Sound desynchronisation with ALC4080 audio codec using S/PDIF in gaming applications
So I have an ASUS ROG Strix x670e-f with a Ryzen 7 9800X3D and on a fresh install I have an issue where in any video game application, there are audio cut outs (as in once every 30-60 seconds the audio will cut out for a brief moment (as in, the audio will stop for a moment before restarting).
Now the main issue is that this motherboard uses a ALC4080 codec. It’s somewhat problematic as its actually running over the USB interface, and there was a bug specifically with S/PDIF, but that was supposedly fixed with a firmware update.
The current workaround I have in place is to configure Wireplumber to firstly disable autosuspend (session.suspend-timeout-seconds = 0) and then fixing the format of the audio to
                audio.format = "S24_3LE"
                audio.rate = 192000
                api.alsa.period-size = 512
This seems to work, but I don’t have high confidence it will work in all cases. Setting the rate to 192000 seems necessary to prevent cutouts generally (something that I find less surprising, as when I was on Windows I had to set it to that to prevent crackling in some scenarios), and then a period-size of 512 seems to be the minimum to allow it to seem stable.
For me whilst it looks like I have a solution, there’s a part of me that feels like this isn’t the right solution. Particularly as I feel like there would be more cases out there of people with this specific issue with similar solutions whilst I largely had to trial and error this solution..
Interesting. I have issue also with ALC4080 i guess.
I have MAG B650M MORTAR WIFI motherboard with ALC4080 Audio Chip. Running now Linux 7.1.1-2-cachyos, KDE Plasma 6.7.1.
When I use Audio via BlueTooth headset, and start game like ArcRaiders my Audio setting for BlueTooth headsets drops from [High Fidelity Playback (A2D2 Sink, codec aptx HD)] to low quality [Headset Unit (HSP/HFP, codec MSBC)] and it sounds horrendous. I manually have to re-select the aptx HD codec profile everytime (every 20 min or so).
When I press to talk on microphone, instantly codec drops back to the low quality one.
Somehow it is observed only to using bluetooth headsets. If I use wired headphones everything works perfect and no such issue.
I have not found solution yet.
