Proton-Cachyos issue
wine: could not load ntdll.so: /usr/share/steam/compatibilitytools.d/proton-cachyos/files/lib//wine/ntdll.so: cannot open shared object file: No such file or directory
reg: The operation completed successfully
Proton: /home/renkei/Games/cyberpunk-2077/drive_c/Program Files (x86)/GOG Galaxy/Games/Cyberpunk 2077/bin/x64/Cyberpunk2077.exe
Proton: Executable a unix path, launching with /unix option.
fsync: up and running.
Command exited with status: 1
I tried reinstalling the whole gaming package didn’t fix the issue, seems like its looking for the NTDLL in the wrong location opting to use a different runner over proton-cachyos for now, but curious if there is a way to fix it besides uninstalling.
I have gotten this as well before, atm it’s not doing it for me when playing ESO.
UMU_NO_RUNTIME=1 is set already still pulls out this error.
Set it up correctly according to Gaming with CachyOS Guide | CachyOS
that’s exactly the guide i followed to begin with that lead to this issue.
then I would suggest opening an issue in Issues · CachyOS/proton-cachyos · GitHub because I am quite unfamiliar with proton, especially in non-Steam environments.
Re-followed the guide than it worked than crashed on cyberpunk using its runner. Now its busted again, very strange, It seems as if the crashes i’ve been having has been corrupting the proton-cachyos folder
