Hello!
I’ve installed CachyOS on 13th of February so this is a really fresh install. Since then I am unable to run any upgrades. First time around I’ve ended up in emergency mode - root account locked, so I just rolled back. Since yesterday, I’ve been fighting harder. I’ve logged through a live ISO into root, ran the upgrades again, but I’ve still ended up in emergency mode. I rolled back again. Today I tried the upgrade one more time, but now I end up in this situation:
Tray update does not work, hello does not work, -Syu does the same thing, this:
bash -c 'sudo pacman -Sy --needed archlinux-keyring && sudo pacman -Su'
also nothing.
I’ve tried to look into the ncurses since that does seem to be a new issue. I have these if it helps:
Summary
❯ pacman -Qi lib32-ncurses
Installed From : None
Version : 6.5-2
Description : System V Release 4.0 curses emulation library (32-bit)
Architecture : x86_64
URL : NCURSES – New Curses
Licenses : MIT
Groups : None
Provides : libncurses++w.so=6-32 libformw.so=6-32 libmenuw.so=6-32 libpanelw.so=6-32 libncursesw.so=6-32
Depends On : lib32-gcc-libs lib32-glibc ncurses=6.5
Optional Deps : None
Required By : lib32-llvm-libs
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 576,04 KiB
Packager : David Runge dvzrv@archlinux.org
Build Date : ne 11. května 2025, 12:04:20
Install Date : pá 13. února 2026, 22:42:26
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
❯ pacman -Qi lib32-llvm-libs
Version : 1:21.1.6-1
Description : LLVM runtime libraries (32-bit)
URL : https://llvm.org/
Licenses : Apache-2.0 WITH LLVM-exception
Groups : None
Provides : None
Depends On : lib32-gcc-libs lib32-zlib lib32-zstd lib32-libffi lib32-ncurses lib32-libxml2
Required By : lib32-mesa lib32-vulkan-radeon
Optional For : None
Replaces : None
Installed Size : 155,76 MiB
Packager : Leonidas Spyropoulos artafinde@archlinux.org
Build Date : st 19. listopadu 2025, 14:17:05
Install Date : pá 13. února 2026, 22:42:27
Install Script : No
Completely new laptop. Has never been kissed by another operating system. I use Limine.
Summary
OS: CachyOS x86_64
Host: 83LT (Legion Pro 5 16ADR10)
Kernel: Linux 6.19.0-2-cachyos
Uptime: 5 hours, 42 mins
Packages: 1474 (pacman)
Shell: fish 4.4.0
Display (SDC4219): 2560x1600 @ 1.75x in 16", 165 Hz [Built-in]
DE: KDE Plasma 6.6.1
WM: KWin (Wayland)
WM Theme: Breeze
Theme: Breeze (KritaDarker) [Qt], Breeze-Dark [GTK2], Breeze [GTK3/4]
Icons: Papirus-Dark [Qt], Papirus-Dark [GTK2/3/4]
Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
Cursor: Kanada (24px)
Terminal: konsole 25.12.2
CPU: AMD Ryzen 7 8745HX (16) @ 5.15 GHz
GPU 1: NVIDIA GeForce RTX 5060 Max-Q / Mobile [Discrete]
GPU 2: AMD Radeon 610M [Integrated]
Memory: 8.44 GiB / 30.64 GiB (28%)
Swap: 0 B / 30.64 GiB (0%)
Disk (/): 161.81 GiB / 949.77 GiB (17%) - btrfs
My internet somewhat sucks, so I’m used to running rate-mirrors every day. It makes the check and download proceed, but still does not finish.
Refreshing keyrings helped me with the initial installation but now also nothing.
sudo pacman -Sy archlinux-keyring cachyos-keyring
sudo pacman-key --refresh-keys
I can however at least run individual package installs through the package installer.
Note that I have an external hard drive in exFat which I sometimes connect but I run no apps on it.
Is there something else I can try to make it work? I don’t want to give up on Cachy.
Please let me know if I can fetch you some more data if needed.
