TL;DR
For Bitwig Studio users, I suggest CachyOS Gnome DE, configure Bitwig to use ALSA, not pipewire, to get the minimum latency of around 6ms.
With kernel 6.12 and sched-ext(s), one can achieve amazingly low audio latency in Bitwig Studio without sample drops causing digital distortion. However, CachyOS with KDE Plasma DE performs worse at buffer=64 samples and sample rate 48000 Hz. Gnome DE has no issues. I tested this on fresh installs with CachyOS December ISO using the flash sched-ext.
Sound system shouldn’t really have anything to do with DE, however, that’s just an opinion.
Sound should be just kernel and pipewire or pulse. Though maybe that’s not true, since Plasma can mute sound ? (not sure)
Agree @Danny_Barron. My theory is that it is the way Plasma and pipewire work. My sound interface has a ‘pro audio’ option in the Plasma Sounds setting, which Gnome does not give. I do not know much about pipewire configurations at a deeper level.
So, 1.33 ms stated in the configuration window may not be accurate.
Setting the driver model to ALSA block size gets stuck in 256. Input and output latency becomes 256. So, that setup gives the best latency of approx 6 ms. That is amazing.
Thank you for your replies. I found that, over the years, hardware (as in audio interface) also makes a difference.
I have a bit of free time over the next few days and might record a few Christmas songs on CachyOS. If I can use the USB cable for MIDI, I would consider switching back … maybe.
Never ask any LLM like ChatGPT and all the others to calculate or reason anything.
They are text generators operating on statistical probability models, not something scientific or something able to reason or calculate or have numerical or factual hard knowledge.
It’s all just textual probabilities, nothing “hard” or relieable!
So they are good at text work, because it does not matter what they exactly tell but awful on anything with facts, numbers and reasonings.
