Mirrez
August 4, 2024, 3:36pm
1
Hello, I am new to cachyos and did a standard install using grub cachyos nvidia.
and I noticed now when I updated the system via sudo pacman -S Syu
I got these error messages for missing these dependency’s
is there a way to get these installed individually or do I need to reinstall the nvidia drivers?
Mirrez
August 4, 2024, 3:42pm
2
reason i say nvidia is because I noticed when I installed sudo pacman -S linux-cachyos-nvidia up above I got these error messages afterwards prior to updating the system.
I dont see an issue here. Its just that the cdn could not find the cache, but it further proceeds with a different mirror
Mhm, was the nvidia driver not preinstalled?
Mirrez
August 4, 2024, 4:47pm
5
Yes I believe so. Wayland is enabled along with VRR so believe I should be ok?
Thanks
Just to check, if the hardware detection is working correctly, could you provide me:
cat /var/log/pacman.log | paste-cachyos
Mirrez
August 4, 2024, 8:16pm
7
Sorry for the late reply!
here’s the log 1b3c0ed
best
Looking into this log, it appears that the driver correctly gets installed:
[2024-08-03T23:30:28-0500] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg -r / --config /etc/pacman.conf --needed -S nvidia-utils egl-wayland nvidia-settings opencl-nvidia lib32-opencl-nvidia lib32-nvidia-utils libva-nvidia-driver vulkan-icd-loader lib32-vulkan-icd-loader linux-cachyos-nvidia'
[2024-08-03T23:30:40-0500] [ALPM] running '60-mkinitcpio-remove.hook'...
[2024-08-03T23:30:41-0500] [ALPM] transaction started
[2024-08-03T23:30:41-0500] [ALPM] installed eglexternalplatform (1.1-3)
[2024-08-03T23:30:41-0500] [ALPM] installed egl-wayland (3:1.1.13-1.1)
[2024-08-03T23:30:41-0500] [ALPM] installed nvidia-utils (555.58.02-2)
[2024-08-03T23:30:41-0500] [ALPM-SCRIPTLET] If you run into trouble with CUDA not being available, run nvidia-modprobe first.
[2024-08-03T23:30:41-0500] [ALPM-SCRIPTLET] If you use GDM on Wayland, you might have to run systemctl enable --now nvidia-resume.service
[2024-08-03T23:30:41-0500] [ALPM-SCRIPTLET] Enabling services...
[2024-08-03T23:30:41-0500] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2024-08-03T23:30:41-0500] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2024-08-03T23:30:41-0500] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' -> '/usr/lib/systemd/system/nvidia-hibernate.service'.
[2024-08-03T23:30:41-0500] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' -> '/usr/lib/systemd/system/nvidia-suspend.service'.
[2024-08-03T23:30:41-0500] [ALPM] installed hicolor-icon-theme (0.18-1)
[2024-08-03T23:30:41-0500] [ALPM] installed adwaita-icon-theme-legacy (46.2-1)
[2024-08-03T23:30:41-0500] [ALPM] installed adwaita-cursors (46.2-1)
[2024-08-03T23:30:41-0500] [ALPM] installed adwaita-icon-theme (46.2-1)
[2024-08-03T23:30:41-0500] [ALPM] installed dconf (0.40.0-3.1)
[2024-08-03T23:30:41-0500] [ALPM] installed gsettings-system-schemas (46.1-2)
[2024-08-03T23:30:41-0500] [ALPM] installed adobe-source-code-pro-fonts (2.042u+1.062i+1.026vf-2)
[2024-08-03T23:30:41-0500] [ALPM] installed gsettings-desktop-schemas (46.1-2)
[2024-08-03T23:30:41-0500] [ALPM] installed libei (1.2.1-1.1)
[2024-08-03T23:30:41-0500] [ALPM] installed libxi (1.8.1-2.1)
[2024-08-03T23:30:41-0500] [ALPM] installed libxtst (1.2.4-2.1)
[2024-08-03T23:30:41-0500] [ALPM] installed at-spi2-core (2.52.0-1.1)
[2024-08-03T23:30:41-0500] [ALPM] installed desktop-file-utils (0.27-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed iso-codes (4.16.0-1)
[2024-08-03T23:30:42-0500] [ALPM] installed libcloudproviders (0.3.6-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed lcms2 (2.16-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libcolord (1.4.7-2)
[2024-08-03T23:30:42-0500] [ALPM] installed libepoxy (1.5.10-3.1)
[2024-08-03T23:30:42-0500] [ALPM] installed librsvg (2:2.58.2-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libxcomposite (0.4.6-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libxcursor (1.2.2-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libxdamage (1.1.6-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libxinerama (1.1.5-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libxrandr (1.5.4-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed json-glib (1.8.0-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed glib-networking (1:2.80.0-3.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libsoup3 (3.4.4-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libstemmer (2.2.0-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed tracker3 (3.7.3-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed gtk-update-icon-cache (1:4.14.4-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed gtk3 (1:3.24.43-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libxv (1.0.12-2.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libvdpau (1.5-3.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libxnvctrl (555.58.02-2)
[2024-08-03T23:30:42-0500] [ALPM] installed nvidia-settings (555.58.02-2)
[2024-08-03T23:30:42-0500] [ALPM] installed opencl-nvidia (555.58.02-2)
[2024-08-03T23:30:42-0500] [ALPM] installed lib32-opencl-nvidia (555.58.02-1)
[2024-08-03T23:30:42-0500] [ALPM] installed lib32-nvidia-utils (555.58.02-1)
[2024-08-03T23:30:42-0500] [ALPM] installed libunwind (1.8.1-3.1)
[2024-08-03T23:30:42-0500] [ALPM] installed gstreamer (1.24.6-1)
[2024-08-03T23:30:42-0500] [ALPM] installed orc (0.4.39-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed gst-plugins-base-libs (1.24.6-1)
[2024-08-03T23:30:42-0500] [ALPM] installed gssdp (1.6.3-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed gupnp (1:1.6.6-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed gupnp-igd (1.6.0-1.1)
[2024-08-03T23:30:42-0500] [ALPM] installed libnice (0.1.22-1)
[2024-08-03T23:30:42-0500] [ALPM] installed gst-plugins-bad-libs (1.24.6-1)
[2024-08-03T23:30:42-0500] [ALPM] installed libva-nvidia-driver (0.0.12-1.1)
[2024-08-03T23:30:43-0500] [ALPM] upgraded linux-cachyos (6.10.1-2 -> 6.10.3-2)
[2024-08-03T23:30:43-0500] [ALPM] installed linux-cachyos-nvidia (6.10.3-2)
[2024-08-03T23:30:43-0500] [ALPM] transaction completed
