When I reboot the system hangs at the first line for 2.5 minutes and I do not understand why. I will attach an image of the issue. Any help would be appreciated. I do not even know where to start on this one.
can you boot on USB iso live cachyos
open a terminal an provide
inxi -Fza
is this coming just after update ?
Absolutely. No, fresh install. I should add I am using the rEFInd boot manager.
I just tried booting to my live USB install and the boot manager loaded and chose cachy os and it booted to a black screen. This can not be run from my normal desktop?
can you try to open a TTY ?
press Ctrl + Alt + PFkeys ( number 2 to 8 )
Where do I do that? Ctrl + Alt + PFkeys ( number 2 to 8 )? Not sure I understand.
have you still a black screen ?
a TTY ( console ) can be open by press Ctrl + Alt + PFKn ( number 3 to 6 )
if not , reboot on USB iso Cachyos ,
open a terminal
do a chroot , an then send report
sudo cachos-chroot
sudo cachyos-bugreport.sh
see
and
I can boot to my cachy desktop. This is what I get from my terminal.
you try to connect to KDE with wayland ? , not X11 ?
check in your journalctl
sudo journalctl -b0
For TTY it must be Ctrl + ALt + F3 until Ctrl + ALt + F6.
Ctrl + ALt + F1 is your workspace.
Ctrl + ALt + F2 show the login screen (no function possible).
So far on my notebook. (Tks SGS)
Pretty sure it is wayland.
Dec 22 13:42:53 cachyosBTW kernel: Linux version 6.12.6-2-cachyos (linux-cachyos@cachyos) (clang version 18.1.8, LLD 18.1.8) #1 SMP PREEMPT_DYNAMIC Thu, >
Dec 22 13:42:53 cachyosBTW kernel: Command line: quiet zswap.enabled=0 nowatchdog splash rw rootflags=subvol=/@ root=UUID=62643a8b-9362-44f0-a367-ffa9fdd>
Dec 22 13:42:53 cachyosBTW kernel: BIOS-provided physical RAM map:
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009d81fff] usable
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x0000000009d82000-0x0000000009ffffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20dfff] ACPI NVS
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x000000000a20e000-0x00000000daccefff] usable
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000daccf000-0x00000000db04efff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000db04f000-0x00000000db0b2fff] ACPI data
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000db0b3000-0x00000000dcbb2fff] ACPI NVS
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000dcbb3000-0x00000000ddbfefff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000ddbff000-0x00000000deffffff] usable
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fd400000-0x00000000fd5fffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x0000000100000000-0x000000081f37ffff] usable
Dec 22 13:42:53 cachyosBTW kernel: BIOS-e820: [mem 0x000000081f380000-0x000000081fffffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: NX (Execute Disable) protection: active
Dec 22 13:42:53 cachyosBTW kernel: APIC: Static calls initialized
Dec 22 13:42:53 cachyosBTW kernel: e820: update [mem 0xd6859018-0xd6868057] usable ==> usable
Dec 22 13:42:53 cachyosBTW kernel: e820: update [mem 0xd67c7018-0xd67d4857] usable ==> usable
Dec 22 13:42:53 cachyosBTW kernel: e820: update [mem 0xd67a0018-0xd67c6457] usable ==> usable
Dec 22 13:42:53 cachyosBTW kernel: extended physical RAM map:
Dec 22 13:42:53 cachyosBTW kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
Dec 22 13:42:53 cachyosBTW kernel: reserve setup_data: [mem 0x00000000000a0000-0x00000000000fffff] reserved
Dec 22 13:42:53 cachyosBTW kernel: reserve setup_data: [mem 0x0000000000100000-0x0000000009d81fff] usable
can you please report bug ?
I just put that in the terminal and I think it just sent a log.
I have narrowed it down to the issue possibly being in the refind_linux.conf file. At least that is where the system hangs up. It does eventually boot into CachyOS but it just takes a long time. I even tried doing a new install and it does the same thing at the same file. I would love to get to the bottom of this.
you need to share that link the bugreport script generates.
Thank you. I will do that when I get home.
something go wrong at least 5 points :
- trouble between wifi 7 and keyboard K95
- trouble on egl / kwindows that ends in time out
- some screen boot display that are not recognized ( .svg ) / kwindows
- errors on version profile version 5 & 6 ( qt ? )
- error on some functions windows that only works in x11 …
I do not have anything with WIFI 7. I do have a K95 keyboard. The rest of it I have no idea. Any advice?
Thanks for the help.
