Heya,
Sience i have installed the 7.0 Kernel update the OS is massively unstable, and now, even when i switch back to lts, i get random Freezes, Crashes etc (sometimes it recovers from a full display freeze, sometimes it just turns off, very unpredictable)
I have a NVIDIA GPU, AMD CPU (AM4) and 32 gigs of memory, it was running fine before that Kernel update and all other updates that came with it, i tried to fix it by downgrading some stuff, which helped for a while (graphics driver for example) but it is getting worse/is unusable and its starting to make me want to switch.
Is there anyone else having issues sience the 7.0 Kernel, is there any eta when new Updates may arrive that could fix theese issues?
I am def no Linux pro, just a casual trying his best heh, if there is anything i can try/do to fix it or at least make it usable again, please tell me.
Here are the exact specs for Reference (except the kernel)
Cachyos
Display (S24C36x): 1080x1920 in 23", 75 Hz [External]
Display (PL2730H): 1920x1080 in 27", 75 Hz [External]
WM: Hyprland 0.54.3 (Wayland)
CPU: AMD Ryzen 7 5700X (16) @ 4.67 GHz
GPU: NVIDIA GeForce RTX 4060 Ti [Discrete]
Memory: 2.08 GiB / 31.28 GiB (7%)
Disk (/): 220.31 GiB / 953.37 GiB (23%) - btrfs
Disk (/mnt/1tbdisc): 731.18 GiB / 915.82 GiB (80%) - ext4
Disk (/mnt/500gbdisc): 334.67 GiB / 457.38 GiB (73%) - ext4
