systemd-resolved and avahi-daemon both enabled and running simultaneously. I did not enabled them. It is fresh OOB experience after installation with refind+kde+printer support+hp printer support options selected.
Kindly enlighten me which one should I disable and expect what side effects?
(I posted this sometimes ago, but perhaps due to the length of the post or due to ambiguity in question, nobody responded. I don’t have permission to delete that question now, hence this post.)
Arch documentation on systemd-resolved categorically mentions to disable avahi-daemon if it is used. There seems to some overlap on the mDNS job.
I understd that Arch documentation is for general case, and here in CachyOS things can be different because of the way things has been assembled/configured.
We can do a logical closure of this issue if you can reconfirm.
