Hello guys, I’m pretty new to linux & cachyos. I was on Linux Mint for a month and recently hopped on cachy.
I have a weird issue when shutting down the system, the screen goes black as expected, but the machine never actually powers off:
- Briefly, the motherboard’s POST logo flashes on screen (as if rebooting or starting), then the screen goes permanently black
- Fans keep spinning at normal speed (not panic/full speed)
- Power button LED and WIFI card stays lit
- Keyboard stays responsive (Num Lock toggles)
- The system then sits indefinitely in this state — no display output, fans running, until a hard power-off (long press) is performed
This happens on most of my shutdowns. Sometimes, it doesn’t happen. Not sure why.
Maybe I’m wrong, but it looks like the system is rebooting somehow (since the motherboard logo show up briefly), but never really goes on, and stays on that black screen.
What I tried:
- ACPI:
acpi=forceandreboot=acpi/reboot=bioskernel parameters — no change - ErP Ready (S5) enabled in BIOS — no change
- Fast Boot disabled in BIOS — no change
- GPU runtime power management:
amdgpu.runpm=0andamdgpu.bapm=0— no change - Wake-on-WLAN: confirmed not the cause (
rfkill block wifibefore shutdown, power LED still stayed on) journalctl -b -1shows a clean shutdown sequence all the way toSending SIGTERM to remaining processes/ journald stopping — no errors logged, no amdgpu-related errors. The freeze appears to happen after journald stops, i.e., during the final hardware power-off sequence, so nothing is captured in logs.- My Windows dual boot is able to shutdown properly.
Specs below:
System:
Kernel: 7.1.1-2-cachyos arch: x86_64 bits: 64 compiler: clang v: 22.1.6
clocksource: tsc
Desktop: KDE Plasma v: 6.7.1 tk: Qt v: N/A wm: kwin_wayland vt: 2 dm: N/A
Distro: CachyOS base: Arch Linux
Machine:
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX B550-A GAMING v: Rev X.0x
serial: <superuser required> part-nu: SKU uuid: <superuser required>
Firmware: UEFI vendor: American Megatrends v: 2806 date: 10/27/2022
Battery:
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech MX Master 3S serial: <filter>
charge: 75% rechargeable: yes status: discharging
CPU:
Info: 8-core model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP smt: enabled
arch: Zen 3+ rev: 2 cache: L1: 512 KiB L2: 4 MiB L3: 96 MiB
Speed (MHz): avg: 3869 min/max: 576/4553 boost: enabled cores: 1: 3869
2: 3869 3: 3869 4: 3869 5: 3869 6: 3869 7: 3869 8: 3869 9: 3869 10: 3869
11: 3869 12: 3869 13: 3869 14: 3869 15: 3869 16: 3869 bogomips: 108799
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Graphics:
❯ inxi -Fxxxz
System:
clocksource: tsc
Machine:
Battery:
status: discharging
CPU:
Speed (MHz): avg: 3265 min/max: 576/4553 boost: enabled cores: 1: 3265
2: 3265 3: 3265 4: 3265 5: 3265 6: 3265 7: 3265 8: 3265 9: 3265 10: 3265
11: 3265 12: 3265 13: 3265 14: 3265 15: 3265 16: 3265 bogomips: 108799
ssse3 svm
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Sapphire driver: amdgpu v: kernel
arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:73df
class-ID: 0300
Display: wayland server: Xwayland v: 24.1.12 compositor: kwin_wayland
driver: gpu: amdgpu d-rect: 6400x2160 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: MSI MAG 272URDF res:
mode: 3840x2160 hz: 160 scale: 150% (1.5) to: 2560x1440 dpi: 163
size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 3840x2160
min: 720x400
Monitor-2: DP-2 pos: right model: 27E1Q serial: <filter> res:
mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 108
size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 2560x1440
min: 720x400
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.2-arch3.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi navi22 ACO DRM
3.64 7.1.1-2-cachyos) device-ID: 1002:73df display-ID: :0.0
API: Vulkan v: 1.4.350 layers: 6 surfaces: N/A device: 0
type: discrete-gpu hw: amd driver: mesa radv device-ID: 1002:73df
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Audio:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 06:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: HP HyperX Cloud II Wireless
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 bus-ID: 3-2:2 chip-ID: 03f0:018b class-ID: 0300
API: ALSA v: k7.1.1-2-cachyos status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.6.7 status: active with: 1: pipewire-pulse
Network:
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlan0 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0c:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp12s0 state: down mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-7.2:5 chip-ID: 8087:0032 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 class-ID: 7c0104
Drives:
Local Storage: total: 2.73 TiB used: 340.89 GiB (12.2%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P3PSSD8 size: 931.51 GiB
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A
temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Crucial model: CT2000P3PSSD8 size: 1.82 TiB
temp: 49.9 C scheme: GPT
Partition:
ID-1: / size: 195.8 GiB used: 22.17 GiB (11.3%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 511 MiB used: 332 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p7
ID-3: /home size: 915.98 GiB used: 318.72 GiB (34.8%) fs: ext4
dev: /dev/nvme1n1p3
Swap:
ID-1: swap-1 type: zram size: 31.22 GiB used: 2.1 MiB (0.0%) priority: 100
dev: /dev/zram0
Sensors:
System Temperatures: cpu: 56.4 C mobo: N/A gpu: amdgpu temp: 63.0 C
mem: 64.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 671
Info:
Memory: total: 32 GiB available: 31.22 GiB used: 5.3 GiB (17.0%)
Processes: 381 Power: uptime: 13m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 261 default: graphical
Packages: 1412 pm: pacman pkgs: 1406 pm: flatpak pkgs: 6 Compilers:
clang: 22.1.6 gcc: 16.1.1 Shell: fish v: 4.7.1 running-in: konsole
inxi: 3.3.40
Reboot log: 3f17a6d
I have honestly no clue what’s going on. I saw a similar issue on the Mint forum but it’s not really solved.
If anyone has an idea, let me know
Thanks a lot
