While trying to install some games on Steam I have been running into various issues with the download speeds being high initially and then dropping by 20x a couple minutes into the download.
While I am not exactly sure why this happens I do know that it’s possible to configure some Steam sided DNS caching by including the @nClientDownloadEnableHTTP2PlatformLinux 0
and @fDownloadRateImprovementToAddAnotherConnection 1.0
params in steam_dev.cfg
However, even though these changes were automatically applied when installing Steam through pacman I still had to install dnsmasq and configure it with the following params:
listen-address=::1,127.0.0.1
cache-size=10000
conf-file=/usr/share/dnsmasq/trust-anchors.conf
dnssec
Only after applying these changes was my Steam stable enough not to drop off to an astronomically low bit rate 2 minutes into the installation.
Perhaps it has something to do with the CachyOS default DNS caching since the first steps with configuring steam_dev.cfg
actually do resolve the problem when troubleshooting the exact same issue on Ubuntu 24.04 LTS.
