When watching a Steam Game Recording replay via the in-game overlay on kernel 7.0.10-1-cachyos, the playback is very choppy and has an audio delay. The issue affects all games (both native Linux and Proton). Downgrading to the LTS kernel (6.18.33-1-cachyos) completely resolves both issues.
I recorded with a GPU graph and we can see that the moment I open the Steam Overlay, there’s a usage spike that goes back to normal when closed. While watching a replay, the usage drops significantly, then goes back to a higher level when I stop watching, and returns to normal the moment I close the overlay. In the recording there are also frames where my wallpaper is briefly visible. The audio delay is not present in this specific recording but I have other clips where it is, which seems to appear when playing for a long time.
By the way, in my videos, I wait before opening the Steam Overlay to let the map and shaders finish preloading, which is visible as GPU usage drops in the graph.
System information:
Kernel (broken): 7.0.10-1-cachyos
Kernel (working): 6.18.33-1-cachyos-lts
CPU: AMD Ryzen 7 5800X
GPU: AMD RX 7800 XT
Desktop: KDE Plasma 6.6.5, Wayland
Steam version: 1779479049 (Beta, May 22 2026)
Steps to reproduce:
Boot into kernel 7.0.10-1-cachyos
Launch any game via Steam
Open the Steam overlay and watch a clip via Steam Game Recording
Expected behavior: Overlay and replay playback render smoothly
Actual behavior: Replay playback is choppy with audio delay. GPU usage briefly spikes when the overlay opens, then drops significantly during replay playback.
Confirmed workaround: Booting into 6.18.33-1-cachyos-lts fully resolves the choppiness, though the brief GPU spike on overlay open persists.
Things already tried that did not help on 7.0.10:
Disabling GPU accelerated rendering in Steam web views
Same issue for with Steam Overlay poor performance (not just with recording). It’s as soon as you open the overlay, it lags horribly and becomes unusable.
I’ve narrowed it down to kernel 6.19 where this started to happen. 6.18 and 6.18 LTS work fine for me too. 6.19 has the severe lag.
Here’s an issue about it over on Valve’s repo:
Hopefully there is a temp fix / workaround on the cachyos side we can do (besides using 6.18 LTS)
My Steam Overlay used to be choppy too but for some reason, it fixed itself? Like dragging windows in the overlay was choppy as well as my cursor, but after letting the game run for a bit longer, the overlay was no longer choppy.
The Steam Game Recording in-overlay player (“Show Recording”) stutters/freezes
constantly while the game in the background runs perfectly fine. The recording itself
is only H.264 1080p60 ~12 Mbps and plays back perfectly smooth in mpv/VLC and when
exported — it’s ONLY the in-overlay CEF player that’s choppy.
I tested the exact same recording across all my installed kernels:
So it’s not a CachyOS-specific patch, Mesa, or a Steam setting — it also reproduces on
plain mainline 7.0.11, and only the 6.18 LTS is clean. Looks like an amdgpu/kernel
regression introduced somewhere after 6.18. VA-API encode/decode is otherwise fine
(vainfo OK, exports fine).
Booting linux-lts is a working workaround for now.
