The system is not upgrading
when i trying to do sudo pacman -Syu it’s showing me:
 cachyos-v3 is up to date
 cachyos-core-v3 is up to date
 cachyos is up to date
 core is up to date
 extra is up to date
 multilib is up to date
and then it’s just freezes without any signs of errors. I waited about 15 min and it doesn’t help at all. However pacman is still working, i can download programms with sudo pacman -Sy.
Hello and welcome,
You are performing partial-upgrades?
Stop doing that - it can cause varying degrees of breakage.
( System maintenance - ArchWiki )
Maybe we can see if any pacman process is still running?
ps aux | grep pacman
We will probably want to make sure all examples are closed.
If in doubt I suppose we would say restart your session but if it is in a partial-upgrade state that could be slightly hazardous.
Maybe we will get more if pacman is run with verbose flag?
sudo pacman -Syuv
Oh i didn’t know that i shouldn’t perform partial upgrades. Thank you, now i only using cachy-update and it works well.
