Problem installing with NVIDIA GTX 1050 2GB
I tried installing it a couple of weeks ago with KDE Plasma and Limine. I tried several methods, but I still couldn’t get it to install due to Nvidia errors. I solved it by changing the GPU to an older AMV card and then…I finished installing to change the GPU to my Nvidia, but it fails in some things like the OS freezing. If I were to reinstall on a different drive, how could I avoid further headaches? Is there a way to make everything work without extensive configuration on the console before installation? Everything indicated that the problem stemmed from CachyOS trying to install the 595xx drivers when my GPU is not compatible. (PS: I’m writing this with Google Translate, in case anything is misread)
I mentioned it earlier today to someone else that when I reinstalled CachyOS with the latest iso, it chose the correct nvidia 580 driver for my 750Ti.
So I wonder did you try with the current iso?
You might try a live usb and chroot into your system.
Then use chwd to install the driver you need.
I haven’t tried it yet, I’ll be able to do it in 2 days.I haven’t tried it yet; I might be able to in two days. I hope it works as you say, thanks for the tip.
I’ll keep that in mind, thanks.
u can use
”sudo chwd -a”
on ur nividia card in tty or terminial or chroot
A little late, but I tried it with the current ISO and it worked perfectly!
