Do I need to install anything else? I have a
Canon TR4700 series printer with fax capability, but it doesn’t print under Linux.
Connect the printer to the network via Wi-Fi. Then you can install it “driverless” (IPP) using CUPS. The scanner should work out of the box; if not, install the “sane-airscan” package.
Thanks It’s working again. Thank you very much for the quick reply.
