great job - worked very well
from where du u got them, Octopi shows still only until 560xx
Run an update. sudo pacman -Syu
No Change
⯠sudo pacman -Syu
[sudo] Mot de passe de franck :
:: Synchronisation des bases de donnĂ©es de paquetsâŠ
cachyos-v3 est Ă jour
cachyos-core-v3 est Ă jour
cachyos-extra-v3 est Ă jour
cachyos est Ă jour
core-testing est Ă jour
core est Ă jour
extra-testing est Ă jour
extra 7,5 MiB 340 KiB/s 00:23 [-----------------------------------------------------] 100%
multilib-testing est Ă jour
multilib est Ă jour
:: DĂ©but de la mise Ă jour complĂšte du systĂšmeâŠ
Maybe it hasnât reacher your local mirror yet. Just wait then.
ok, with mirror u use ?
my /etc/pacman.d/mirrorlist looks good , no ?
FINISHED AT: 2024-09-23 17:56:05.106756387 +02:00
Server = https://mirror.lesviallon.fr/cachy/repo/$arch/$repo
Server = https://mirror.cachyos.org/repo/$arch/$repo
Server = https://cdn77.cachyos.org/repo/$arch/$repo
Server = https://cdn.cachyos.org/repo/$arch/$repo
Server = https://mirrors.tuna.tsinghua.edu.cn/cachyos/repo/$arch/$repo
Server = https://cdn-1.cachyos.org/$arch/$repo
Server = https://aur.cachyos.org/repo/$arch/$repo
Server = https://no.mirror.cx/cachyos/repo/$arch/$repo
Server = https://us.cachyos.org/repo/$arch/$repo
Server = https://mir.cachyos.fr/repo/$arch/$repo
Server = https://mirror.truenetwork.ru/cachy/repo/$arch/$repo
The CDN. https://cdn-1.cachyos.org/$arch/$repo
is my top ranked mirror.
Update: In France now to avaiable with local Mirror
We have mainly pushed it because there a security issues in 560 and there wont come from NVIDIA a security release, outside of 565.
See:
âCVEâ2024â0126 - âNVIDIA GPU Display Driver for Windows and Linux contains a vulnerability which could allow a privileged attacker to escalate permissions. A successful exploit of this vulnerability might lead to code execution, denial of service, escalation of privileges, information disclosure, and data tampering.â If youâre on driver versions 565.57.01, 550.127.05, 535.216.01 or later youâre secure. Otherwise, you should probably go and update. So that explains the tiny one-liner update I covered for the 550.127.05 release yesterday along with the 565.57.01 Beta that was also released at the same time.â
Hi guys,
is it possible that there is some kind of dependency mismatch? I try to install
sudo pacman -S linux-cachyos-headers linux-cachyos-nvidia-open nvidia-utils lib32-nvidia-utils nvidia-settings
And everytime I get
UnerfĂŒllbare AbhĂ€ngigkeit »nvidia-utils=560.35.03«, benötigt von lib32-nvidia-utils
And I completely uninstalled those packages before reinstalling themâŠ
sync your mirrors.
Sorry my bad. After adding cachyos-v3/ in front of all packages erverything installed fineđ
Looks like this driver has issues resuming from sleep. Is anyone else experiencing a black screen when they try to resume?
I have that issue, but it started in the last Nvidia driver release I think. Need to check what version in running
Unfortunately, the version is very buggy. A few DX12 games that I tried are unplayable due to âvertex explosionâ issue. Oh, well⊠nVidia doing nVidia thing
Yes, we know. But we wont keep our users vulernable, and downgrading to version 550 would be even worse, due missing a lot of features.
