It seems that the gaming packages ( from cachyos-hello ) has some bugs and issues. and I couldn’t upload the images of the bugs to the website, so I’m going to upload them to Element instead. Additionally, I couldn’t find Wine, and it appears that Winetricks is not working.
Install the cachyos-gaming-meta package:
sudo pacman -S cachyos-gaming-meta
Afaik, it installs wine-staging (and everything else for gaming, including proton-cachyos, steam, lutris, etc…)
To easily find wine, open octopi (it’s in the system menu) and search for it.
edit: winetricks is working fine for me.
There is a button in cachyos hello that install the gaming packages in the past it also install bottles when you press it including wine lutris and many more , bottles got removed because it have some bugs , and currently winetricks have issue openning and couldnt find wine
i know that in a fresh install i could install lutris wine etc by myself without pushing that button ( gaming packages ) but i thought it also be great if dev see what is wrong, or am the only one facing this issue !
Also yestrday i installed cachyos so its new fresh install
I always use this after I’ve installed and tweaked everything else I want on the system. Replace pikaur with yay or paru or whichever AUR helper you prefer.
sudo pikaur -Sy wine-staging wine-mono wine-gecko
pikaur -S giflib lib32-giflib libldap lib32-libldap gnutls lib32-gnutls v4l-utils lib32-v4l-utils libpulse lib32-libpulse alsa-plugins lib32-alsa-plugins alsa-lib lib32-alsa-lib libxcomposite lib32-libxcomposite libxinerama lib32-libxinerama opencl-icd-loader lib32-opencl-icd-loader gst-plugins-base-libs lib32-gst-plugins-base-libs sdl2 lib32-sdl2 libgphoto2 sane cups samba dosbox
Thank you i will try it next time
Yes, and above I just gave you the command to manually enter on the terminal to do this, so that you could see if it works and also easily copy/paste any errors here as you were also having problems with reporting the errors with the other method.
So I see you running around in circles instead of doing what would be moving forward with your problem?
