Keyboard doesn’t works after waking up sleep mode. I tried too many different things but none of them solved. I made some change in limine config file, update BIOS but none of them works. Gemini says it’s a kernel issue. Do you know any way to fix it?
Also num lock always gets close every restart even though I set it on in settings.
I have ideapad slim 3 15arp10, ryzen7 7735hs
here is the kernel log (idk what is the kernel log, gemini says)
❯ sudo dmesg | grep -i -E "keyboard|i8042|atkbd"
[sudo] password for ufukd:
[ 1.125240] i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
[ 1.125242] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.125890] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.126928] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.637893] hid-generic 0003:046D:C53F.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:04:00.4-2/input0
[ 4.577473] logitech-djreceiver 0003:046D:C53F.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:04:00.4-2/input0
[ 4.765102] input: Logitech Wireless Mouse PID:4074 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3-2:1.2/0003:046D:C53F.0003/0003:046D:4074.0004/input/input9
[ 4.789313] hid-generic 0003:046D:4074.0004: input,hidraw3: USB HID v1.11 Keyboard [Logitech Wireless Mouse PID:4074] on usb-0000:04:00.4-2/input2:1
[ 6.451729] logitech-hidpp-device 0003:046D:4074.0004: input,hidraw4: USB HID v1.11 Keyboard [Logitech G305] on usb-0000:04:00.4-2/input2:1
I fixed it and it’s really easy:
–Open terminal
–enter this command (creates a new config file for amd power module)
sudo nano /etc/modprobe.d/amd_pmc.conf
then you will see an empty black screen
-paste this command in it:
options amd_pmc enable_stb=1
–press “ctrl+q” then “enter” then “ctrl+x” (that saves the file and quits)
–enter this command:
sudo mkinitcpio -P
-restart pc
Now you can try sleep mode. This ways works for my laptop.
Gemini says: it runs a STB(smart trace buffer) while sleep mode.
– – – SOLVED BY USING AI – – –
Some further reading for those that like getting information from actual sources instead of AI
Hi everyone,
I’m writing this to save anyone else the massive headache I’ve had over the last 24 hours. I recently got a Lenovo IdeaPad Slim 3 15ARP10 (7 7735HS), and installed mint 22.2 on it.
After a couple hours of usage, I found that the...
35 points | 52 comments — u/InfiniteMushroom3161
I found that Lenovo is using a specific Power Management Controller (PMC) configuration. Specifically, they use a driver parameter for the amd_pmc module that isn’t enabled by default in standard Linux distributions.
Had the same problem on my new notebook this week.
OS: Fedora Linux 43 (Workstation Edition) x86_64
Host: 83K7 (IdeaPad Slim 3 15ARP10)
Kernel: Linux 6.18.6-200.fc43.x86_64
Shell: bash 5.3.0
Display (LEN9194): 1920x1200 in 15", 60 Hz [Built-in]
DE: GNOME 49.2
WM: Mutter (Wayland)
CPU: AMD Ryzen 5 7535HS (12) @ 4.60 GHz
GPU: AMD Radeon 660M [Integrated]
Memory: 3.33 GiB / 19.21 GiB (17%)
Swap: 0 B / 8.00 GiB (0%)
Disk (/): 13.00 GiB / 154.83 GiB (8%) - btrfs
Battery (L24X3PK1): 100% [AC Connected]
Locale: en_US.UTF-8
Here’s what works for me (thanks Gemini for that):
AMD PMC configuration update
It is important for Fedora that the power modules are initialized correctly.
Create a configuration file:
sudo nano /etc/modprobe.d/amd-fix.conf
Paste there:
Create one more configuration file:
sudo nano /etc/modprobe.d/ideapad.conf
Paste there:
options ideapad_laptop allow_v4_dytc=1
Since Fedora uses dracut , you need to force update the boot image to take these options into account:
sudo dracut -f
For your distro it might be instead:
sudo update-initramfs -u
That’s it! Nothing else I didn’t do. Keyboard works perfectly fine (functional keys too) after suspending and lid closing/opening suspends/wakes.
Try this solution from Reddit - The heart of the internet . It worked on Linux Mint 22:
# fixes the problem
sudo tee /etc/modprobe.d/amd_pmc.conf <<< 'options amd_pmc enable_stb=1'
# after reboot, checks if config above was correctly applied
cat /sys/module/amd_pmc/parameters/enable_stb # should output Y, instead of N
Seems to be related to Lenovo notebooks/laptops that are pretty recent
A few weeks later, I had a new problem with that: laptop doesn’t wake up. That means old solution is trash. So, here is the new solution, this solution actually disconnect then reconnect the keyboard when laptop wake up.
1- create a new service file:
sudo nano /etc/systemd/system/keyboard-wake.service
an empty page will be open
2- paste this in it:
[Unit]
Description=Reset i8042 keyboard controller after sleep
After=suspend.target hibernate.target hybrid-sleep.target suspend-then-hibernate.target
[Service]
Type=oneshot
ExecStart=/bin/sh -c ‘echo -n “i8042” > /sys/bus/platform/drivers/i8042/unbind && echo -n “i8042” > /sys/bus/platform/drivers/i8042/bind’
[Install]
WantedBy=suspend.target hibernate.target hybrid-sleep.target suspend-then-hibernate.target
press in order: ctrl+o, enter, ctrl+x (this saves the file and quits)
3- activate the settings:
sudo systemctl enable keyboard-wake.service
4- reboot
(i8042 controller is older than 40 years, your keyboard controller might be different, consider that)
Also if laptop doesn’t go sleep mode, shut down, then press power button 30 seconds. then open again.
I hate that thing, this setting has blown up too…
Consider living without suspend (and disabling it through KDE settings). I never really use it as I always save my work when I move my laptop between places. And for stuff that I need to use fast (like to check something quickly), those are on my phone
Yes this is what I’m doing. I limited max charge. Now I’m using plugged in with disabled sleep mode. I also wrote on the Lenovo forum, and they advised me to use Windows. They probably haven’t even tested hardware for Linux.
Looking at your initial log, maybe you could try a different approach.
If the issue is with amd_pmc driver, maybe the best way would be to remove the module after suspend and load it again?
I used similar approach with my old Acer Nitro, with the WiFi network that died on me after suspend. A simple service that do a rmmod and then modprobe after few seconds did the trick with the driver for me.
EDIT: You can do the same with i8042
I just tried that too, unfortunately it’s not working.
Hmm. We are talking about laptop ‘integrated’ keyboard, or USB / BT one?
Can you paste the logs from
sudo journalctl
That start after your computer wakes up?
Look at the time and search for something like:
systemd[1]: systemd-suspend.service: Deactivated successfully.
And paste everything after that
$ sudo journalctl -r
Apr 06 19:22:27 cachyos-ufukd sudo[4623]: pam_unix(sudo:session): session opened for user root(uid=0) by ufukd(uid>
Apr 06 19:22:27 cachyos-ufukd sudo[4623]: ufukd : TTY=pts/0 ; PWD=/home/ufukd ; USER=root ; COMMAND=/usr/bin/jo>
Apr 06 19:22:17 cachyos-ufukd kdeconnectd[1870]: No uuids found for "A0:B3:39:C6:95:20"
Apr 06 19:22:08 cachyos-ufukd sudo[4516]: pam_unix(sudo:session): session closed for user root
Apr 06 19:21:17 cachyos-ufukd kdeconnectd[1870]: No uuids found for "A0:B3:39:C6:95:20"
Apr 06 19:21:17 cachyos-ufukd kdeconnectd[1870]: No uuids found for "A0:29:42:96:46:63"
Apr 06 19:20:02 cachyos-ufukd systemd[1]: snapperd.service: Deactivated successfully.
Apr 06 19:19:59 cachyos-ufukd sudo[4516]: pam_unix(sudo:session): session opened for user root(uid=0) by ufukd(uid>
Apr 06 19:19:59 cachyos-ufukd sudo[4516]: ufukd : TTY=pts/0 ; PWD=/home/ufukd ; USER=root ; COMMAND=/usr/bin/jo>
Apr 06 19:19:48 cachyos-ufukd systemd[1]: cachyos-rate-mirrors.service: Consumed 3.073s CPU time over 36.377s wall>
Apr 06 19:19:48 cachyos-ufukd systemd[1]: Finished Refresh arch / cachyos mirror lists.
Apr 06 19:19:48 cachyos-ufukd systemd[1]: cachyos-rate-mirrors.service: Deactivated successfully.
Apr 06 19:19:48 cachyos-ufukd cachyos-rate-mirrors[4368]: ==> Done [cachyos] /etc/pacman.d/cachyos-mirrorlist
Apr 06 19:19:38 cachyos-ufukd cachyos-rate-mirrors[4368]: --> Ranking mirrors for cachyos repository in /etc/pacm>
Apr 06 19:19:38 cachyos-ufukd cachyos-rate-mirrors[4368]: ==> Done [arch] /etc/pacman.d/mirrorlist
Apr 06 19:19:17 cachyos-ufukd kdeconnectd[1870]: No uuids found for "5C:B4:7E:9A:21:1B"
Apr 06 19:19:12 cachyos-ufukd cachyos-rate-mirrors[4368]: --> Ranking mirrors for arch repository in /etc/pacman.>
Apr 06 19:19:12 cachyos-ufukd systemd[1]: Starting Refresh arch / cachyos mirror lists...
Apr 06 19:19:02 cachyos-ufukd systemd[1]: snapper-cleanup.service: Deactivated successfully.
Apr 06 19:19:02 cachyos-ufukd limine-snapper-sync[4284]: Remove this warning by changing MAX_SNAPSHOT_ENTRIES from>
Apr 06 19:19:02 cachyos-ufukd limine-snapper-sync[4293]: Snapshot limit mismatch: 57 Snapper snapshots exceed the >
Apr 06 19:19:02 cachyos-ufukd limine-snapper-sync[4284]: Snapshot limit mismatch: 57 Snapper snapshots exceed the >
Apr 06 19:19:02 cachyos-ufukd systemd-helper[4272]: Running empty-pre-post cleanup for 'root'.
Apr 06 19:19:02 cachyos-ufukd systemd-helper[4272]: Running timeline cleanup for 'root'.
Apr 06 19:19:02 cachyos-ufukd systemd-helper[4272]: Running number cleanup for 'root'.
Apr 06 19:19:02 cachyos-ufukd systemd-helper[4272]: Running cleanup for 'root'.
Apr 06 19:19:02 cachyos-ufukd systemd[1]: Started DBus interface for snapper.
Apr 06 19:19:02 cachyos-ufukd systemd[1]: Starting DBus interface for snapper...
Apr 06 19:19:02 cachyos-ufukd systemd[1]: Started Daily Cleanup of Snapper Snapshots.
Apr 06 19:19:02 cachyos-ufukd systemd[1]: Starting Daily Cleanup of Snapper Snapshots...
Apr 06 19:18:39 cachyos-ufukd sudo[4251]: pam_unix(sudo:session): session closed for user root
Apr 06 19:18:30 cachyos-ufukd sudo[4251]: pam_unix(sudo:session): session opened for user root(uid=0) by ufukd(uid>
Apr 06 19:18:30 cachyos-ufukd sudo[4251]: ufukd : TTY=pts/0 ; PWD=/home/ufukd ; USER=root ; COMMAND=/usr/bin/jo>
Apr 06 19:18:23 cachyos-ufukd sudo[4207]: pam_unix(sudo:session): session closed for user root
Apr 06 19:16:01 cachyos-ufukd sudo[4207]: pam_unix(sudo:session): session opened for user root(uid=0) by ufukd(uid>
Apr 06 19:16:01 cachyos-ufukd sudo[4207]: ufukd : TTY=pts/0 ; PWD=/home/ufukd ; USER=root ; COMMAND=/usr/bin/jo>
Apr 06 19:15:56 cachyos-ufukd systemd[1113]: Started app-org.kde.konsole-4156.scope.
Apr 06 19:15:55 cachyos-ufukd systemd[1113]: Started Terminal - Terminal.
Apr 06 19:14:55 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 4001 of process 2291 owned by '1000' RT>
Apr 06 19:14:17 cachyos-ufukd kdeconnectd[1870]: No uuids found for "5C:B4:7E:9A:21:1B"
Apr 06 19:14:17 cachyos-ufukd kdeconnectd[1870]: No uuids found for "A0:B3:39:C6:95:20"
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9e:5c:20 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:97:f0 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:93:e0 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9e:3e:60 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:a7:40 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:91:20 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:91:30 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9e:45:60 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:b0:a0 0
Apr 06 19:13:57 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:9e:00 0
Apr 06 19:13:10 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 3830 of process 3450 owned by '1000' RT>
Apr 06 19:12:36 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 3684 of process 3357 owned by '1000' RT>
Apr 06 19:12:20 cachyos-ufukd systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 06 19:12:14 cachyos-ufukd NetworkManager[907]: <info> [1775491934.4739] audit: op="statistics" interface="wla>
Apr 06 19:12:14 cachyos-ufukd NetworkManager[907]: <info> [1775491934.4647] audit: op="statistics" interface="wla>
Apr 06 19:12:11 cachyos-ufukd kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=fe80:0000:0000:0000:0cf0:9569:5809:1a9a D>
Apr 06 19:12:11 cachyos-ufukd systemd[1]: systemd-rfkill.service: Deactivated successfully.
Apr 06 19:12:11 cachyos-ufukd avahi-daemon[909]: Registering new address record for fe80::cf0:9569:5809:1a9a on wl>
Apr 06 19:12:11 cachyos-ufukd avahi-daemon[909]: New relevant interface wlan0.IPv6 for mDNS.
Apr 06 19:12:11 cachyos-ufukd avahi-daemon[909]: Joining mDNS multicast group on interface wlan0.IPv6 with address>
Apr 06 19:12:10 cachyos-ufukd kernel: [UFW BLOCK] IN=wlan0 OUT= MAC= SRC=161.9.23.87 DST=224.0.0.252 LEN=60 TOS=0x>
Apr 06 19:12:10 cachyos-ufukd kdeconnectd[1870]: Failed to send mDNS query: Cannot assign requested address
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3612] manager: NetworkManager state is now >
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3608] device (wlan0): Activation: successfu>
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3604] manager: NetworkManager state is now >
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3600] device (wlan0): state change: seconda>
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3598] device (wlan0): state change: ip-chec>
Apr 06 19:12:10 cachyos-ufukd systemd[1]: Started Network Manager Script Dispatcher Service.
Apr 06 19:12:10 cachyos-ufukd systemd[1]: Starting Network Manager Script Dispatcher Service...
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3403] device (wlan0): state change: ip-conf>
Apr 06 19:12:10 cachyos-ufukd systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 06 19:12:10 cachyos-ufukd systemd-resolved[691]: wlan0: Bus client set DNS server list to: 160.75.25.1, 160.75>
Apr 06 19:12:10 cachyos-ufukd systemd-resolved[691]: wlan0: Bus client set default route setting: yes
Apr 06 19:12:10 cachyos-ufukd systemd-resolved[691]: wlan0: Bus client set search domain list to: itu.edu.tr
Apr 06 19:12:10 cachyos-ufukd avahi-daemon[909]: Registering new address record for 161.9.23.87 on wlan0.IPv4.
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3331] policy: set 'eduroam' (wlan0) as defa>
Apr 06 19:12:10 cachyos-ufukd avahi-daemon[909]: New relevant interface wlan0.IPv4 for mDNS.
Apr 06 19:12:10 cachyos-ufukd avahi-daemon[909]: Joining mDNS multicast group on interface wlan0.IPv4 with address>
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.3320] dhcp4 (wlan0): state changed new leas>
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.2043] dhcp4 (wlan0): state changed new leas>
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.1930] dhcp4 (wlan0): activation: beginning >
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.1927] device (wlan0): state change: config >
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.1924] device (p2p-dev-wlan0): supplicant ma>
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.1923] device (wlan0): Activation: (wifi) St>
Apr 06 19:12:10 cachyos-ufukd NetworkManager[907]: <info> [1775491930.1923] device (wlan0): supplicant interface >
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-CONNECTED - Connection to 48:b4:c3:9f:9b:a0 >
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: WPA: Key negotiation completed with 48:b4:c3:9f:9b:a0 [>
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: PMKSA-CACHE-ADDED 48:b4:c3:9f:9b:a0 0
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-SUCCESS EAP authentication completed suc>
Apr 06 19:12:10 cachyos-ufukd systemd[1]: dbus-:1.5-org.kde.powerdevil.wakeupsourcehelper@1.service: Deactivated s>
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: EAP-TLV: TLV Result - Success - EAP-TLV/Phase2 Completed
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: EAP-MSCHAPV2: Authentication succeeded
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PEER-ALT depth=0 DNS:*.idari.itu.edu.tr
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PEER-ALT depth=0 DNS:*.cc.itu.edu.tr
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PEER-ALT depth=0 DNS:*.itu.edu.tr
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PEER-ALT depth=0 DNS:itu.edu.tr
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PEER-CERT depth=0 subject='/C=TR/ST=\xC4>
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PEER-CERT depth=1 subject='/C=US/O=DigiC>
Apr 06 19:12:10 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PEER-CERT depth=2 subject='/C=US/O=DigiC>
Apr 06 19:12:09 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-METHOD EAP vendor 0 method 25 (PEAP) sel>
Apr 06 19:12:09 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-PROPOSED-METHOD vendor=0 method=25
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.9325] device (p2p-dev-wlan0): supplicant ma>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.9324] device (wlan0): supplicant interface >
Apr 06 19:12:09 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 06 19:12:09 cachyos-ufukd wpa_supplicant[1099]: wlan0: CTRL-EVENT-EAP-STARTED EAP authentication started
Apr 06 19:12:09 cachyos-ufukd kernel: wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 48:b4:c3:9f:9b:>
Apr 06 19:12:09 cachyos-ufukd wpa_supplicant[1099]: wlan0: Associated with 48:b4:c3:9f:9b:a0
Apr 06 19:12:09 cachyos-ufukd kernel: wlan0: associated
Apr 06 19:12:09 cachyos-ufukd kernel: wlan0: RX AssocResp from 48:b4:c3:9f:9b:a0 (capab=0x1431 status=0 aid=1)
Apr 06 19:12:09 cachyos-ufukd kernel: wlan0: associate with 48:b4:c3:9f:9b:a0 (try 1/3)
Apr 06 19:12:09 cachyos-ufukd kernel: wlan0: authenticated
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.8137] device (p2p-dev-wlan0): supplicant ma>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.8137] device (wlan0): supplicant interface >
Apr 06 19:12:09 cachyos-ufukd wpa_supplicant[1099]: wlan0: Trying to associate with 48:b4:c3:9f:9b:a0 (SSID='eduro>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.8126] device (p2p-dev-wlan0): supplicant ma>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.8125] device (wlan0): supplicant interface >
Apr 06 19:12:09 cachyos-ufukd kernel: wlan0: send auth to 48:b4:c3:9f:9b:a0 (try 1/3)
Apr 06 19:12:09 cachyos-ufukd kernel: wlan0: authenticate with 48:b4:c3:9f:9b:a0 (local address=14:b5:cd:30:45:bd)
Apr 06 19:12:09 cachyos-ufukd wpa_supplicant[1099]: wlan0: SME: Trying to authenticate with 48:b4:c3:9f:9b:a0 (SSI>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6357] Config: added 'proactive_key_caching'>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6357] Config: added 'identity' value 'konuk>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6357] Config: added 'phase2' value 'auth=MS>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6357] Config: added 'fragment_size' value '>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6357] Config: added 'eap' value 'PEAP'
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6357] Config: added 'password' value '<hidd>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6356] Config: added 'key_mgmt' value 'WPA-E>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6356] Config: added 'bgscan' value 'simple:>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6356] Config: added 'scan_ssid' value '1'
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6356] Config: added 'ssid' value 'eduroam'
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6354] device (wlan0): Activation: (wifi) co>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6353] device (wlan0): state change: prepare>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6352] device (wlan0): state change: need-au>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6340] device (wlan0): state change: config >
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6340] device (wlan0): Activation: (wifi) ac>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6338] device (wlan0): state change: prepare>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6337] manager: NetworkManager state is now >
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6336] device (wlan0): state change: disconn>
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6332] device (wlan0): Activation: starting >
Apr 06 19:12:09 cachyos-ufukd NetworkManager[907]: <info> [1775491929.6327] policy: auto-activating connection 'e>
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/op>
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/opus>
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/fa>
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/ap>
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/sbc
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/sbc
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/aac
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/aac
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/aptx
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSink/aptx>
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Endpoint registered: sender=:1.69 path=/MediaEndpoint/A2DPSource/ld>
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Failed to set default system config for hci0
Apr 06 19:12:07 cachyos-ufukd kernel: Bluetooth: MGMT ver 1.23
Apr 06 19:12:07 cachyos-ufukd kernel: Bluetooth: hci0: AOSP extensions version v1.00
Apr 06 19:12:07 cachyos-ufukd bluetoothd[910]: Battery Provider Manager created
Apr 06 19:12:07 cachyos-ufukd kernel: Bluetooth: hci0: RTL: fw version 0x42d34e04
Apr 06 19:12:07 cachyos-ufukd org_kde_powerdevil[1740]: [ 1909] Udev event detected
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0494] device (p2p-dev-wlan0): state change:>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0490] device (wlan0): state change: unavail>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <warn> [1775491927.0484] device (p2p-dev-wlan0): error setting>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0483] device (p2p-dev-wlan0): state change:>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0481] manager: (p2p-dev-wlan0): new 802.11 >
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0479] Wi-Fi P2P device controlled by interf>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0476] device (p2p-dev-wlan0): state change:>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0476] device (wlan0): supplicant interface >
Apr 06 19:12:07 cachyos-ufukd kdeconnectd[1870]: No local bluetooth adapter found
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0367] manager: NetworkManager state is now >
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <warn> [1775491927.0365] device (p2p-dev-wlan0): error setting>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0361] device (p2p-dev-wlan0): state change:>
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Resumed scheduling 7 threads.
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 1514 of process 1514 owned by '1000' hi>
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 1520 of process 1514 owned by '1000' RT>
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 1515 of process 1515 owned by '1000' hi>
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 1527 of process 1515 owned by '1000' RT>
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 1715 of process 1715 owned by '1000' hi>
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 1728 of process 1715 owned by '1000' RT>
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0341] device (wlan0): state change: unmanag>
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Successfully made thread 2638 of process 2291 owned by '1000' RT>
Apr 06 19:12:07 cachyos-ufukd kdeconnectd[1870]: Failed to open any MDNS server sockets
Apr 06 19:12:07 cachyos-ufukd rtkit-daemon[1262]: Resuming known real-time threads.
Apr 06 19:12:07 cachyos-ufukd kdeconnectd[1870]: Failed to open any MDNS client sockets
Apr 06 19:12:07 cachyos-ufukd NetworkManager[907]: <info> [1775491927.0333] manager: sleep: wake requested (sleep>
Apr 06 19:12:07 cachyos-ufukd systemd[1]: Stopped target Suspend.
Apr 06 19:12:07 cachyos-ufukd systemd-resolved[691]: Resetting learnt feature levels on all servers.
Apr 06 19:12:07 cachyos-ufukd systemd-resolved[691]: Closing all remaining TCP connections.
Apr 06 19:12:07 cachyos-ufukd systemd-logind[917]: Operation 'suspend' finished.
Apr 06 19:12:07 cachyos-ufukd systemd[1]: Reached target Suspend.
Apr 06 19:12:07 cachyos-ufukd systemd[1]: Stopped target Sleep.
Apr 06 19:12:07 cachyos-ufukd systemd[1]: Finished System Suspend.
Apr 06 19:12:07 cachyos-ufukd systemd[1]: systemd-suspend.service: Deactivated successfully.
btw amd stb service is enabled now
Damn, looks clear. What about the kernel log:
dmesg | grep -iE ‘i8042|atkbd|i2c_hid|input|acpi’
$ dmesg | grep -iE ‘i8042|atkbd|i2c_hid|input|acpi’
fish: Unknown command: atkbd
fish:
wait I forgot to tell sonething, actually stb configuration is working fine now, but it blown up yesterday. I deleted it and reload again. so, probably you can’t find anything in the logs.
My bad on the command. Should be:
sudo dmesg | grep -iE "i8042|atkbd|i2c_hid|input|acpi"
You can be right - if it was restarted, it will probably be ok.
[ 0.000000] BIOS-e820: [mem 0x0000000009f00000-0x0000000009f13fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000b2f7f000-0x00000000baf7efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000baf7f000-0x00000000baffefff] ACPI data
[ 0.000000] efi: ACPI=0xbaffe000 ACPI 2.0=0xbaffe014 TPMFinalLog=0xbaf3e000 SMBIOS=0xb16e4000 SMBIOS 3.0=0xb16e2
000 MEMATTR=0xabf19018 ESRT=0xabf39018
[ 0.003916] ACPI: Early table checksum verification disabled
[ 0.003918] ACPI: RSDP 0x00000000BAFFE014 000024 (v02 LENOVO)
[ 0.003921] ACPI: XSDT 0x00000000BAF95228 00017C (v01 LENOVO CB-01 00000001 01000013)
[ 0.003926] ACPI: FACP 0x00000000BAFEC000 00010C (v05 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003929] ACPI: DSDT 0x00000000BAFD6000 00F8B3 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003930] ACPI: FACS 0x00000000BAEB2000 000040
[ 0.003932] ACPI: UEFI 0x00000000BAF7E000 000236 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003933] ACPI: SSDT 0x00000000BAFFC000 0008D5 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003934] ACPI: SSDT 0x00000000BAFF3000 00808B (v02 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003935] ACPI: SSDT 0x00000000BAFF2000 000573 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003937] ACPI: SSDT 0x00000000BAFF1000 0001CC (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003938] ACPI: SSDT 0x00000000BAFF0000 000356 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003939] ACPI: POAT 0x00000000BAFEF000 000055 (v03 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003940] ACPI: ASF! 0x00000000BAFEE000 0000A5 (v32 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003942] ACPI: BOOT 0x00000000BAFED000 000028 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003943] ACPI: HPET 0x00000000BAFEB000 000038 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003944] ACPI: APIC 0x00000000BAFEA000 000142 (v03 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003946] ACPI: MCFG 0x00000000BAFE9000 00003C (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003947] ACPI: SLIC 0x00000000BAFE8000 000176 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003948] ACPI: SSDT 0x00000000BAFD5000 000099 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003950] ACPI: VFCT 0x00000000BAFCA000 00AE84 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003951] ACPI: SSDT 0x00000000BAFC9000 0000F8 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003952] ACPI: SSDT 0x00000000BAFC3000 005354 (v02 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003953] ACPI: CRAT 0x00000000BAFFD000 000EE8 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003955] ACPI: CDIT 0x00000000BAFC1000 000029 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003956] ACPI: SSDT 0x00000000BAFC0000 0000D3 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003957] ACPI: SSDT 0x00000000BAFBF000 000BAB (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003958] ACPI: SSDT 0x00000000BAFBC000 0029B0 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003959] ACPI: SSDT 0x00000000BAFB4000 007EBA (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003961] ACPI: FPDT 0x00000000BAFB3000 000044 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003962] ACPI: BGRT 0x00000000BAFB2000 000038 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003963] ACPI: WSMT 0x00000000BAFB1000 000028 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003965] ACPI: SSDT 0x00000000BAFAE000 0022AF (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003966] ACPI: TPM2 0x00000000BAFE7000 000050 (v05 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003967] ACPI: MHSP 0x00000000BAFE6000 0000C8 (v04 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003968] ACPI: SSDT 0x00000000BAFAD000 0000E5 (v02 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003970] ACPI: IVRS 0x00000000BAFAC000 000198 (v02 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003971] ACPI: SSDT 0x00000000BAFAB000 00076A (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003972] ACPI: SSDT 0x00000000BAFAA000 0008C8 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003973] ACPI: SSDT 0x00000000BAFA9000 000057 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003975] ACPI: SSDT 0x00000000BAFA7000 001855 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003976] ACPI: SSDT 0x00000000BAFA6000 0007B5 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003977] ACPI: SSDT 0x00000000BAF9C000 0094F1 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003978] ACPI: SSDT 0x00000000BAF97000 004FC3 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003980] ACPI: SSDT 0x00000000BAF96000 000F03 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003981] ACPI: SSDT 0x00000000BAFC2000 0007D7 (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003982] ACPI: SSDT 0x00000000BAF94000 00008D (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003983] ACPI: SSDT 0x00000000BAF92000 0011CD (v01 LENOVO CB-01 00000001 ACPI 00040000)
[ 0.003984] ACPI: Reserving FACP table memory at [mem 0xbafec000-0xbafec10b]
[ 0.003985] ACPI: Reserving DSDT table memory at [mem 0xbafd6000-0xbafe58b2]
[ 0.003986] ACPI: Reserving FACS table memory at [mem 0xbaeb2000-0xbaeb203f]
[ 0.003986] ACPI: Reserving UEFI table memory at [mem 0xbaf7e000-0xbaf7e235]
[ 0.003987] ACPI: Reserving SSDT table memory at [mem 0xbaffc000-0xbaffc8d4]
[ 0.003987] ACPI: Reserving SSDT table memory at [mem 0xbaff3000-0xbaffb08a]
[ 0.003987] ACPI: Reserving SSDT table memory at [mem 0xbaff2000-0xbaff2572]
[ 0.003988] ACPI: Reserving SSDT table memory at [mem 0xbaff1000-0xbaff11cb]
[ 0.003988] ACPI: Reserving SSDT table memory at [mem 0xbaff0000-0xbaff0355]
[ 0.003989] ACPI: Reserving POAT table memory at [mem 0xbafef000-0xbafef054]
[ 0.003989] ACPI: Reserving ASF! table memory at [mem 0xbafee000-0xbafee0a4]
[ 0.003989] ACPI: Reserving BOOT table memory at [mem 0xbafed000-0xbafed027]
[ 0.003990] ACPI: Reserving HPET table memory at [mem 0xbafeb000-0xbafeb037]
[ 0.003990] ACPI: Reserving APIC table memory at [mem 0xbafea000-0xbafea141]
[ 0.003991] ACPI: Reserving MCFG table memory at [mem 0xbafe9000-0xbafe903b]
[ 0.003991] ACPI: Reserving SLIC table memory at [mem 0xbafe8000-0xbafe8175]
[ 0.003991] ACPI: Reserving SSDT table memory at [mem 0xbafd5000-0xbafd5098]
[ 0.003992] ACPI: Reserving VFCT table memory at [mem 0xbafca000-0xbafd4e83]
[ 0.003992] ACPI: Reserving SSDT table memory at [mem 0xbafc9000-0xbafc90f7]
[ 0.003993] ACPI: Reserving SSDT table memory at [mem 0xbafc3000-0xbafc8353]
[ 0.003993] ACPI: Reserving CRAT table memory at [mem 0xbaffd000-0xbaffdee7]
[ 0.003993] ACPI: Reserving CDIT table memory at [mem 0xbafc1000-0xbafc1028]
[ 0.003994] ACPI: Reserving SSDT table memory at [mem 0xbafc0000-0xbafc00d2]
[ 0.003994] ACPI: Reserving SSDT table memory at [mem 0xbafbf000-0xbafbfbaa]
[ 0.003995] ACPI: Reserving SSDT table memory at [mem 0xbafbc000-0xbafbe9af]
[ 0.003995] ACPI: Reserving SSDT table memory at [mem 0xbafb4000-0xbafbbeb9]
[ 0.003995] ACPI: Reserving FPDT table memory at [mem 0xbafb3000-0xbafb3043]
[ 0.003996] ACPI: Reserving BGRT table memory at [mem 0xbafb2000-0xbafb2037]
[ 0.003996] ACPI: Reserving WSMT table memory at [mem 0xbafb1000-0xbafb1027]
[ 0.003997] ACPI: Reserving SSDT table memory at [mem 0xbafae000-0xbafb02ae]
[ 0.003997] ACPI: Reserving TPM2 table memory at [mem 0xbafe7000-0xbafe704f]
[ 0.003998] ACPI: Reserving MHSP table memory at [mem 0xbafe6000-0xbafe60c7]
[ 0.003998] ACPI: Reserving SSDT table memory at [mem 0xbafad000-0xbafad0e4]
[ 0.003998] ACPI: Reserving IVRS table memory at [mem 0xbafac000-0xbafac197]
[ 0.003999] ACPI: Reserving SSDT table memory at [mem 0xbafab000-0xbafab769]
[ 0.003999] ACPI: Reserving SSDT table memory at [mem 0xbafaa000-0xbafaa8c7]
[ 0.004000] ACPI: Reserving SSDT table memory at [mem 0xbafa9000-0xbafa9056]
[ 0.004000] ACPI: Reserving SSDT table memory at [mem 0xbafa7000-0xbafa8854]
[ 0.004000] ACPI: Reserving SSDT table memory at [mem 0xbafa6000-0xbafa67b4]
[ 0.004001] ACPI: Reserving SSDT table memory at [mem 0xbaf9c000-0xbafa54f0]
[ 0.004001] ACPI: Reserving SSDT table memory at [mem 0xbaf97000-0xbaf9bfc2]
[ 0.004002] ACPI: Reserving SSDT table memory at [mem 0xbaf96000-0xbaf96f02]
[ 0.004002] ACPI: Reserving SSDT table memory at [mem 0xbafc2000-0xbafc27d6]
[ 0.004003] ACPI: Reserving SSDT table memory at [mem 0xbaf94000-0xbaf9408c]
[ 0.004003] ACPI: Reserving SSDT table memory at [mem 0xbaf92000-0xbaf931cc]
[ 0.023007] ACPI: PM-Timer IO Port: 0x408
[ 0.023015] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.023016] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.023016] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.023017] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.023017] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.023018] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.023018] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.023018] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.023019] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.023019] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.023019] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.023020] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.023020] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.023021] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.023021] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.023021] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.023040] ACPI: INT_SRC_OVR (bus 0 bus_irq 1 global_irq 1 low edge)
[ 0.023042] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.023043] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.023045] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.023046] ACPI: HPET id: 0x10228210 base: 0xfed00000
[ 0.066870] ACPI: Core revision 20250807
[ 0.222941] ACPI: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f13fff] (81920 bytes)
[ 0.222941] ACPI: PM: Registering ACPI NVS region [mem 0xb2f7f000-0xbaf7efff] (134217728 bytes)
[ 0.229786] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.231779] ACPI: Added _OSI(Module Device)
[ 0.231781] ACPI: Added _OSI(Processor Device)
[ 0.231782] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.259538] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP7.DEV0], AE_NOT_FOUND (20250807/dswloa
d2-163)
[ 0.259545] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20250807/psobject-220)
[ 0.259548] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[ 0.260311] ACPI BIOS Error (bug): Failure creating named object [\_TZ.TZ01], AE_ALREADY_EXISTS (20250807/dswloa
d2-327)
[ 0.260316] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20250807/psobject-220)
[ 0.260319] ACPI: Skipping parse of AML opcode: ThermalZone (0x5B85)
[ 0.264973] ACPI: 26 ACPI AML tables successfully acquired and loaded
[ 0.282543] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.282545] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.283484] ACPI: EC: EC started
[ 0.283486] ACPI: EC: interrupt blocked
[ 0.911274] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.911278] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
[ 0.911281] ACPI: Interpreter enabled
[ 0.911310] ACPI: PM: (supports S0 S4 S5)
[ 0.911312] ACPI: Using IOAPIC for interrupt routing
[ 0.913693] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.914204] ACPI: Enabled 2 GPEs in block 00 to 1F
[ 0.916211] ACPI: \_SB_.PCI0.GPP1.P0NV: New power resource
[ 0.917541] ACPI: \_SB_.PCI0.GPP6.WLAN.WRST: New power resource
[ 0.918530] ACPI: \_SB_.PCI0.GP11.PWRS: New power resource
[ 0.918599] ACPI: \_SB_.PCI0.GP11: Overriding _PRW sleep state (S4) by S0 from power resources
[ 0.919325] ACPI: \_SB_.PCI0.GP11.SWUS.PWRS: New power resource
[ 0.920100] ACPI: \_SB_.PCI0.GP12.PWRS: New power resource
[ 0.920172] ACPI: \_SB_.PCI0.GP12: Overriding _PRW sleep state (S4) by S0 from power resources
[ 0.920921] ACPI: \_SB_.PCI0.GP12.SWUS.PWRS: New power resource
[ 0.921234] ACPI: \_SB_.PCI0.GP17.PWRS: New power resource
[ 0.921558] ACPI: \_SB_.PCI0.GP17.VGA_.PWRS: New power resource
[ 0.921997] ACPI: \_SB_.PCI0.GP17.ACP_.PWRS: New power resource
[ 0.922558] ACPI: \_SB_.PCI0.GP17.AZAL.PWRS: New power resource
[ 0.923108] ACPI: \_SB_.PCI0.GP17.HDAU.PWRS: New power resource
[ 0.923630] ACPI: \_SB_.PCI0.GP17.XHC0.PWRS: New power resource
[ 0.924743] ACPI: \_SB_.PCI0.GP17.XHC1.PWRS: New power resource
[ 0.925315] ACPI: \_SB_.PCI0.GP17.XHC1.RHUB.PRT3.BTPR: New power resource
[ 0.925565] ACPI: \_SB_.PCI0.GP18.SATA.P0S0: New power resource
[ 0.925599] ACPI: \_SB_.PCI0.GP18.SATA.P3S0: New power resource
[ 0.926213] ACPI: \_SB_.PCI0.GP19.XHC2.PWRS: New power resource
[ 0.927435] ACPI: \_SB_.PCI0.GP19.XHC3.PWRS: New power resource
[ 0.928596] ACPI: \_SB_.PCI0.GP19.XHC4.PWRS: New power resource
[ 0.929756] ACPI: \_SB_.PCI0.GP19.NHI0.PWRS: New power resource
[ 0.929827] ACPI: \_SB_.PCI0.GP19.NHI0: Overriding _PRW sleep state (S4) by S0 from power resources
[ 0.930550] ACPI: \_SB_.PCI0.GP19.NHI1.PWRS: New power resource
[ 0.930618] ACPI: \_SB_.PCI0.GP19.NHI1: Overriding _PRW sleep state (S4) by S0 from power resources
[ 0.939738] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.939744] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.939966] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug AER]
[ 0.940368] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME PCIeCapability LTR DPC]
[ 0.958561] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.958563] ACPI: PCI: Interrupt link LNKA disabled
[ 0.958820] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.958821] ACPI: PCI: Interrupt link LNKB disabled
[ 0.959059] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.959060] ACPI: PCI: Interrupt link LNKC disabled
[ 0.959315] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.959316] ACPI: PCI: Interrupt link LNKD disabled
[ 0.959555] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.959556] ACPI: PCI: Interrupt link LNKE disabled
[ 0.959744] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.959745] ACPI: PCI: Interrupt link LNKF disabled
[ 0.959933] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.959934] ACPI: PCI: Interrupt link LNKG disabled
[ 0.960123] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.960124] ACPI: PCI: Interrupt link LNKH disabled
[ 0.961597] ACPI: EC: interrupt unblocked
[ 0.961598] ACPI: EC: event unblocked
[ 0.961602] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.961603] ACPI: EC: GPE=0x9
[ 0.961605] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
[ 0.961607] ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
[ 0.961680] ACPI: bus type USB registered
[ 0.973623] PCI: Using ACPI for IRQ routing
[ 0.984372] pnp: PnP ACPI init
[ 0.987636] pnp: PnP ACPI: found 5 devices
[ 0.993859] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.047540] ACPI: AC: AC Adapter [ADP0] (on-line)
[ 1.047603] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 1.047625] ACPI: button: Lid Switch [LID0]
[ 1.047653] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.047675] ACPI: button: Power Button [PWRB]
[ 1.052075] ACPI: thermal: Thermal Zone [TZ01] (39 C)
[ 1.083081] ACPI: bus type drm_connector registered
[ 1.093489] i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
[ 1.093491] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopn
p
[ 1.105824] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.107526] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.118928] ACPI: battery: Slot [BAT0] (battery present)
[ 1.139642] acpi PNP0C02:07: hash matches
[ 1.488055] input: HP 285M HP 280/285 Wireless Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-2/3
-2:1.0/0003:03F0:6F4A.0001/input/input3
[ 1.488280] input: HP 285M HP 280/285 Wireless Mouse Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0
4:00.4/usb3/3-2/3-2:1.0/0003:03F0:6F4A.0001/input/input4
[ 1.539048] input: HP 285M HP 280/285 Wireless Mouse System Control as /devices/pci0000:00/0000:00:08.1/0000:04:
00.4/usb3/3-2/3-2:1.0/0003:03F0:6F4A.0001/input/input5
[ 1.539571] hid-generic 0003:03F0:6F4A.0001: input,hiddev96,hidraw0: USB HID v1.11 Mouse [HP 285M HP 280/285 Wir
eless Mouse] on usb-0000:04:00.4-2/input0
[ 2.056061] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 2.056625] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:16/LNXVIDEO:00/input/input6
[ 5.376174] ACPI Warning: \_SB.PCI0.GP17.VGA.LCD._DDC: Return type mismatch - found Package, expected Integer/Bu
ffer (20250807/nspredef-254)
[ 5.376367] amdgpu 0000:04:00.0: amdgpu: [drm] Using ACPI provided EDID for eDP-1
[ 8.299489] acpi-tad ACPI000E:00: Missing _PRW
[ 8.355757] ACPI: bus type thunderbolt registered
[ 8.355998] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 8.460427] input: ELAN06FA:00 04F3:327E Mouse as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN06FA:00/0018:04F3:
327E.0002/input/input8
[ 8.460567] input: ELAN06FA:00 04F3:327E Touchpad as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN06FA:00/0018:04
F3:327E.0002/input/input10
[ 8.460702] hid-generic 0018:04F3:327E.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN06FA:00 04F3:327E] on i2c-E
LAN06FA:00
[ 8.566275] ACPI: battery: new hook: Ideapad Battery Extension
[ 8.567800] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input11
[ 8.685072] input: ELAN06FA:00 04F3:327E Mouse as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN06FA:00/0018:04F3:
327E.0002/input/input12
[ 8.686238] input: ELAN06FA:00 04F3:327E Touchpad as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN06FA:00/0018:04
F3:327E.0002/input/input14
[ 8.686440] hid-multitouch 0018:04F3:327E.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN06FA:00 04F3:327E] on i2
c-ELAN06FA:00
[ 8.785079] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/i
nput15
[ 8.785192] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/i
nput16
[ 8.813915] snd_hda_codec_alc269 hdaudioC1D0: inputs:
[ 8.871315] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input17
[ 8.871438] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input
18
[ 9.374469] input: keyd virtual keyboard as /devices/virtual/input/input19
[ 9.456837] input: keyd virtual pointer as /devices/virtual/input/input20
[ 92.157185] ACPI: EC: interrupt blocked
[ 100.222948] ACPI: EC: interrupt unblocked
[ 100.398511] ACPI: button: The lid device is not compliant to SW_LID.
[ 180.465302] ACPI: EC: interrupt blocked
[ 186.524817] ACPI: EC: interrupt unblocked
[ 2548.863962] input: JBL TUNE520BT (AVRCP) as /devices/virtual/input/input21
If it will broke again, I’ll kill my keyboard.
O, I finally fixed. The problem is not cachyos or limine. The problem is the Lenovo itself. There are hidden bios configurations. You have to reach them and change S0ix(modern stanby) to S3 mode. A ubuntu user in lenovo community gave me the solution:
Hello,
This worked for me(Ubuntu 26.04, no need for grub options):
Keyboard AND Fn keys working after resume!
GitHub - DavidS95/Smokeless_UMAF · GitHub
UniversalAMDFormBrowser.zip
Access your BIOS settings. Some users have reported using tools like Smokeless UMAF (a third-party utility not officially supported by Lenovo) to reveal hidden options.
Navigate to the AMD PBS or a similar setting related to sleep/standby support.
Change the setting from Modern Standby (S0ix) to S3 Enabled.
Save the changes and exit the BIOS.
Reboot your system.
https://forums.lenovo.com/t5/Ubuntu/Lenovo-IdeaPad-Slim-3-15ARP10-Internal-keyboard-atkbd-fails-on-resume-from-suspend-S3-and-audio/m-p/10009901?page=2#10055963
PS: It works on CachyOS too! It’s distribution agnostic.
I find the settings in amd pms > power management.
