Second monitor turns on and off
I have just installed the OS over the weekend and noticed a wierd bug, the second monitor keeps going black for a few seconds almost after every action I do on the first monitor, it could be anything, turning on an app, typing a command in terminal, anything.
one fix that sometimes works is to disable and then enable the display.
However once the PC is locked and then I re-login the problem comes back
https://paste.cachyos.org/p/d496f96.log
bump??? please its making me lose my mind
Hi!
Have you tried to change the adaptive sync to “never” on both monitors and apply? (system settings → display & monitor, if you want VRR try always instead (if you have automatic)
You could also try to lower from 165Hz to 144Hz and see if that removes the issue.
