I have used Linux for about maybe 1.5-2 years now, but due to free-time situation I still consider myself new to Linux.
So…
1 With the different download/upgrade commands in CachyOS (DLSS, FSR, XESS), where are these files put, and is this something I later need to manually remove if I remove game/Steam?
2 Is the umu wrapper installed if I have the standard CachyOS install? Or do I need to manually pacman umu-launcher?
3 How do I know if my CachyOS-Proton use umu or not?
4 Normal Proton does not use umu right?
5 Why is there a Wayland command, do I use it when I run Wayland? Why/when use?
6 Why is there a HDR command, when I have HDR monitor and KDE is set to HDR enabled? Do not my games run in HDR if they support it without this command?
7 What games can the Proton-CachyOS-slr proton make run with anticheat?
8 Does all the commands also work for SLR version? Does ‘all games’ run with SLR version?
9 Why use Proton-GE if CachyOS-Proton is based on GE?
10 In general, Steam overlay on Linux is a no no? Looks like games and functions break if enabled.
11 I am a little confused on what CachyOS advice me to do in the Lutris vs Heroic situation. Can Lutris run all, or is it adviced to use Heroic for Epic, Gog and Amazon? Use what launcher for which brands and why?
12 Does really the “game-performance” command do anything as of 2025? If so, what?
13 Is really gamescope still a part of the gaming package? If so why/when use it?
