Hi, sorry for my english.
Im curently debating if i should switch to CachyOS.
The thing is, ive had working Arch install, but, after update to new kernel, my PC started to freeze in browsers, i didnt have the knowledge of changing the kernel back to where it worked, so i distro hopped to Ubuntu. Everything is mostly fine, but my integrated Bluetooth dont work, it does not even detect it, so im forced to use my BT dongle, which is kinda irritating.
So my question is, can installing CachyOS fix my issue with Bluetooth? Im pretty desperate now, i would like to stay on one distro, but its kinda hard lol.
Ive installed it on my old Thinkpad and figured, there is a Kernel Manager, which is a cool neat thing. I have MS-7E26 motherboard. Thanks for the replies.
Cachyos is arch, more than likely you will have the same problem here too. You should have tried the lts kernel with arch.
Yes, i know, its too late now.
But i dont know if should distro hop to Cachy and try that kernel, that worked for me the whole 5 months… it was the 6.10. or the LTS one, im really tempted
Basically, the linux kernel is not a unique part of a distro (though that is somewhat more true here perhaps than most) and should not be why one would wish to change distros. All distros are essentially the same under the top-dressing.
Whether it’s rolling or static (like Debian) release is more important. It may be more important if the distro supports (out of box) something you prefer (like GNOME, KDE, Hyprland, or perhaps Xmonad), but you can usually build your own there too. In almost all cases, all the tools are there (in each distro) to do almost anything you want. It depends on how much of a mechanic you are.
Unlikely, but you can check from the live environment.
can you provide with USB live Cacyos
inxi -Fza
Yes, here it is
System:
Kernel: 6.11.7-1-cachyos arch: x86_64 bits: 64 compiler: clang v: 18.1.8
clocksource: tsc avail: hpet,acpi_pm
parameters: BOOT_IMAGE=/arch/boot/x86_64/vmlinuz-linux-cachyos
archisobasedir=arch archisosearchuuid=2024-11-10-17-23-56-00
cow_spacesize=10G copytoram=auto
module_blacklist=nvidia,nvidia_modeset,nvidia_uvm,nvidia_drm,pcspkr
nouveau.modeset=1 i915.modeset=1 amdgpu.modeset=1 nvme_load=yes
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
wm: kwin_x11 vt: 1 dm: SDDM Distro: CachyOS base: Arch Linux
Machine:
Type: Desktop System: Micro-Star product: MS-7E26 v: 1.0
serial:
Mobo: Micro-Star model: PRO B650-S WIFI (MS-7E26) v: 1.0
serial: uuid: UEFI: American
Megatrends LLC. v: 1.F0 date: 07/26/2024
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
serial: charge: 55% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse B330/M330/M331
status: discharging
CPU:
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4398 min/max: 545/5050 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4398 2: 4398 3: 4398
4: 4398 5: 4398 6: 4398 7: 4398 8: 4398 9: 4398 10: 4398 11: 4398 12: 4398
13: 4398 14: 4398 15: 4398 16: 4398 bogomips: 134400
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: retbleed status: Not affected
Type: spec_rstack_overflow mitigation: Safe RET
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4, DP-5, DP-6, HDMI-A-2, Writeback-2 bus-ID: 11:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 48.0 C
Display: x11 server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: fbdev,modesetting
alternate: vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3200x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: AOC 24G2W1G4 serial: built: 2020 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Sony CPD-E430
serial: built: 2002 res: 1280x1024 hz: 85 dpi: 92 gamma: 1.5
size: 352x264mm (13.86x10.39") diag: 450mm (17.7") ratio: 4:3 modes:
max: 1280x1024 min: 640x350
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Audio:
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640
class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.7-1-cachyos status: kernel-api
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Network:
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0d:00.0
chip-ID: 10ec:8125 class-ID: 0200
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 0e:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlan0 state: down mac:
Info: services: NetworkManager, sshd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.1:5 chip-ID: 2357:0604
class-ID: e001 serial:
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: not found
rfk-block: hardware: no software: no address: see --recommends
Drives:
Local Storage: total: 2.31 TiB used: 0 KiB (0.0%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 061 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Patriot model: P210 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 0A0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: fw-rev: 072
ID-4: /dev/sdd maj-min: 8:48 vendor: Verbatim model: STORE N GO
size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial:
fw-rev: STOR scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Partition:
ID-1: / raw-size: N/A size: 10 GiB used: 24 MiB (0.2%) fs: overlay
source: ERR-102
Swap:
Kernel: swappiness: 150 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 30.46 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
Sensors:
System Temperatures: cpu: 55.8 C mobo: 38.0 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 40.0 C mem: 38.0 C fan: 0 watts: 15.00
device: amdgpu temp: 48.0 C
Info:
Memory: total: 32 GiB note: est. available: 30.46 GiB used: 4.52 GiB (14.8%)
Processes: 368 Power: uptime: 2m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.12 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 950 libs: 217 tools: paru Compilers: N/A
Shell: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
im really clueless why this happened, my Bluetooth worked before normaly
Please try with an updated ISO version :). Latest ISO uses 6.12 kernel.
Omg i found the solution… i unplugged the PSU cable, waited 10 minutes and it works now, my mind is blown lol. I wouldnt figured this out on my own
Ok thank for your replies :]
I must think this out, wether to switch or not
