Throttled SSD throughput and Input/Output error on 7.1.1-2 with Samsung 990 Pro
After upgrading from 7.0.12-1 to 7.1.1-2, started seeing very slow throughput on writes and occasional system halts with Input / Output errors on a Samsung 990 Pro. Downgrading the kernel, headers, and nvidia-open back to 7.0.12-1 has fixed the problem, so I don’t need a solution, just reporting a potential regression.
What file system do you have on this drive? Which kernel are you running? Please send the output of inxi -Faz
Filesystem is btrfs with the default subvolume layout; currently running 7.0.12-1-cachyos, the problem was occurring with 7.1.1-2-cachyos; inxi output follows. Again, I am stable on 7.0.12, and I am happy to wait and try the next kernel version, but I thought this might be helpful information.
System:
  Kernel: 7.0.12-1-cachyos arch: x86_64 bits: 64 compiler: clang v: 22.1.6
    clocksource: tsc avail: hpet,acpi_pm parameters: quiet zswap.enabled=0
    nvidia-drm.modeset=1 nvidia.NVreg_EnableGpuFirmware=0 nowatchdog splash
    rw rootflags=subvol=/@ root=UUID=83a1c6cf-3285-46b6-be49-784ecb76ecdc
  Desktop: KDE Plasma v: 6.7.0 tk: Qt v: N/A wm: kwin_wayland with: krunner
    dm: SDDM Distro: CachyOS base: Arch Linux
Machine:
  Type: Desktop Mobo: Micro-Star model: MAG X670E TOMAHAWK WIFI (MS-7E12)
    v: 1.0 serial: <filter> uuid: 9a91797a-a88e-9516-a360-345a603e6ca2
    Firmware: UEFI vendor: American Megatrends LLC. v: 1.K7 date: 10/21/2025
CPU:
  Info: model: AMD Ryzen 9 9900X socket: AM5 bits: 64 type: MT MCP arch: Zen 5
    gen: 5 level: v4 note: check built: 2024+ process: TSMC n4 (4nm)
    family: 0x1A (26) model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
  Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 960 KiB desc: d-12x48 KiB; i-12x32 KiB L2: 12 MiB
    desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3026 min/max: 614/4400 boost: enabled
    base/boost: 4400/5650 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.3 V ext-clock: 100 MHz cores: 1: 3026 2: 3026 3: 3026 4: 3026
    5: 3026 6: 3026 7: 3026 8: 3026 9: 3026 10: 3026 11: 3026 12: 3026
    13: 3026 14: 3026 15: 3026 16: 3026 17: 3026 18: 3026 19: 3026 20: 3026
    21: 3026 22: 3026 23: 3026 24: 3026 bogomips: 211190
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: ghostwrite status: Not affected
  Type: indirect_target_selection status: Not affected
  Type: itlb_multihit status: Not affected
  Type: l1tf status: Not affected
  Type: mds status: Not affected
  Type: meltdown status: Not affected
  Type: mmio_stale_data status: Not affected
  Type: old_microcode status: Not affected
  Type: reg_file_data_sampling status: Not affected
  Type: retbleed status: Not affected
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
    prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
    sanitization
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: srbds status: Not affected
  Type: tsa status: Not affected
  Type: tsx_async_abort status: Not affected
  Type: vmscape mitigation: IBPB on VMEXIT
Graphics:
  Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
    driver: nvidia v: 610.43.02 alternate: nouveau,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: DP-3,DP-4 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:2684 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none empty: DP-5, DP-6, DP-7, HDMI-A-2,
    Writeback-1 bus-ID: 16:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 50.0 C
  Device-3: Logitech Brio 101 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5.3:5
    chip-ID: 046d:094d class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.12 with: Xwayland v: 24.1.12
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting alternate: fbdev,nouveau,nv,vesa dri: radeonsi
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 6560x2560 s-dpi: 96 s-size: 1735x677mm (68.31x26.65")
    s-diag: 1862mm (73.32")
  Monitor-1: DP-3 pos: top-right model: Dell U2715H serial: <filter>
    built: 2014 res: mode: 2560x1440 hz: 60 scale: 177% (0.5625) to: 1440x2560
    dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: max: 2560x1440 min: 640x480
  Monitor-2: DP-4 pos: primary,bottom-l model: LG (GoldStar) ULTRAGEAR+
    serial: <filter> built: 2025 res: mode: 5120x2160 hz: 165 scale: 100% (1)
    dpi: 125 gamma: 1.2 size: 1042x440mm (41.02x17.32") diag: 1131mm (44.5")
    modes: max: 5120x2160 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 610.43.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
    memory: 23.43 GiB
  API: Vulkan v: 1.4.350 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4090 driver: nvidia v: 610.43.02
    device-ID: 10de:2684 surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Ryzen 9 9900X 12-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 26.1.2-arch3.1 device-ID: 1002:13c0 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
    wl: wayland-info x11: xdpyinfo, xprop, xrandr
Audio:
  Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 16:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
    speed: 16 GT/s lanes: 16 bus-ID: 16:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Logitech Brio 101 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k7.0.12-1-cachyos status: kernel-api
  Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
  Server-2: PipeWire v: 1.6.7 status: n/a (root, process) with:
    1: pipewire-pulse status: active 2: wireplumber status: active
    3: pipewire-alsa type: plugin 4: pw-jack type: plugin
    tools: pactl,pw-cat,pw-cli,wpctl
Network:
  Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
    chip-ID: 10ec:8125 class-ID: 0200
  IF: enp6s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlan0 state: down mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
Bluetooth:
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 0e8d:0616
    class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c0104
Drives:
  Local Storage: total: 7.51 TiB used: 2.72 TiB (36.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
    model: MZVL4256HBJD-00BH1 size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: HPS3NHAV temp: 50.9 C scheme: GPT
  SMART: yes health: PASSED on: 74d 9h cycles: 49
    read-units: 709,215 [363 GB] written-units: 1,369,751 [701 GB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 53.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 1y 114d 12h cycles: 130
    read-units: 124,383,459 [63.6 TB] written-units: 143,434,465 [73.4 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWE140 family: X300
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B sata: 3.0
    speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter> fw-rev: FP2A
    temp: 56 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 9y 319d 20h cycles: 484
    Old-Age: g-sense error rate: 123 Pre-Fail: reallocated sector: 100
    threshold: 50
Partition:
  ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 1.92 TiB (52.8%)
    fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2
  ID-2: /boot raw-size: 2 GiB size: 2 GiB (99.80%) used: 1.29 GiB (64.8%)
    fs: vfat block-size: 512 B dev: /dev/nvme1n1p1 maj-min: 259:1
  ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 1.92 TiB (52.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
    maj-min: 259:2
  ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    maj-min: 259:2
  ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    maj-min: 259:2
Swap:
  Kernel: swappiness: 150 (default 60) cache-pressure: 50 (default 100)
    zswap: no
  ID-1: swap-1 type: zram size: 60.42 GiB used: 5 MiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
Sensors:
  System Temperatures: cpu: 52.9 C mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 64 GiB note: est. available: 60.42 GiB
    used: 10.18 GiB (16.8%)
  Processes: 579 Power: uptime: 1h 38m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 24.02 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Packages: 1853 pm: pacman pkgs: 1847 libs: 427 tools: octopi,paru
    pm: flatpak pkgs: 6 Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Sudo (sudo)
    v: 1.9.17p2 default: Bash v: 5.3.9 running-in: konsole inxi: 3.3.40
You may have encountered a regression in Btrfs. I actually updated my NAS server to kernel 7.1 just yesterday, and it has been working perfectly ever since and continues to do so. I haven’t noticed any regressions in read/write speeds. But I’m running bcachefs on it. Try the linux-cachyos-server kernel just in case—there’s a very small chance that the regression might be due to incompatibility with cachyos-specific things.
inxi -Faz
System:
  Kernel: 7.1.1-1-cachyos-server arch: x86_64 bits: 64 compiler: gcc v: 16.1.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/vmlinuz-linux-cachyos-server
    root=UUID=a39ffc01-e285-4b05-933a-fc9a6e0dd747 rootfstype=bcachefs rootwait rw
  Console: pty pts/5 DM: SDDM Distro: Arch Linux
Machine:
  Type: Server Mobo: Supermicro model: X8DTL v: 1234567890 serial: <superuser required>
    uuid: <superuser required> Firmware: BIOS vendor: American Megatrends v: 2.1b date: 11/16/2012
CPU:
  Info: model: Intel Xeon X5650 bits: 64 type: MT MCP SMP arch: Nehalem level: v2 built: 2008-10
    process: Intel 45nm family: 6 model-id: 0x2C (44) stepping: 2 microcode: 0x15
  Topology: cpus: 2x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
    L1: 2x 384 KiB (768 KiB) desc: d-6x32 KiB; i-6x32 KiB L2: 2x 1.5 MiB (3 MiB) desc: 6x256 KiB
    L3: 2x 12 MiB (24 MiB) desc: 1x12 MiB
  Speed (MHz): avg: 1708 high: 1817 min/max: 1600/2668 boost: enabled scaling:
    driver: acpi-cpufreq governor: performance cores: 1: 1600 2: 1600 3: 1600 4: 1600 5: 1600
    6: 1600 7: 1817 8: 1817 9: 1817 10: 1817 11: 1817 12: 1817 13: 1600 14: 1600 15: 1600 16: 1600
    17: 1600 18: 1600 19: 1817 20: 1817 21: 1817 22: 1817 23: 1817 24: 1817 bogomips: 128057
  Flags-basic: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Vulnerabilities:
  Type: itlb_multihit status: KVM: Split huge pages
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
  Type: meltdown mitigation: PTI
  Type: old_microcode status: Vulnerable
  Type: spec_rstack_overflow status: Not affected
  Type: spec_store_bypass status: Vulnerable
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling; PBRSB-eIBRS: Not
    affected; BHI: Not affected
  Type: vmscape status: Not affected
Graphics:
  Device-1: NVIDIA GF100GL [Quadro 4000] vendor: Hewlett-Packard driver: nouveau v: kernel
    non-free: series: 390.xx+ status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
    xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: lanes: 16 ports: active: DVI-I-1 empty: DP-1,DP-2
    bus-ID: 03:00.0 chip-ID: 10de:06dd class-ID: 0300 temp: 56.0 C
  Device-2: Matrox Systems MGA G200eW WPCM450 vendor: Super Micro driver: mgag200 v: kernel
    ports: active: none off: VGA-1 empty: none bus-ID: 08:01.0 chip-ID: 102b:0532 class-ID: 0300
  Display: unspecified server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
    compositor: kwin_wayland driver: gpu: mgag200,nouveau tty: 230x72
  Monitor-1: DVI-I-1 model: PiKVM V3 serial: <filter> built: 2016 res: 1280x720 dpi: 62
    gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes: max: 1280x720
    min: 640x480
  Monitor-2: VGA-1 size-res: N/A in console modes: max: 1024x768 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau device: 1
    drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland: drv: nouveau inactive: x11
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 26.1.2-arch2.1 note: console (EGL sourced)
    renderer: NVC0, llvmpipe (LLVM 22.1.6 128 bits)
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: cpu name: llvmpipe (LLVM 22.1.6 128 bits)
    driver: mesa llvmpipe v: 26.1.2-arch2.1 (LLVM 22.1.6) device-ID: 10005:0000 surfaces: N/A
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
    wl: wayland-info x11: xdpyinfo,xprop
Audio:
  Device-1: NVIDIA GF100 High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 03:00.1
    chip-ID: 10de:0be5 class-ID: 0403
  API: ALSA v: k7.1.1-1-cachyos-server status: kernel-api tools: N/A
  Server-2: JACK v: 1.9.22 status: off tools: N/A
  Server-3: PipeWire v: 1.6.7 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Network:
  Device-1: Intel 82574L Gigabit Network vendor: Super Micro driver: e1000e v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: dc00 bus-ID: 06:00.0 chip-ID: 8086:10d3 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  Device-2: Intel 82574L Gigabit Network vendor: Super Micro driver: e1000e v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: ec00 bus-ID: 07:00.0 chip-ID: 8086:10d3 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Info: services: NetworkManager,sshd
Drives:
  Local Storage: total: 29.11 TiB used: 2.79 TiB (9.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: DT 101 G2 size: 3.73 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
    serial: <filter> fw-rev: PMAP scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
  SMART Message: Unable to run smartctl. Root privileges required.
  ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB block-size:
    physical: 4096 B logical: 512 B tech: N/A serial: <filter> fw-rev: C907
  ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB block-size:
  ID-4: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB block-size:
  ID-5: /dev/sde maj-min: 8:64 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB block-size:
  ID-6: /dev/sdf maj-min: 8:80 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB block-size:
  ID-7: /dev/sdg maj-min: 8:96 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB block-size:
  ID-8: /dev/sdh maj-min: 8:112 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB
    block-size: physical: 4096 B logical: 512 B tech: N/A serial: <filter> fw-rev: C907
  ID-9: /dev/sdi maj-min: 8:128 vendor: Hitachi model: HUS726040AL5214 size: 3.64 TiB
Partition:
  ID-1: / raw-size: 3.64 TiB size: 26.72 TiB (734.28%) used: 2.79 TiB (10.4%) fs: bcachefs
    dev: /dev/sdi maj-min: 8:128
  ID-2: /boot raw-size: 3.71 GiB size: 3.71 GiB (100.00%) used: 486.9 MiB (12.8%) fs: btrfs
    dev: /dev/dm-0 maj-min: 252:0 mapped: cryptoboot
Swap:
  Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes compressor: zstd
    max-pool: 20%
  ID-1: swap-1 type: zram size: 15.68 GiB used: 418 MiB (2.6%) priority: 100 comp: zstd
  ID-2: swap-2 type: zram size: 15.68 GiB used: 407.1 MiB (2.5%) priority: 100 comp: zstd
    avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram1
Sensors:
  System Temperatures: cpu: 69.5 C mobo: N/A gpu: nouveau temp: 57.0 C
  Fan Speeds (rpm): N/A gpu: nouveau fan: 2700
Info:
  Memory: total: 32 GiB available: 31.37 GiB used: 6.05 GiB (19.3%)
  Processes: 489 Power: uptime: 1d 12h 23m states: freeze,standby,mem,disk suspend: s2idle
    avail: shallow wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume
    image: 12.49 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Packages: 1144 pm: pacman pkgs: 1081 libs: 233 tools: paru pm: flatpak pkgs: 63 Compilers:
    clang: 22.1.6 gcc: 16.1.1 Shell: fish v: 4.7.1 running-in: pty pts/5 (SSH) inxi: 3.3.40
Entirely possible, I’ll give that a shot. Thanks
