[2024-11-17 21:10:47.649]: Info: Creating encoder [hevc_vaapi]
[2024-11-17 21:10:47.649]: Info: Color coding: SDR (Rec. 709)
[2024-11-17 21:10:47.649]: Info: Color depth: 10-bit
[2024-11-17 21:10:47.649]: Info: Color range: JPEG
[2024-11-17 21:10:47.664]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:47.666]: Info: Using normal encoding mode
[2024-11-17 21:10:47.666]: Info: Using default rate control
[2024-11-17 21:10:47.666]: Warning: [hevc_vaapi @ 0x778d600e4380] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
[2024-11-17 21:10:47.708]: Info:
[2024-11-17 21:10:47.708]: Info: // Ignore any errors mentioned above, they are not relevant. //
[2024-11-17 21:10:47.708]: Info: Found H.264 encoder: h264_vaapi [vaapi]
[2024-11-17 21:10:47.708]: Info: Found HEVC encoder: hevc_vaapi [vaapi]
[2024-11-17 21:10:47.708]: Info: Executing [Desktop]
[2024-11-17 21:10:47.722]: Info: New streaming session started [active sessions: 1]
[2024-11-17 21:10:47.745]: Info: CLIENT CONNECTED
[2024-11-17 21:10:47.746]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.750]: Info: Found display [wayland-0]
[2024-11-17 21:10:47.750]: Info: Found interface: zxdg_output_manager_v1(31) version 3
[2024-11-17 21:10:47.750]: Info: Found interface: wl_output(72) version 4
[2024-11-17 21:10:47.750]: Info: Resolution: 1920x1080
[2024-11-17 21:10:47.750]: Info: Offset: 0x0
[2024-11-17 21:10:47.750]: Info: Logical size: 1920x1080
[2024-11-17 21:10:47.750]: Info: Name: DP-1
[2024-11-17 21:10:47.750]: Info: Found monitor: @@@ /0x00000001
[2024-11-17 21:10:47.750]: Info: -------- Start of KMS monitor list --------
[2024-11-17 21:10:47.750]: Info: Monitor 0 is DP-1: @@@ /0x00000001
[2024-11-17 21:10:47.750]: Info: --------- End of KMS monitor list ---------
[2024-11-17 21:10:47.750]: Info: Screencasting with KMS
[2024-11-17 21:10:47.750]: Info: /dev/dri/card0 -> amdgpu
[2024-11-17 21:10:47.750]: Info: Found monitor for DRM screencasting
[2024-11-17 21:10:47.751]: Info: Found connector ID [116]
[2024-11-17 21:10:47.751]: Info: Found cursor plane [90]
[2024-11-17 21:10:47.762]: Info: Creating encoder [h264_vaapi]
[2024-11-17 21:10:47.762]: Info: Color coding: SDR (Rec. 601)
[2024-11-17 21:10:47.762]: Info: Color depth: 8-bit
[2024-11-17 21:10:47.762]: Info: Color range: MPEG
[2024-11-17 21:10:47.781]: Info: vaapi vendor: Mesa Gallium driver 24.2.7-cachyos1.2 for AMD Custom GPU 0405 (radeonsi, vangogh, LLVM 18.1.8, DRM 3.59, 6.11.8-2-cachyos-deckify)
[2024-11-17 21:10:47.784]: Info: Using normal encoding mode
[2024-11-17 21:10:47.784]: Info: Using default rate control
[2024-11-17 21:10:47.784]: Warning: [h264_vaapi @ 0x778d300666c0] Driver does not support some wanted packed headers (wanted 0xd, found 0x1).
[2024-11-17 21:10:48.236]: Info: Setting default sink to: [sink-sunshine-stereo]
[2024-11-17 21:10:48.237]: Info: Found default monitor by name: sink-sunshine-stereo.monitor
[2024-11-17 21:10:48.276]: Info: Opus initialized: 48 kHz, 2 channels, 512 kbps (total), LOWDELAY
