Trying to install the pamac GUI and I ran into a version conflict:
loading packages...
resolving dependencies...
:: libpamac-aur-11.7.3-2 and libpamac-full-1:11.7.3-1 are in conflict (libpamac). Remove libpamac-full? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
loading packages...
loading packages...
error: packages failed to build: pamac-aur-11.7.3-1 pamac-all-11.7.3-1
Is this a problem with pamac upstream that needs to be fixed by Manjaro, or is this an issue with the packages maintained in Cachy’s repo? Is there a way to force the installer to ignore libpamac-aur and pamac-aur and only install the -full versions, or is this some weird cross-dependency that can’t be fixed?
I don’t mind using Discover and octopi separately in the meantime but I’d like to have a one-stop shop for both AUR and flatpak.
Fair warning that pamac is perpetually broken - both due to oddities in how it interfaces with ALPM (it does not use pacman as a backend) and oddities in its own ideas about how to parse information. It might also break permissions of its own build directory, etc.
I would suggest to not use pamac at all.
Fair warning not to use discover to manage packages (themes or flatpaks should be alright) - as it would be using packagekit (not ALPM) which is both buggy on Arch/Cachy and opens up system permissions (unsecure).
What command did you use exactly to try to install it?
I’ve been using Manjaro for four days now. Not because I’m convinced, but to either refute or confirm the statements of previous users. The minimal installation with Wayland and my preferred kernel runs perfectly.
But using Manjaro’s Pamac on other distros is just plain stupid.
The problem is, something (I can’t figure out what) is attempting to install both at the same time, and I don’t know why. If it was that easy I wouldn’t be here asking for help.
Alright, then I won’t bother asking for further help, despite the number of people who recommend using pamac in other Arch-based distros as an alternative to the command line.
You have CachyOS Package Installer and Octopi already installed.
If you use Cachy, you have to follow the advice of people who use Cachy and not people who use other distros!
Sadly its one of the “best” in terms of usability - the only problem is that it uses its own pacman backend and we need to patch it to be compatible with cachyos and its opimized repositorys.
Would be another huge project working on a proper gui manager for archlinux
