Ultrawide monitor support
Hi, newbie here.
I have a C49RG9 Samsung monitor which support 5120x1440 resolution, however it does not appear in Display configuration. The highest available is 3840x1080.
Thank you!
Are you using HDMI 2.x? Do you have an AMD card?
I have a 2080 Ti using DP 1.4
I looked around and ran “xrandr”. The result showed a bunch of different resolutions up to 3840x1080.
“cvt” shows the 5210x1440 though. I found a suggestion on adding a new mode with desired resolution & frequency and applying it, but it resulted in a black screen lol.
Ok, I was able to make it work.
❯ xrandr -q
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected primary 3840x1080+0+0 (normal left inverted right x axis y axis) 1190mm x 340mm
3840x1080 119.97*+ 99.96 59.97
2560x1440 59.99 59.99 59.96 59.95
2560x1080 120.00 119.88 100.00 60.00 59.94
1920x1440 85.00 75.00 60.00
1856x1392 75.00 60.01
1792x1344 75.00 60.01
2048x1152 59.99 59.98 59.90 59.91
1920x1200 59.88 59.95
1920x1080 60.01 120.00 100.00 119.88 59.97 59.96 60.00 60.00 59.94 59.93
1600x1200 85.00 75.00 70.00 65.00 60.00
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 59.99 59.94 59.95 60.00 59.82
1280x1024 85.02 75.02 60.02
1440x900 59.89
1400x900 59.96 59.88
1280x960 85.00 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1152x864 75.00
1280x720 60.00 59.99 59.86 60.00 59.94 59.74
1024x768 85.00 75.05 60.04 85.00 75.03 70.07 60.00
1024x768i 86.96
960x720 85.00 75.00 60.00
928x696 75.00 60.05
896x672 75.05 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
832x624 74.55
960x540 59.96 59.99 59.63 59.82
800x600 85.00 75.00 70.00 65.00 60.00 85.14 72.19 75.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 74.76 59.98
800x450 59.95 59.82
640x512 85.02 75.02 60.02
700x450 59.96 59.88
640x480 85.09 60.00 85.01 75.00 72.81 75.00 66.67 60.00 59.94
720x405 59.51 58.99
720x400 85.04 70.08
684x384 59.88 59.85
640x400 59.88 59.98 85.08
576x432 75.00
640x360 59.86 59.83 59.84 59.32
640x350 85.08
512x384 85.00 75.03 70.07 60.00
512x384i 87.06
512x288 60.00 59.92
416x312 74.66
480x270 59.63 59.82
400x300 85.27 72.19 75.12 60.32 56.34
432x243 59.92 59.57
320x240 85.18 72.81 75.00 60.05
360x202 59.51 59.13
360x200 85.04
320x200 85.27
320x180 59.84 59.32
320x175 85.27
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
❯ cvt -r 5120 1440 120
5120x1440 119.91 Hz (CVT) hsync: 182.86 kHz; pclk: 965.50 MHz
Modeline “5120x1440R” 965.50 5120 5168 5200 5280 1440 1443 1453 1525 +hsync -vsync
❯ xrandr --newmode “5120x1440R” 965.50 5120 5168 5200 5280 1440 1443 1453 1525 +hsync -vsync
❯ xrandr --addmode DP-2 “5120x1440R”
❯ xrandr --output DP-2 --mode “5120x1440R”
I’m not sure why it didn’t work the last couple times I tried to do this.
Found the solution here: https://forums.raspberrypi.com/viewtopic.php?t=257777
