Since a couple months I have random reboots on my system, can be twice in 3 hours or not at all after 12hrs (so not even every day), everytime while idle, afk or doing light office/browsing stuff
Usually I got 0 logs in journalctl, but lately I have the lines below “GPU lost from bus” (falled from the bus lol ?)
Updated BIOS
Removed all OC/tweaks
Reseated GPU and power connections
Removed OpenRGB as it crashed the system when first launched without -noautodetect
Tried LTS kernel
No luck
ChatGPT keeps telling me it’s a low power distribution fault likely from the PSU, I’m quite dubious but have no clue…
Is some genius here able to help ?
Specs : AMD R9 7950X3D CPU/ Asus ROG STRIX X670E-E board/ 2x32GB G-Skill Trident Z Neo 6000CL30 RAM / ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case / Arctic Liquid Freezer III 360 ARGB cooler/ 2TB WD SN850 NVme + 2TB Crucial T500 NVme + 4TB Toshiba X300 HDD / Corsair RM850x PSU/
Log :
mai 18 23:05:46 cachyos kernel: BIOS-provided physical RAM map:
– Boot 296fa72905044025ae7df5ca2957eac7 –
mai 18 23:05:21 pdf-CachyOS kwin_wayland[2371]: With the output of ‘sudo dmesg’ and ‘journalctl --user-unit plasma-kwin_wayland --boot 0’
– Boot c16359c5b5b9478693e4d051dab7142f –
mai 18 23:05:46 cachyos kernel: Command line: quiet nowatchdog splash rw rootflags=subvol=/@ root=UUID=5b60956b-e1ef-4ec7-91b4-96ac643ddb3a
mai 18 23:05:21 pdf-CachyOS kwin_wayland[2371]: Please report this at Making sure you're not a bot!
mai 18 23:05:46 cachyos kernel: Linux version 7.0.8-1-cachyos (linux-cachyos@cachyos) (clang version 22.1.5, LLD 22.1.5) #1 SMP PREEMPT_DYNAMIC Fri, 15 May 2026 13:22:28 +0000
mai 18 23:05:21 pdf-CachyOS kwin_wayland[2371]: Pageflip timed out! This is a bug in the amdgpu kernel driver
mai 18 23:05:21 pdf-CachyOS kernel: amdgpu 0000:03:00.0: Failed to export SMU metrics table!
mai 18 23:05:21 pdf-CachyOS kernel: in params:00000005
mai 18 23:05:21 pdf-CachyOS kernel: amdgpu 0000:03:00.0: SMU: bus error for message: TransferTableSmu2Dram(18) response:0xFFFFFFFF
mai 18 23:05:21 pdf-CachyOS kernel: amdgpu 0000:03:00.0: device lost from bus!
mai 18 23:05:20 pdf-CachyOS kernel: amdgpu 0000:03:00.0: Failed to get fan speed(PWM)!
mai 18 23:05:20 pdf-CachyOS kernel: amdgpu 0000:03:00.0: Failed to export SMU metrics table!
mai 18 23:05:20 pdf-CachyOS kernel: in params:00000005
mai 18 23:05:20 pdf-CachyOS kernel: amdgpu 0000:03:00.0: SMU: bus error for message: TransferTableSmu2Dram(18) response:0xFFFFFFFF
mai 18 23:05:20 pdf-CachyOS kernel: amdgpu 0000:03:00.0: device lost from bus!
mai 18 23:04:59 pdf-CachyOS kdeconnectd[3225]: No uuids found for “D0:5A:00:01:D7:36”
mai 18 23:04:55 pdf-CachyOS pika-backup[3446]: 2026-05-18T21:04:55.116293Z INFO pika_backup_common::config::loadable:16: Loading file “/home/pdf/.config/pika-backup/schedule_status.json”
mai 18 23:04:55 pdf-CachyOS pika-backup[3446]: 2026-05-18T21:04:55.116271Z INFO pika_backup_common::config::loadable:85: Reloading file after change Some(“/home/pdf/.config/pika-backup/schedule_status.json”)
