[Solved] Non functional ethernet connection, but wifi works
Hey, I’m using a fresh install of CachyOS on a new PC and having issues getting it to detect an ethernet connection.
So far, I am assuming this must be a driver related issue with my motherboard
https://www.msi.com/Motherboard/MAG-Z890-TOMAHAWK-WIFI
lspci lists the following devices:
82:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. Device 5000 (rev 04)
83:00.0 Network controller: Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 (rev 1a)
I can confirm that the Ethernet port and related hardware does function - it works under windows with the relevant drivers from the mobo manufacturer installed. However, it doesn’t recognize anything on CachyOS (or the arch install medium) and despite searching I can’t find a driver package or trick for configuring it that does anything.
Does anyone know either the package I need or a procedure to set this hardware up to work via ethernet? I’ve been looking but I’ve had no luck so far. Would greatly appreciate any help with this.
Hey :wave:
Realtek is IMHO overall a pretty infamous manufacturer, let’s see if we can get there.
Can you narrow down the exact device type?
What does sudo dmesg | grep '82:00' show?
Is the interface there but just not up? Try ip link.
Run lcpci -v, it shows more details and the loaded and available kernel modules.
Here are the results of those commands:
❯ sudo dmesg | grep ‘82:00’
[ 0.331966] pci 0000:82:00.0: [10ec:5000] type 00 class 0x020000 PCIe Endpoint
[ 0.331986] pci 0000:82:00.0: BAR 0 [io 0x3000-0x30ff]
[ 0.332011] pci 0000:82:00.0: BAR 2 [mem 0xb8200000-0xb820ffff 64bit]
[ 0.332027] pci 0000:82:00.0: BAR 4 [mem 0xb8210000-0xb8213fff 64bit]
[ 0.332175] pci 0000:82:00.0: supports D1 D2
[ 0.332175] pci 0000:82:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.368454] pci 0000:82:00.0: Adding to iommu group 25
❯ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
link/ether e8:bf:b8:e5:21:58 brd ff:ff:ff:ff:ff:ff
lspci -v (trimmed to just the ethernet and wifi devices)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 7e32
Flags: fast devsel, IRQ 255, IOMMU group 25
I/O ports at 3000 [disabled] [size=256]
Memory at b8200000 (64-bit, non-prefetchable) [disabled] [size=64K]
Memory at b8210000 (64-bit, non-prefetchable) [disabled] [size=16K]
Capabilities:
Subsystem: Rivet Networks Device 1774
Flags: bus master, fast devsel, latency 0, IRQ 19, IOMMU group 26
Memory at b8100000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
Additionally, windows recognizes it as a “Killer E5000B” when it has drivers up.
Thanks. Looks okay so far, no errors, but indeed it has no kernel driver loaded or available; compare with the WiFi, which has iwlwifi loaded.
I found this:
I updated to the 6.11 kernel and my Intel® Killer™ E5000B 5G LAN r8126 isn’t detected. I also installed the dkms package and no go as well. pve 8.2.7. I’m on a very new z890 chipset mother board with Intel Ultra 265k
I was able to get the NIC working, it’s techinicall the: (Intel® Killer™ E5000B 5G LAN r8126)
So the chipset seems to be from realtek (r8126) and it is used by different vendors, e.g. Intel in their products.
Does a modprobe r8126 work?
There seems to be an AUR package available for this chipset:
$ yay -Ss r8126
aur/r8126-dkms 10.014.01-1 (+3 1.71)
    Kernel module for Realtek RTL8126
$ yay -Si r8126-dkms
Repository                    : aur
Version                       : 10.014.01-1
Description                   : Kernel module for Realtek RTL8126
URL                           : https://www.realtek.com/Download/List?cate_id=584
Licenses                      : GPL2
Groups                        : None
Provides                      : None
Depends On                    : dkms
Optional Deps                 : linux-headers  linux-lts-headers
Make Deps                     : None
Check Deps                    : None
Conflicts With                : r8126
Replaces                      : None
AUR URL                       : https://aur.archlinux.org/packages/r8126-dkms
First Submitted               : Wed 25 Sep 2024 10:14:58 PM CEST
Keywords                      : None
Last Modified                 : Sun 10 Nov 2024 07:37:43 PM CET
Maintainer                    : didi2002
Popularity                    : 1.708070
Votes                         : 3
Out-of-date                   : No
That is, if I detected the chipset correctly for you…
Okay, so initially modprobe didn’t work, and paru seemed unwilling to install the driver you specified, so I used yay and fortunately that did the trick. Seems to work now and persists through boot as well.
Appreciate your help a lot, thank you.
Great, I’m happy it works now
Paru and yay do exactly the same thing.
What many people don’t know is that paru needs to be confirmed with q in order to install packages.
Makes sense, appreciate you telling me. Been wracked by small oversights like this as is customary when trying out new things.
For those looking to get this to work on the Alienware M18 R2, yes this is the solution. Be sure to restart after paru is done installing.
