System update script
I just noticed that AUR support got removed from the system update script, or do I have a false memory and it was never supported in the first place? Anyway, it would be convenient if the script would handle AUR and also Flatpak updates.
We have never supported AUR with the update system button in cachyos-hello.
You can update AUR packages with “paru” in the terminal.
that happened due to paru being removed from the match which “package manager” will be used.
you can install yay or aura, in that case regular packages and AUR should be updated
So the system update script was using paru and therefore AUR updates were included? Makes sense and I might as well use paru, however, updating via the system update button would be a lot more attractive if it would handle all the packages and also prompts users to deal with .pacnew files. Like arch-update, a one-stop shop for updates.
