Try with -5 or -6.
I just tried -5 with color profile None. It took longer, but did lock up. Do you want me to try another version?
Yeah, with the other versions up to 8 please.
Iāve also pushed -9 in case all the other versions also lock up.
Versions 5-8 all lockup with Color profile set to None. FYI, I havenāt had the version from the extra repo lockup yet. When I switch back to it I can test it some more.
Ah, just saw this. Gimme a minute and Iāll test -9.
No luck with -9.
Yeah, itās an upstream Kwin bug I guess. -9 is identical to Archās package except it was built with v3 and -O3. Let me know if you can reproduce the lockup with Archās package. Thanks.
If you canāt, Iāll do a build without compiler optimizations and see.
I donāt know if it helps, but I get the feeling that it happens when:
- You have a window at the top of the screen
- Click on the title bar and immediately try to drag up
At least thatās what Iāve noticed a few times during testing. It may not be definitive.
Hey @naim
I havenāt been able to reproduce the lockup with Archās package. Iāll keep trying, but maybe itās a compiler optimization bug. Let me know when youāve got a build without compiler optimizations that youāre ready for me to test.
Sure thing, Iām building a kernel right now but I can build Kwin later. Thanks.
-10 is up, please try
-10 locks up. BTW, the -3 kwin package from the extra repo still hasnāt locked up.
What about -11 from Nginx Directory
@naim A quick question before I try -11.
I just upgraded my system except for kwin. I now notice that the extra repo no longer has -3 but -5 in it. So I assume after testing -11, I wonāt be able to go back to -3 if the new -5 hangs?
-5 from extra shouldnāt hang.
-11 hung a couple of times, but it felt like it took more fidgeting with windows to get it to hang. Of course, it may have just been random.
After testing -11, I installed 6.3.0-5 from extra/kwin. Itās hanging now. Interestingly, Octopi is showing that both extra/kwin and cachyos-v3/kwin are installed. Can I safely uninstall the -v3/kwin from Octopi?
I donāt think thatās true. Itās just parsing the version, which is the same for both. pacman -Qi kwin
will show u which one is installed.
-12 is up, please try, thanks!
