If possible, I’m here for a short answer to the question: is the problem more likely in my connection or the servers? (This has only happened with brave-bin so far and during system updates there were several packages among hundreds that did not look to download due to error 404)
sudo pacman -S brave-bin
(translated from google.translate) error: failed to get file from:
warning: some files could not be retrieved
error: transaction failed to complete (some files could not be retrieved)
Errors were found, packages were not updated.
Im using Cloudflare DNS’s 1.1.1.1 & 1.0.0.1
And i don’t think that rate mirrors is good idea because i leave in Ukraine and there could be blackouts so servers may be shutdown, or you think it still worth to try it?
Sadly it didn’t help. I think its server problem maybe because i can easily install any other package except brave-bin and couple packages that had error while i updated system today (like 3 out of 500)
